Just drove it to RadioShack today to buy my last switches for my latest project. Glad it's FINALLY done! Lol. Now just need to get it sold so I can fund our vacation and get back to modding my truck.
FFB7EE7E-A059-4C86-98D7-CEE38DDFF50B_zps
878119D0-245A-49B6-956D-717716A9200C_zps
Man, that is freaking sweet! I need some details!
The connector tilts back so the phone leans like it would if it just​ sat in the groove. I get a little lean from side to side but I plan to beef it up with some rubber or something to eliminate that.
Sent from my Pixel XL using Tapatalk
A little update... Added some foam to support side to side movement. No issues at all since doing that but I also bought this new cable I'm going to swap with the current one to have more slack for a better adjustment at the phone end. I've popped​ the console trim off a lot in the past for mods so wanted to give myself more slack.
Lots of time, money and labor. Lol. I built it to sell and fund our family vacation. It's actually the 3rd one I have made. All done from scratch. Everything inside is fully adjustable and I can guarantee it is nicer inside than a safe you buy at the store. 5050 leds inside the door and inside the safe that turn on by pressing the vending buttons on the outside. Very bright and I love the custom switches I made. I have it on Craigslist and Armslist at the moment.
No link to your ad?
It would be kind of funny if you could insert some coins or dollars to get it to open.
http://akroncanton.craigslist.org/for/6071548639.html?lang=en
Pop machines are not cheap by themselves. Lol. The internal guys literally take up every inch inside. You could make some sort of container in the exact shape as a pop can and fill it with ammo. If I owned a shooting range, I would definitely have that in my lobby area.
hmmm, what's pop? i've heard of soda before. :D
You must be from the south.
Ryan B.
Underseat storage
Is that the factory GM version? I like that one.
Yessir. Fits nice with the Husky mats as well.
Freakin sweet! Cause I have the Husky mat also for the rear seats. Guess I need to add one of these to my list now.. Thanks for the info. And thanks for your Service as well..!
Ok, so still figuring out how to post photos.
I dipped my dust covers on my rims, I was going to do the little removable fingers but I thought it might be to much.
Not sure if I like it though.
I like the all black rims also but what if you did just XD lettering on the cap in red instead of the whole thing?? Just an idea.. Nice truck though
Ryan B.
I'm from Illinois originally and I didn't realize that only Midwesterners says pop. Everybody else is coke or soda. I almost broke three girls necks the first time I said pop in Alabama.
Sent from my SM-G930V using Tapatalk
Thanks. 12yrs has flown by.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
