What are the main differences between the 2? I looked up and found the vette and it shows 450hp vs our 420, is it all tuning? Are there any simple changes to make it match the vette? I know you can do anything with aftermarket parts and tunes, but I think itd be cool to do it with factory parts. I intend to put the vette vaule covers on just as a convo piece (if possible, yet another ? Lol)
Intake manifold is the big one. The trucks have one with longer runners to help low-mid range torque but it hurts top end HP a bit. Obviously cam timing/tuning is probably pretty different as well.
I'm sure the C7 exhaust manifolds up the horsepower rating. The C7 fuel rail covers would look sweet if someone can get the gm part numbers for them....of course someone will have to be the guinea pig or someone with a C7 can test fit for us. A few companies make color matching covers which would add that extra flare.
Cam, tuning, intake manifold, exhaust manifold and exhaust system are where the differences are going to be at.
I wonder if this would fit our 6.2L trucks? It came off a 2013 Camaro.
I like the look but would rather have just the fuel rail covers. You cover the intake manifold then it holds more heat.
I would say you are on the money, along with the intake and exhaust manifolds..... Oh and 12" of elevation change.
It would be easy to bypass the vets power with a good cam and headers. I can't wait until the aftermarket starts kicking parts out for these things.
Dont forget about the thousands of pounds of weight difference between the two applications. Its not just about the engines and 30hp won't make a truck feel like a corvette.
See, I don't get that... am I the only one that would rather have a Corvette that feels like a truck? I am 3/4 hillbilly though!
The 6.2's in the cars vs trucks feel much different. At least my truck feels more torquey, camaro is definitely faster
Ryan
I wouldn't count on it. Our intake is much taller than the LT1's.
Engine covers don't fit between different 6.2 engines
Ryan
I bet there will be lighter valves in the vettes heads and possibly sodium filled or some minor differences in valvetrain. Not sure if ours are hollow stem or what.
    • This is NOT impact damage nor neglect. There were previous class action lawsuits because of such paint preparation st GM manufacturing plant. Not just the Cherry Red Color. This paint is applied in three processes to obtain the desired color.  The manufacturer will cover for 36 months or 36k miles only. That rust is actually corrosion because of the paint process failure. Corrosion is covered for 100,100 miles or a certain months. However their corrosion doesn't include this type. Go figure. Clearly manufacturer knew from previous paint issues. This started 3 weeks ago out of the blue.
    • Is it time to put a piece of tape over the CEL?
    • consider doing electrical testing?  I would guess some power or ground wire/connection has a problem.   alldata.com has wiring diagrams, connector pinouts and diagnostic procedures you can use to find where the problem is.
    • Any joy with this truck seems to be short-lived.   The CEL for P0172 ("bank 1" too rich) is now "intermittent".   I'm not sure where to check, or re-check, and my energy to keep chasing problems with junk is wearing thin. The P0172 seems to set as I'm coming to a stop, completely off the throttle, when fully warm. At least, that's what it's done the 3? times it's set.   Everything appears normal on the scanner EXCEPT long term fuel trim. There's only one bank on this vehicle because it's an OBD 1.5 with only one upstream O2 sensor. At idle, it's around -16.4% and will dip to -18% occasionally at idle or off-throttle. LTFT approaches 0 when throttle is held at 2500rpm. Short term appears normal, much closer to zero all the time. The LTFT tells me the engine is running rich at idle but compensating at higher load. But, why?   The EVAP purge valve doesn't appear to be leaking/sucking fuel vapor continuously. Is it sticking just as I come to a stop and the engine is choking on fuel vapor and sets the P0172? But that doesn't explain the persistently negative LTFT. Disconnecting the purge valve doesn't seem to make any difference.   I suppose that leaves another dang issue with the fuel injector. A leaking fuel pressure regulator, a new leak in the spider, or a leaking fuel injector/poppet valve I didn't see, or a small crack in one of the spider legs.   The vacuum line leading to the fuel pressure regulator doesn't have raw fuel in it. It doesn't even smell like fuel when it's pulled off, not until you suck air through it, then you can tell it leads to a fuel component. I'd consider that normal? Nothing is signaling this is a FPR issue from the outside, at least.   The oil smells like fuel but it's not building volume. I've noticed most oil in most engines smells like fuel to some degree so it's hard to say if the smell is an issue or not. Or if the engine just still smells like fuel because the crankcase was full of it a few hundred miles ago. But it's been changed twice since that original issue of the leaking fuel line dumping fuel into the intake.   Patience is running very thin. Every win seems to be accompanied by two steps backwards, or another issue that leads to removing at least the top half of the intake manifold. Enough! LOL
