BAD paint chips Sierra All Terrain
The front bumper is steel on an All Terrain. The upper piece between the bumper and the body/grill is a plastic piece.
  • Replies 40
Shouldn't they rename that edition "All Paint Chips"?
Honestly, you would think GM has enough expertise to know that steel bumpers must be coated with better thicker paint or gravel guarded to resist chipping.
They had to repaint mine also, tons of paint chips on the front bumper after less than. 4,000 miles. The dealer did it out of good faith but looked at me like it was me . I said if it was my driving then why less than a half inch above the bumper not a single mark? They agreed to do it after that. It's not normal to have 60+ chips and only 4k miles
  • 2 months later...
I found a chip in the paint of my All Terrain bumper today. It's a spot about the size of a dime. the paint is still attached, but I could easily peel it right off. Might be having a work with my dealer about getting it fixed.
Was curious if it would be covered under warranty? Not even 10k miles yet. (9355 miles as of today).
Clear bra is a must on a painted front end
10.4
I had the entire front end wrapped with Xpel Ultimate a week ago on my black AT. Very hopeful that it will preserve the look of the front end for years to come.
How much $$$?
My dealer said they wont cover the paint chips on the bumper so Im gonna have it done myself. But I'd like to get some added protection while I am at it.
I have a question. You guys put the clear bra in the bumper only?
I have a GMT900 with painted bumpers but it's the same thing.. I got the steel part of the bumper done and the hood... No reason to cover plastic as it dosent chip.
How much $$$?
From my understanding all xpel dealers have different pricing... I got the bumper and hood done for about 260. Got a quote for the same thing I got done at another xpel dealer in a different town for 850.
Wow that's a pretty big discrepancy. I guess I'll have to do my due diligence.
Sent from my iPhone.
The Xpel guy in my area wanted $850 ... no side mirrors or fender.. just everything in the front. Screw them..They can pound sand.
If you don't want paint chips... don't tailgate others... that simple.
1 year and 11K miles... I have one small chip that I touched up. And.. I drive 80% highway travel with my truck.
Not a bad enough issue for me.. just stay 5 or 6 car lengths back. Definitely shouldn't be an issue for you guys just cruising around the city.
From what I have seen, it does in fact increase the odds of rock chips when tailgating but it's still inevitable to get hit by them.. Rocks and debris travels far when flung up, also even if you pass someone who is in the right lane you can still be hit by rocks. I tried to avoid chips by staying away from everyone... It's worth paying the money to not have to worry about it IMO
I'm gonna post a pic of my chip later on. I hardly go on the highway. most of my driving is around town.
How much $$$?
It was $1050 to cover everything to the front doors including the entire hood. It was a bit of a premium but I decided that I didn't want the line across the hood and on the front quarter panels. They were able to wrap at all of the edges so the look is very clean and should have a better chance of not peeling up in the future. If you look closely you can see it at the corners where they had to cut small reliefs.
    • Most thermostatically controlled ATF systems use a 'wax' pill just like the one in your water thermostat. They work on the expansion volume of the wax and the pill is constructed in such a way as to limit the travel to remain within that range. This means it has an opening temperature often called the 'cracking temperature' and a fully open temperature. For whatever reason oil is designated by it's fully open temperature and water by it's cracking temperature.    Between the two it the "Regulating Temperature" The entire range is about 20 F from closed to open. In your example the lower limit, opening point of 145 F then has a fully open temp of 165 F and a throttling temperature of 155 F.    Thing is, the throttling temperature needs two things to work properly. Enough system load high enough to reach the minimum and a heat sink (cooler/exchanger) large enough to prevent any load applied from exceeding the fully open temperature.    If your system exceeds the fully open temperature it is screaming MORE COOLER.    Here is the silly part of the whole thermostat system where the oil is cooled/heated by the radiator. Nothing is flowing to that system until the oil temperature reaches the cracking temperature unless it is equipped with a minimum flow bypass orifice or a bypass built into the seating surface of the plunger. That system meant to get it up to temp quicker isn't doing a thing until WORK drives if from ambient to cracking temp. One a cold winter day, like zero F, it may never get hotter than about 110 F. Sometimes not even that.    People forget or are young enough to not know that until this millennia transmissions were cooled by the radiator cold tank alone and without a thermostat at all.  In the 50's they weren't even cooled. OEMs learn everything the hard way.    When an OEM tells you the trans "Works best" between 175 F and 220 F it means works best for THEM. The transmission thermostat is fuel play. If you watch you trans temps like I do you will learn that it may take a hundred miles if you are not towing and not driving more than say 55-60 mph on a zero F day to even reach 120 F and it might sit there all day if it's colder. Yet if functions perfectly over about 100 F. It may need to get a bit warmer for the fuel and spark maps to go without an multiplier.    Worry more about too hot. Use a cooler large enough to put that thermostat in range.
    • Around 2008 if memory serves they took sulfur out. That was when diesel went up.
    • Question for you Grumpy, why is diesel so much more than gasoline? Seems to me that it may be slightly a little less refined than gas and it doesn't have 10% alcohol which presumably lowers the price of gas
    • Thanks, so being a different beast altogether, anyone know what the "optimal" temp is for the 10L80/90 for proper shifting?
    • How many years have I pointed out every point in that link to the folks here and been avalanched with criticisms and outright hostilities at times? I ran counter to even the great CUSTOMBOSS and Lake Speed Jr and the half dozen experts on YouTube and in the final.....GM, Physics (Stribeck) backs that Grumpy old Bear.    Honestly, I never said a thing engineering hadn't studied silly and laid in concrete during WWII. But I'm old, the information is old and yet, the Laws of Physics are eternal.    Okay there is one exception. I vehemently disagree with their use of the word 'tolerances' when what it meant is "clearance".   The clearance is the distance between two objects. The tolerance is the degree of acceptable variation permitted in that clearance. I.E., piston to bore clearance is 0.004" with a tolerance of +/- .0002" so the clearance is in specification if it lies between 0.0038" and 0.0042". Cutting that 'tolerance in half has ZERO impact on lubrication requirements. Makes for more difficulty in manufacturing.  But a tighter clearance 'MAY'. Depends on finish. Anyway....   It's one of those statements made by people to make themselves look smarter than they are to convince people who are as un-enlighten as they seem to manipulate their behaviors. But hey, the blind leading the blind puts them both in the pit.
