Anyone seen the new cooper STT pro? New cooper mud tire. 1db louder than some all terrains which means they're incredibly quiet. Looks like a KM2 design with some conservation in the center tread. Cheap too 233$ for 285/70/17 and 260$ for 295/70/17.
c7147f023c94ebd12eda3a315a199f62.jpg6cbd459859d4f63f8731a44e0a91f057.jpgf0ca1bd8b2b825bc567bf4f3e30116ed.jpg
Yep i ordered some 20x9 fuel nutz pvd wheels and i was going to put these on in either a 305/55r20 or 295/60r20.
I'll be sticking to 17s but 295/70/17 is my preferred size, 33.5x12x17. They're white lettered. Though looking at that one in the store can't i just flip it around?
I've read these forums for a few months and decided to finally sign up. Lots of great info here. Anyways here's my setup.
2015 z71
20x9 Ultra Bolt Wheels
+18 offset
305/50/20 terra grapplers g2
Stock height (I have a 2" motofab level kit I just haven't installed it yet)
No rubbing
Edited by JagFan80
  • Like 3
I'm running 305/50/20 WITHOUT a level kit on stock suspension. I have a 2" level that I haven't put on yet and it doesn't rub at any point.
2015 z71
+18 offset
No rubbing
Go Jags...and stuff.
Edited by krzyd
2015 z71
+18 offset
No rubbing
Great looking truck. Welcome to GM-Trucks
Just installed 2.5" RC level and 275/65/20 Toyo Open Country AT II tires on stock 20" all terrains.
I do have rubbing on the carpet wheel liner on both sides but will fix that today.
Okay, I'll post pics next week, after much consideration, I'm going this route next week:
-Cooper Discoverer AT3, 275/60/R20
-Rancho 9000 in front
-Bilstein 5100 in back
Last chance to convince me otherwise
I like the look. That to me seems like the best size tire for a RCX 2.5".
2.5 level with method mesh wheels with toyo open country rt's. Love themfa5533a6b9668ca3eb35b7869d31db65.jpg6c1d0e089493f7c7da87dba6a4d66a36.jpg96b86bff94c065d99ff33b54e25ccc46.jpg0eabdf56bb738ba787e7cdab82b1d680.jpg
  • Like 7
Perfect set up![emoji106] 18s on 33x12.50s?
Edited by langston1726
