Hey Gents,
First post here; I've been lurking since February of 2015. Great info across the board, but this is my favorite thread. Not many regular cabs, so here you go...
20x9 -12 Rockstar II's on 305/50R20 Nitto Terra Grappler G2's.
Will be getting a BDS 2" level up front and 1" block in the rear next Wednesday.
Thanks for having me :)
6" BDS + 1.5" Zone BL. XD Series 820's 20x12, -44 offset on Toyo MT 3c236f3882bfe944797daabb3ae4c330.jpgfd6c3eef7ab478e298e2c5cacc6aec45.jpg2e31c8f465d9b007f85ee79c5f570fe6.jpg
I dig it
Badges already have been blacked along with bowties
Snow plow? The lower chrome strip? Ya I don't want to plastidip it ... I wish I could get rid of that chrome piece and replace it with a black one somehow.
But these things are so minimal that it doesn't bother me much.
That's the reason I went with this new Z71 was the massive "Lack" of chrome ... I DoNot like chrome on my truck so this was a good start. But after blacking out the badges and center bowties I'm more then happy with how it's turned out.
I've addded a 1" Readylift blocks in the back to level the truck out. Ore along with addi a set of Amp Research Powerstrps. Next will be a full LTZ center console swap then a stereo system. Then when we get a new trailer a set of rear airbags.
I am SO happy with how this truck has turned out!
Thanks everyone for all the nice replies.
And as far as the red ... I love red ... And ya this picture turned out a tinge reder then it really is with a iPhone enhancement thing. It's still damn red, the color is called "Red Hot" so it's suppose to be really red but it is a touch different in person then the pic.
This is virtually identical to what I'll have in 7 more weeks. Any more pics since the blackouts? LOVE it!
So love these wheels just don't know if they'll work on my truck. They look better than my expectation was for the photoshop. Thoughts?
Big shoutout to VTBulldog for the great work on the photoshop.
Edited by jrob56
Just got them installed 2 days ago. 275/65R20 Kanati Trail Hogs on oem Denali 20x8.5 all on a Fabtech 2.5 level.
Without reading through all 150 pages, does anybody know what is the biggest tire I can run on a 2.5 level with a -12 offset? I'm going to get some new tires this week and really leaning toward the Toyo AT2 or RT. I know I could run 33x12.5 RT, but not sure about 305/55 AT2. If 305 is too wide I'll go with 295/55. Any help on this would be appreciated!
does anyone have a 14' sierra z71 with a 6.5" zone lift on stock 20s....and what is the backspacing on stock 20s?
I had the slightest rub in reverse @ full lock coming out of my driveway with 285/65r18 at II on 18x9 -12 fuels with just a 2.5" front, your 20x10 -12 are going to stick out an additional 1/2" compared to my 18x9's. One guy on here said he has a slight rub in reverse with 305 55 20 ATII and 4.75" lift he was running 20x10 -24 offset. The RT's are 32.8"x12.5" while the 305 55 20 is 33.25"x12.4" and the 295 55 20 is 32.8"x12.2" maybe take a clearance measurement at full lock and compare those numbers with your existing tire measurements. What size tires are on your truck right now?
Stock 20's are +27 I believe. There is truck similar to what you're looking for I believe its a 7" RC with 35x12.50 firestone mt on factory wheels with 1.5" wheels spacers the truck is maroon. I think he posted a while back in this thread.
Edited by abominable z71
Thanks for that. If the 305's don't work, I would like to think the 295 should without any rubbing. I called my shop today and put an order in for the 305. Good thing is once they get them mounted I can drive it around the shop and make sure I don't have any rubbing issues. If so I'll switch to 295. I currently have stock 275/55 goodyears.
I have 305's on 20x9 0 offset and I rub with the level, not bad, and some plastic trimming would fix it. Yo will prob rub pretty good, but hope it works out for ya!
Post #42 and post #162 of this thread can shed some light on the subject.
Hnnnnnng. Do you have any pics of your setup? I appreciate that. I'd rather go to a smaller tire than have to hack up the front end.
Thank you sir. I'll look into those.
    • I have 2 choices.
