Went with the +12 worx beast and Nitto trail grappler 275/70R18. Rough country 2.5in front and 2in rear. Wheel cut all the way I barely rub the mudflap. I think if I didn't have mudflaps it wouldn't touch.
26340F2D-165E-4F3F-AEF7-88D351218B72_zps
64AD9955-5132-4AAE-AC2C-104D93E016C6_zps
Are your tires 275s or 295s? They look a lot bigger then 33s but I guess the 275 trail is 33.6.
Edited by chewy22
Rough Country 3.5 inch suspension lift. Tires are 305/70/17 (33.8") Wheels are Dick Cepek 17x9 -12 offset. minor rubbing on inner fender when turned to full lock. Will post better pictures when the weather clears up. Just took a few quick ones after installing the lift and tires.
not to highjack your thread but does changing your rims and tires affect the TMPS?( tire monitor pressure system) im getting new wheels installed tomorrow, and It just dawned on me, that I might have issues. please advise as I cant sleep now. I love everyones setup. cant wait to post mine tomorrow night!
If you choose not to put sensors in your wheels, your computer will throw a code telling that TPMS needs to be serviced. If you put sensors in the new wheels, you will need to have them programmed or do it your self with a TPMS programmer. Available on Amazon or Ebay. (lots of websites have them)
3" front/1.5" rear
20x9 BMF Novakanes "0" backspace
305/55/20 Nitto Terra Grappler
3" front/1.5" rear
Looks sharp....what did you use to get that lift and was there any rubbing?
And if you have any pictures down the side could you share?
3" Maxxtrac leveling kit, with an extra 1.5 block in the rear. I'll try to take some pics tomorrow down the side of the truck. I have a slight rub, only when backing up. I plan on buying the Bilstein 2.5" full strut replacement and adding the Zone 1.5" body lift. I think the 3" is a lil much for the front end, and really don't want to have to replace ball joints at 30,000 miles
If you're going to do Maxtrac, I would suggest the 3" spindles and not the 3" spacers. That way the angles stay almost stock. However, the price difference is what keeps most people from doing this since the spindles are a few hundred dollars more.
I went 285/60/20 Dura Tracs on stock Denali wheels and 2.25" ready lift. Some minor rubbing. Also have 3" block in back to keep factory rake. Very happy with it
Is there anyone running a 295 70 r18 on the stock z71 wheels? I want to do this set up with a RC2.5" level but im afraid it will rub too much. Any opinions?
2.5" RC Leveling Kit and 275/65R20 Goodyear Duratracs. The tires rubbed just slightly on the fender liner, a couple zip ties solved that. Thx Mr. Drag Sledder for the tips.
How is the tire noise compared to stock?????
That is one of the sizes I am strongly considering in Toyo AT II's. In the leveling kit thread, http://www.gm-trucks.com/forums/topic/153363-2014-leveling-kits/page-39, those that have 275/70/18's with a 2.5" level, said there is a lot more room for a wider tire. I am also planning a 1.5" body lift as well when the time comes. But it sounds like it would work. Also, I am planning on running the stock Z71 wheels. The offset will be they key factor.
Slightly louder than stock. I don't mind it at all.
    LCH14
    LCH14
  • Who's Online   5 Members, 0 Anonymous, 1,068 Guests (See full list)
