How do you keep the phone from falling when you accelerate? Or do you have a 5.3? :rollin:
The connector tilts back so the phone leans like it would if it just​ sat in the groove. I get a little lean from side to side but I plan to beef it up with some rubber or something to eliminate that.
Sent from my Pixel XL using Tapatalk
Got a set of new shoes 33x12.5 on stock 18s no rub.
looks good - tires would that be a 275 or 285 ???? How do you light your running broads , any problems getting in or out . thanks
Its a true 33x12.5, that would come out to a 318x60 according to tire size calculator, running boards are alright i dont really use them but everyone else that gets in my truck does.
Can you tell me what brand your running boards/nerf bars are? I really like them.
Did they attach to the factory holes? Any issues with them?
There rough country, yes bolted right up very simple took maybe 10mins a side to install, no complaints they are solid.
Installed Morimoto fog lights and changed cabin air filter (26,000 miles)
Curious, when you guys change the cabin filter is it because it smells or the mileage. Do you notice an air quality diff withe the filter changed?
Sent from my Nexus 6P using Tapatalk
Added a heated steering wheel.. my favorite mod so far lol
  • Like 4
Based solely on mileage. With all the crap we breathe in in the city as is I doubt it's be able to tell the difference under normal circumstances. Edited by tootall87
Did this yesterday but removed the stock running boards.
Whatd you do for a wheel and tire set up?? Looks great.
Thank you. They are Toyo Open Country RT (33x12.50x20) and XD820 in Satin black.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
