Why are people so concerned about this topic. I do not understand it. Just drive it. End of story. And yes, even if you can't figure out why the truck has it, it is to save fuel.
Because those of us that bought a 2014 truck have a vibration and drone when the AFM kicks in. It is like an under power dogging that will not go away. When in town I have to run in tow mode and it stops. GM has a huge problem and are not fixing it. Keep your 2013 and enjoy.
Try M5 in town stays out of V4 shifts better over 55 click up to m6. Work good for me. At least for me these trucks are awesome.
Vibration or drone..... Shut up!
Try M5 in town stays out of V4 shifts better over 55 click up to m6. Work good for me. At least for me these trucks are awesome. Sent from my iPhone using Tapatalk
If I wanted a manual transmission I would have bought one.
Sorry for tying to help, I get in pull down to m ( just pass drive) click it up to m5 it dose the work just dosent shift in 6, no v4, shifts better. At 55 I hit the button one time. I know it's real hard but better then being annoyed.
I have absolutely no problems with the AFM in my truck. I guess I'm lucky. I hardly even notice when it kicks in or out and no drone or vibration.
Tapatalk via iPhone 5s
I have absolutely no problems with the AFM in my truck. I guess I'm lucky. I hardly even notice when it kicks in or out and no drone or vibration. Tapatalk via iPhone 5s
I'm guessing stock exhaust?
Nope...Flowmaster true dual exhaust.
And you hardly notice it, because your used to it. That would be my guess. I hated it and yes I could notice it. Mines turned off, one of the best things I could have done, IMO.
No I don't notice it because my last truck, a 2007 LTZ 5.3L, was awful!! It droned and vibrated like folks on here talk about. In comparison this 2014 is a dream. I wonder if the 6.2L is the difference. Tapatalk via iPhone 5s
Edited by LTZTom
When in town I notice it a little, after 55 not so much. I wouldn't call it a problem, when I get around to a tune Ill keep it,just after 55. I didn't notice it till the exhaust.
My 2 cents....I came from a 2011 with oil burning issues and yes the AFM on the 5.3 was crap for sure. Before I tuned it I had a borla touring and yes it did drone slightly. Post tune it was just fine with the AFM turned off.
Fast forward to my new 6.2L...I fully intend to put a range module on it when supported fully as I have had one of those as well. I have to admit that the AFM on this truck is WAY better then my 2011. Yes I can feel it some but it really is night and day. Drone is no issue with stock exhaust. I really don't plan any exhaust mods as I tow a TT and cant stand the noise at highway speed for 2000 mile trips. Maybe I'm just getting old?
The range module is something I could do or a GM tech? Where do I get the range module? And no you are not getting old. Just wiser.
Yeah you can purchase it direct from them or autoanything usually offers a discount. They are not fully supported for 2014 yet although some on here run them without problems. I used one previously that worked flawless. I will just wait until the bugs are out and get another. Yes you can install it. It simply plugs into your OBD port, bottom under dash. Literally plug it it in, thats it.
I bought it from Range Tech today. The other place was out. I put my VIN in and it was accepted as compatible.
Tracking shows it will be delivered Monday.
    • Howdy folks,   Recently I pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain (part numbers coming soon - will have to disassemble), and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash for the heating element.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But I seemingly can’t turn it off AND still no backlights on any of the buttons.    Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
    • I'm about 1800 miles into my last oil change, and yesterday a message appeared saying oil life was at 77%. Not sure why it popped up but I think all of these electronics could be susceptible to solar flares or somesuch. I change my oil right at 3K each time, and that was the first time in 10870 miles that message came up. Strange thing is that it showed on the screen at all since I don't drive with that sort of info displayed on the DIC.
    • I’m praying that someone sees this and can help me out… pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain, and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But can’t turn it off AND still no backlights.   Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
    • Checked the pads today and there's plenty of meat on them. If the message keeps coming up, I'll just answer YES that the pads were replaced and wait for the squeal.
    • Welcome to the Forum! Always post the code definitions along with the codes. there are over 18000 possible codes, no one remembers them all and most will skip over your post rather than look them up
