What are you towing with your 2014?
  • Replies 458
I've got some decisions to make. 2014, 5.3, 3.42. In the past, I've pulled 24 foot enclosed race trailers, no problems at all. Crosswinds aren't fun... but other than that, no issues. Of course I use a WD hitch.
I am considering buying a 28' race trailer w/living quarters... empty weight about 6,000, and I'll probably be about 8500k loaded. My concern is this: the trailer is 7'4" tall inside... from road to top, it is 9' 8" tall.
I do need the extra height for what I'm towing... but I'm pretty worried about the wind resistance with this tall of a trailer and the 5.3l. Any experience?
My travel trailer is about that height and weighs almost 11k loaded. The hardest part is the tongue weight. Mine is about 12.7%
Sent from my LGLS990 using Tapatalk
So happy. Hitched up my 21 foot trailer to my new truck this afternoon. I was a bit concerned that we were going to need a different hitch since the hitch sits 2 inches higher on my new truck. Not even going to be an issue, was almost dead level. Was thinking that we were going to need tow mirrors. No need for tow mirrors, the trailer is only a few inches wider than the truck is, so again no issues. Can't wait to take it up to the campground for 4th of July week.
My latest boat. Still not happy with how it tows, but its a big parachute.
towed the trailer last week to get some new tires
Here is my rig hooked up to a 26' Jayco expandable camper. Got some rear sag, but overall it pulled rather decent.
Just picked up my new travel trailer tonight. Dry it is 6600lbs. 33'5" long from hitch to bumper. When I picked it up they had filled the freshwater tank so it was over 7k. Towed it about 60 miles through the green mountains of VT. Truck handled it great! No sway and did not struggle at all, even in pretty decent wind. Truck has 3.42's. Luv this truck!
2014 MB Sports B52 23'.
Handles the boat well? 5.3 or 6.2?
I'm looking at buying a wake boat in the future and don't really wanna have to buy a different truck.
Ha I am pulling a 10k 30ft Formula with a 5.3 u will be fine
It's does good yes. 5.3 with 3.42 gear. The boat dry is 4200lb. Add trailer, 65 gal of gas, all wake/lake gear camping gear for the weekend, and finally all 5 of my family it's does sag in the rear a little ;) No idea what the weight was but it was heavy. After a weekend in the Ozark Mountains with all the above on a 4 hour tow I decided to add a set of helper springs. Other than that I have no issues. It will hold speed up a pretty steep hill, stops and turns very stable, and I get 10.5 mpg with all tires on the truck and trailer at 50psi.
Picked this up for service this morning! Made her squat a lil[emoji6]
Sent from my DROID RAZR HD using Tapatalk
That's not the trucks fault, that trailer isn't setup right, had a 34 Edgewater on mine today, it walked it
Boat was sitting in a storage unit and I just picked it up. I would have had it about 4 ft or so back
    AidenVorpagel
    AidenVorpagel
  • Who's Online   3 Members, 0 Anonymous, 1,260 Guests (See full list)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
