What are you towing with your 2014?
Thanks, it's a blast to drive. Had it to almost 90mph one time. Lol..
I know that boat in the background will top that with it's 502ci LS motor. LOL
Sent from my SM-N900V using Tapatalk
  • Replies 458
It rides on Pirelli PZero slicks, the track was about 90 miles out. I usually drive it on the slicks when the venue is local. This time, it was an opportunity to trailer it, I've been waiting for it.
Lol yeah slicks are great for the road. Read a story of a guy over on the GT500 forums who got caught in the rain with slicks and 1100rwhp. Spun out on the highway going 50mph lol.
Slicks in the downpour take very little speed and power to hydroplane. Depending on the amount of downpour and drainage, preferrably, speed is kept at 45 mph; at certain cases, 50 mph is possible and at certain other cases, 40 mph would be too fast. I've been caught in a downpour driving on slicks for more times than I care about, but so far there is nothing bad.
OMG a Helms cheerleader on this forum. I can still run with that 500ci LS. :fingersx:
I'm sure he has done 100mph in that boat. He willl hold that thing wide open longer than most. Want to see what that motor does in 400 feet with nitrous? It can eat a 300 and a 200 shot. I'm the tuner at WaterThunder, so I know a little about it. It was built to beat our unlimited motors and when it couldn't come close, James bought it. We changed some things to make it run well.
I pull the boat. No good pics together but if you look behind it you can kind of see the truck...Boat weighs about 5900 lbs and the truck pulls it well.post-136105-0-27169300-1441324581_thumb.jpg
  • 1 month later...
Shoot I'd be driving her to the track and leaving the trailer at home!
People always say that when someone tows their car to the track. My follow up question to that is what do you do if something on the car breaks? i.e. drive shaft, axle, rear end, etc. you would either have to call up a really good friend to bring your trailer out there or pay a tow truck to tow you back. However, if your out of town then you are really SOL.
For me I take my car to Royal Purple Raceway in Houston (Baytown) and it's about a 45 min drive from my house. It's just easier to tow it to the track. I have driven it there and back and man it sure is tempting to street race some of the cars out there. I broke once without a trailer, it took about 3 hours to get back to the track to load it on the trailer, and once on the trailer the track was about to close.
Personally I get too much joy out of driving performance cars on the street to car whether or not a part breaks at the track. If it does then I'd get a ride home to pick up the truck and trailer. Hell half the fun is driving to the track with your buddies on the highway.
I'll be towing the track the first few times until I have my fresh build ironed out and then I'll drive it. Track is just 45 minutes so it will take some time, but screw it.
Sent from my SM-N920V using Tapatalk
I scaled at 15660#
Wdh? Might help with the sag
Sent from my LGLS990 using Tapatalk
I have airbags. They weren't aired up. It would sag less then a similar truck with a wdh. Just pulled that trailer from Salt Lake city UT to Nashville TN then to Indianapolis IN over 3 days and it pulled great. Oh I also have an anti sway kit on the trailer/ hitch. 7995a1ba021023c8a9607312bca50dc0.jpg
Finally towed the big Z home. Best guestimate is around 8K loaded (6858 empty). Running Equalizer 12K WD hitch.
    ChristopherDobson
    ChristopherDobson
  • Who's Online   3 Members, 0 Anonymous, 1,255 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
