Does anyone else's engine seem to bog down at lower RPMs? Many times when accelerating it's as if the engine is choking on itself then catches up once a higher RPM is reached.
Another funny thing is when driving slowly up a steep incline. The truck seems to stay in 2nd or 3rd gear until it almost stalls. I'll press the pedal in a good one to two inches before it downshifts to first gear at 4k RPM. Seems like a 5.3l should have enough power to drive up a hill without downshifting to first to avoid stalling.
Possible fuel pressure problem?
what gears does your truck have? if its the 3.08's its gonna take a bit of push on that skinny pedal to get her moving.
Ha that's what it seems like! My 08 Sierra had an easier time accelerating and going up steep hills.
Does anyone else's engine seem to bog down at lower RPMs? Many times when accelerating it's as if the engine is choking on itself then catches up once a higher RPM is reached. Another funny thing is when driving slowly up a steep incline. The truck seems to stay in 2nd or 3rd gear until it almost stalls. I'll press the pedal in a good one to two inches before it downshifts to first gear at 4k RPM. Seems like a 5.3l should have enough power to drive up a hill without downshifting to first to avoid stalling. Possible fuel pressure problem?
I have the same issue and was wanting to know as well with the bogging down/hesitation at lower rpm's. I also have the 3.42 gears. Can't comment on going up a hill, it is all flat land here. I think I remember having this on my 2005 GTO, wonder if it has to do with the throttle being electric instead of a cable?? Would a tune take care of this problem?
Edited by jcastyo
my 5.3 and the 3.42 gears gets up hills no problem. You just gotta get into the skinny pedal a bit more compared to your 08 with a 4 speed trans. The 6 speed trans needs more throttle to downshift. Don't be afraid to rev the engine up...that's what they are made for.
Edited by fondupot
I HAVE to push the pedal down to get it up the hill. Just seems a little ridiculous to downshift to first gear at 4k RPM to make it up when an older vehicle cruised up no problem.
Under light acceleration, the truck will remain in V4 mode and almost feel like its bogging. Mine does it as well and i just push the gas a little more and you can watch it go into V8 and feel it light up right away. Just put a little lead in your foot lol.
Disclaimer: my 08 was blackbear tuned. Might have spoiled me a little. Too paranoid to tune the new truck because of warranty though.
Combo of Variable Valve Timing, V4, 6 speed. Mine does the same thing. Sometimes at low speed , stomp the gas pedal and NOTHING. Like a deer in the headlights for a second or two.
This is why I like manual transmissions. I currently have one in the 2013 Chevy Sonic. Although I have no complaints about the 4 speed auto transmission behavior either in my Silverado or Impala LTZ. Impala especially is very quick to downshift when you push on the gas pedal even slightly. Silverado requires slightly heavier throttle to downshift but then the non-AFM 5.3 has a lot more torque than the 3.9 liter V6 in my Impala so it can run at lower RPMs in the fourth gear without feeling too strained.
I believe that GM in their effort to maximize the fuel economy has pushed things too far on these new trucks and maybe some aftermarket tuning can fix it? We have a 2012 Silverado crew cab 4X4 with the 5.3 AFM engine/6 speed auto at work and I do not find any issues with the transmission shifting. I cannot tell when it is switching between 4 and 8 cylinders either.
Edited by pm26
Do you still have this problem?
Did you take it in?
Did you figure out a way to encourage to downshift but not all the way to first (or whatever gear is resulting in 4000).
Yeah, still have the problem. Took it in to dealership twice, but they aren't any help. They just say there's no codes, and won't look into it further. Seems almost like a fuel pressure problem or spark problem, but I don't have the means or know how to check it out myself.
I did get a diablosport tuner, and the canned tune seems to help. Just started the process for a custom tune from Lew.
I did do a log file and noticed the fuel pressure drops when first accelerating. Does anyone know if this is normal?
    • I find it amusing the OP doesn’t realize this threads heading includes several engines. He should have posted in the off topic section if he wanted a more narrow focus. I really appreciate and find amusing that he actually pointed out one of my many vehicles. The Odyssey. That happens to use 0-20 oil. I love pushing his buttons.
    • Maybe, but it seems he is the only one that has backed up data to prove what he is stating. I think he is doing this more because he enjoys it and wants to get the information out to us. He's got the knowledge and access to the proper equipment and having the funds doesn't hurt.  I would love to do what he is doing and would do it if and when I hit the Powerball.  I'm not a Tribologist by any means but love to learn what I can.   I would bet there would be doubting people out there if a completely independent lab with high quality work and highly respected in the automotive industry, put out information like this.  The world can't be pleased, one just has to take the information that they are given, do more of their own research to find actual lab data to back up what they are trying to figure/find out.  Most don't bother, they just want to believe what they first see.     I don't have the minimax but my 6.2 in my 2019 Silverado with 64k miles shows excellent UOA results with 0w-20 and for my own purposes 5w-20.  Since not much of a change using 5w. I liked the data sheet information on the SS 5w-20 and figured I would give it a try.  Still the same viscosity at 100℃.   In the end we all just do what makes us happy, life is too short to get upset over trivial social media.   On a side note, I do feel GM has dropped the ball and just cares about the bottom dollar and not quality anymore.  "Like a Rock" has been long gone.  Seems "Built Ford Tough" has as well.
    • Better than stock but that's like putting lipstick on a pig
    • Hello, my 3 month old Sierra Elevation wont recognize a trailer with electric brakes? All the lights work correctly, but no power to the brakes?   This is the factory installed brake controller. If you manually push the knob, the display shows the power % but does not light up like my 2022 silverado.   I have an appointment with the dealer, but was checking to see if anyone else has seen this issue.    Thanks,
    • Been using SS 0w-20 from new, but wanted to change to the 5w-20 because I liked the data on the data sheet, to me it seems like a little better product. But as you can see, not much difference. This is also with running a mix of 10 gallons E85 to a tank topped with 93. It isn't a flex fuel vehicle so any higher I get a CEL for running lean on both banks. Yes my mileage takes a hit. Instead of 20 mpg I normally get on trips I get 17mpg. This is also using EaO17 filter.  What is amazing is I have the AMSOIL cone filter on it since I have the GM Performance intake installed and that air filter has 44k miles on it.  I just take it out and shop vac it off once a year.  I use the upholstery tool on my shop vac.  Works well.
