Gear Change 9.5" 12 bolt
CAtaylor
I talked to Yukon a few days ago. They are working on a new ring and pinion for the new rear end. They did not have a time frame but was told it should be by the end of the year. It will make the gear change much more affordable once they release it.
  • Replies 131
It doesn't look like they are in too much of a hurry, a guy was running their prototype in march of last year. They must have run into issues.
  • 3 weeks later...
Figures. I dont mind waiting as long as it is worth the wait and all the bugs are worked out. they have a pretty good reputation so i expect the product will be right whenever it finally is released.
  • 3 months later...
I have 3.08 as well and really looking to re-gear at some point. Gets pretty decent mileage, but downshifts all over the place. Drives me crazy! Hoping Yukon comes out with something around the same time I get my 33's!
On another note, those of you with the Diablo tuners, can you do a flash for a regear? Just want clarification on that.
Yes with a Diablo Intune I-1000 you can reprogram for new gears, tires, and more.
Want to share my experience to maybe help others. Long story but some might want to know.
I very recently bought a 2014 1500 Z71 with 3.08 gears and did not like the way it was constantly searching for gears. I regularly pull a 2000 lb trailer. First time I hooked up to it the shifting was worse and I could not get the truck to stay in 6th gear at 70 mph. No the tow/haul button was not engaged. 2000 lbs is not really "towing". I could put the transmission shifter in M and shift to 6th but it would go straight back to 5th when shifting to drive.
So I started googling and found this thread amongst a few others but this one has the most information. Yes I could have had them order a max-tow truck but I think I still came out ahead because I got such a good deal on my 2014. I researched and researched. Called East Coast Gear a few times too. But ended up ordering from Randy's. Randy's happened to have a front and rear set of Yukon 3.73 gears that were "used" for a very low price. Yes I put used gears in a new truck.
The salesman assured me that the gears had not been installed but for some reason they could not be sold as new. So I took a chance and got em. He also assured me I didn't need a new rear carrier. This truck will rarely leave the highway but I will occasionally need 4wd. The Gov-Loc will suit me fine. The salesman told me I needed a new front carrier and master install kit for it but said I only needed a mini kit for the rear. This was incorrect. The mechanic broke some of the ring gear bolts on the rear due to what he described as massive amounts of fresh loc-tite. So I had to order ring gear bolts that would have been in the master kit. Well the same day the ring gear bolts came in they slapped the carrier back in to find out there weren't enough shims in the mini kit. None to be found locally. Had to order a shim kit. I had printed out the how-to instructions from East Coast Gear and told him the factory carrier might not fit with the new gears. It did just fine. No I didn't need a diff cover spacer. Those have nothing to do with new gears. They are required for aftermarket carriers as apparently they are "meatier". And no machining of the brake caliper.
As stated earlier you must buy a new pinion yoke. I chose the Yukon strap type that uses the factory u-joint. Also you can't use the pinion seal in the install kit. But Randy's gives you a part number for a aftermarket seal. That seal is designed as a rear main seal. Not a pinion seal. The OEM seal is what you want. Of course the factory seal will be ruined during install. Just go to the dealership and order a new one. Mine was $47 after tax.
My mechanic was very thorough in the installation. He checked the pre-load several times with an inch-lb torque wrench. He got the truck back together on a Friday at 5:15. I was there and elated. Thought I was going to get my truck back for the weekend. .......wrong. I knew it would need break-in but he wanted to do it himself. The next Monday he let the truck run in idle for a couple hours on the rack in gear. Then he drove it 20 miles and let cool down 3 times. After all that he let me have it. Told me to come back in 500-1000 miles and he would change the diff fluid to factory specified oil. I think he put some generic 85w in it at install. No gear whine whatsoever. Charged $1,100 for the install. I purchased all the parts myself.
After getting the truck back it drove GREAT!!! Transmission goes into 6th at 45mph and stays there. RPM's are at 1970 at 70 MPH in 6th. With the 3.08's the RPM's were at over 2100 at 70 mph in 5th gear.
Now about the speedometer. Before I bought anything I asked the service manager at the dealership if he would get a VCI number for me and correct my speedometer after the change. He said they would try. This should be possible as 3.73's were a factory option. After I got my truck back from mechanic I went to dealership.....had to make an appointment for the following week. When that day came I had the truck there. But was a waste. Technician simply told me it couldn't be done. I didn't push the issue as I will be using them for any warranty work that might be needed. Ordered a Hypertech that day and programmed two days later......which was last night.
Speedometer is now correct and I don't know if it is in my head but the truck seems to be shifting even better than before programming.
Truck stay's in V4 mode almost the whole time in city now. As other's have reported better mileage in town as well. I'll report back actual mileage after a few tanks.
ZK GM8.25IFS-B Front install kit
YC G26018131 Front carrier
YG GM8.25-373R Front gears
ZK GM9.5-B - USA Standard Gear Rear install kit
YG GM9.5-373 - Yukon Gear Ring & Pinion Sets Rear gears
YY GM19256396 - Yukon Gear & Axle Rear yoke
And the factory rear pinion seal. I think that is it.
If you want to put a locker or limited-slip in it you can, you will just have to "dent" out your factory diff cover or buy the spacer from East Coast Gears.
Anybody have any updates on a direct fit 4.10 gear swap?
Nothin direct yet from word i got, but the conversion cost approx the same if your changing to a better locker anyway , i wouldn't trust the g80 with 4.10s if your getting good traction from a launch anyway, they don't have a great rep
So the rear Ring and Pinion set is the same part number from the old gear sets all the way back to late 97-current.
RT
Does anybody know if anybody has made 3.73s for the 9.5" 12 bolt yet? Last I saw there was only 3.08, 3.42 and then 4.10. I believe there's a 3.73 for the front diff since I don't think that changed, just curious more on the rear 9.5" 12 bolt diff.
    • Enjoy the new truck, it’s a beauty. I’m glad you’re keeping the OBS, I love those old trucks.
    • With large equipment or deep mud it is more of a use the higher gear to avoid spinning tires, getting stuck because of spinning tires and doing damage to your machine. The idea is if you run out of torque before you spin tires you can still downshift for more torque. If you are just spinning your tires in the lowest available gear you are stuck and things break.   Automatic transmissions, traction control and electronic transfer cases change the calculation a little as you the driver have less control over each piece.
    • are there any codes? with lots of rust, perhaps disconnect/clean both sides of the connection/examine cable ends (the wires) for corrosion going into the sheath & replace if necessary/reconnect ALL the power AND ground cables between the battery, engine, frame, cab, fuse box and starter charm.li (website) has a no-start diagnostic procedure you can work through to get it working.
    • Its no wonder you've gravitated to the oil types and brands you have in later years after trying certain brands and one being a specialty oil or at least very hard to come by up here and the other would have been a commonly found oil of the era and the vastly different outcomes as a result to using the vehicles in question the same distance for an OCI . It shows what marketing hype can do without actually having the product to back up the claims and that is no different now with the insane claims that are written on the side of a bottle of oil from some of the off the shelf oils.    What has surprised me and I was already finding this out before I bought my truck with the GDI engine, that this newer fancy technology that seemingly would suggest better fuel economy/emissions with this high pressure spray of fuel is not in reality kind at all to the engine or at least the oils life. Yet they insist on claiming long OCI with this technology just like they did with the port or similar type fuel injection systems when in reality its a step back in oil life to have a GDI system.    I think the mistake your making Grumpy is that your not sending your samples to Blackstone and getting the feel good glowing report that you can run it another 1000 or more miles and then send another sample where they say run it yet another 1000 miles and on and on it goes until your sending in something that looks a lot like road tar and then they may suggest you change your oil within the next 1000 miles 😆
    • I am guessing that engines of that design back then had a better ability to be abused and survive longer than a new design engine with the long timing chain and the overhead cams and phasers etc. But I would never guess that an engine could go that far and not fail spectacularly or at least die a slow death.
