2.5 level with method mesh wheels with toyo open country rt's. Love themfa5533a6b9668ca3eb35b7869d31db65.jpg6c1d0e089493f7c7da87dba6a4d66a36.jpg96b86bff94c065d99ff33b54e25ccc46.jpg0eabdf56bb738ba787e7cdab82b1d680.jpg
Looks great, what offset?
Sent from Tapatalk App - Samsung S6
Perfect set up![emoji106] 18s on 33x12.50s?
right on the money
-12 If I remember correctly
Figured it was probably a negative offset, as they poke out as much as mine do with the 1.5" spacer (which essentially has me at -12 as well). So, we're sitting in the same position, but you have a wider tire.
Any rub on the carpet or flaps at full lock in reverse?
Yeah just a little bit of rubbing at full lock. barely ever happens though or at least I've been careful enough to not do it haha :lol:
Right on, exactly the same for me. Thanks for the clarification. Just wanted to know for my next tires, if I decide to do 305/55/20, shouldn't get much worse.
Alright buys help me out i have a 2015 all terrain c03db15d6dc012866d4a01294a545555.jpg
Iv got the dealer installed 2.5inch level not sure brand it brought the back up an inch with the front.. I have factory tires and wheels and want some 20x9 with a 0 offset and im hoping to throw on some 275/65/20 bfg ko2 tires.. What's your guys thought will I have issues running that set up? And how much of a difference will my mpg be going from the 265/65/18 hwy tire witch actually gets amazing millage on my 5.3 to that set up.. That's for the help
Sent from my SM-G900W8 using Tapatalk
Lots of info in the wheel and tire thread, and level thread, to help you with this.
People say 275/65/20 won't rub with a level, but that is stock offset. Being you're pushed out an inch if you go with +0, you might rub a little on the felt liner, but you can pull that back some if you cut it.
it'll be minimal most likely though, if it rubs at all.
QUESTION,275-60-20 HANKOOK ATM RF10 TIRES WORK ON A STOCK 2015 GMC 1500 DENALI?
THX IN ADVANCE
Anyone running 18x9 - 12 offset with a 5.00 backspace? With a 285/65 ko2 tire
THX IN ADVANCE
A few people are running that size on a stock truck and say no problem.
Any thoughts on these wheels?
http://www.blackrhinowheels.com/truck-wheels-rims-Everest.php
https://www.google.com/search?q=black+rhino+everest&source=lnms&tbm=isch&sa=X&ved=0CAkQ_AUoA2oVChMImv6RwNLTxwIVRvI-Ch2xtgi4&biw=1920&bih=1031#imgrc=_
I'm thinking of a set in 20x9 to replace my factory 18's along with some Cooper A/T3's.
attachicon.giftruck-wheels-rims-black-rhino-everest-6-lug-both-matte-black-std-700.jpg
Those looks good, almost same design as the KMC 690. You dont have any chrome on the side, so they fit well.
I have looked through this entire thread and am still kind of torn.
I would like to stick with 305-55-20XL Nitto Terra Grappler G2 tires because they give me the size I am looking for without being 10ply becuase I do not need that heavy duty of a tire and the extra weight.
The wheels I want only come in +6 offset. I have been trying to look at +0 offset with the 305's to get a good idea of how far they stick out since it is relatively close.
I would like them to just barely stick out. I have a 2" level, but will add the extra spacer to make it 2.5" if need be. Ideally I would be at about a +14-+18 offset, but like I said, the wheels I prefer only come in +6.
Does anybody have a down the side shot or pics with this set up of a 0 offset with 305-55-20's or +18 with the same size tire?
Thanks in advance for your help!
    DWic
    DWic
  • Who's Online   4 Members, 0 Anonymous, 714 Guests (See full list)
