I been running 35 psi on my 305-55-20 falken wildpeak. Is that a good number to stay in? I seen people running 50+. What's the difference if I put 50+?
2014 Silverado 2WT CC Summit White 4.3L V6
DROPKICK Edition
IG: jorge_dropkick_rangel
Are they P305/55R20's or LT305/55R20's? Typically LT tires would have 40-50 psi, sometimes more when towing or hauling a lot weight. P tires are normally less than 40 psi.
Looks like Falken might only make an LT version in 305/55R20.I'd start at 40 and adjust it from there.
Yes they are LT. Might try putting them at 40 and see what it does.
DROPKICK Edition
Anybody know where you can buy GM rims? I really like the chrome Denali rims and some of the other AT rims.
Besides that, what are some other good sites for other brands?
DROPKICK Edition
I've got the exact same tires in that size on my truck. I usually have the PSI around 35-40 and anything more than that makes the ride super harsh in my opinion. Around town I like them at 35 and when I take a long road trip I'll pump them up to 40.
DROPKICK Edition
You should not run 50 psi on any size tire. 50 is Max psi (Blow up territory). If you are running at 35 psi cold, it will go up 2-3 psi, depending on how long you drive. With added weight you will go up another 2-3 psi. So the max you can put in your tires is 40psi. rule of thumbs for me is 10psi below max recommended.
Depends on whether the tires are P-metric or LT's. His are LT load range E's with a max inflation of 65 psi. You'd be correct if he had P305/55R20's.
You Sir are correct, my bad.
The new skins are on! BF Goodrich All Terrain KO2's. LT275/70/R18 with 2" level kit. Much better.... :)
Edited by fpdsniper
What is the actual size of that tire when mounted on the truck (true height, tread width, and section width)? Would like to see some low angle front and rear pics to see the full width of the tire if you could post them.
I have a 2015 Silverado and looking to put the Nitto G2s 305/55/20 on it. My question has to do with the tire pressure sensors and the vehicle diagnostics with OnStar. If I run around 10 lbs or pressure higher will it make any sort of tire light come in or show an error with OnStar diagnostics?
No you won't have an issue. I am running 42psi in my 35" tires and everything reports as normal.
Not the OP, but here you go:
Well, here's the low angle front, anyway:
Is a BFG KO A/T 285/65r20 to much for stock all terrain rims? Looks to be about 34"x11" so guessing I will have rubbing if stock height? Found a good deal on a set and hoping they will work
    Aries68
    Aries68
  • Who's Online   6 Members, 0 Anonymous, 340 Guests (See full list)
