Here are mine:
2" RC level
20x9 OE wheels machined black. +31 offset
275/60/20 Falken Wild Peak AT
No Rubbing or trimming
Pretty much what I'm about to do.
Just found this site, way more info than i could have asked for in here.
I was going to try to fit the 275/60/20 AT3/Ws without a leveling kit, but I'm sold on running the leveling kit now.
Sent from my SM-G935P using Tapatalk
Is that just a 2" rc in the front ? Stock on the rear ?
275/65-20... +16 offset makes it fit puuuuurfectly
My truck is completely stock at this time. I am going to do a RC 2" and Falken 275/60/20 AT3/W tire
For whatever reason i can't find the 275/65/20 for sale on Discount Tire's site. See what they say when i stop in the store. Just gotta work this extra OT for a couple weeks first.
2016 Silverado
2 1/4" Front Level Only
OEM GMC All Terrain Rims, Plasti dipped black with Glossifier
Midnight Edition Center Caps
275/60/20 BF KO2's
Zero Rub, Perfect Fit
Out of curiosity, could you have run that tire without the leveling kit?
Those new falken at3's look sick
Not 100% sure but I wanna maybe? Have to spend hours searching on here
keep looking! I got mine on tire rack. Bfg ko2
I was looking to tone down the chrome on my denali and preferred to stick with an OEM wheel. I really liked the looks of the black 22" wheel but preferred a 20" wheel for several reasons. I ended up getting the 20x9 Black Rhino "Peak" wheel which looked very similar and was able to use my stock center caps. They are 20mm offset and I kept the 1/4" spacer plates on the front after changing the stock wheels but don't it was needed. The factory center caps are larger than the Black rhino's (+/- 3/8" larger) and don't sit in the recess but they snap in with a little extra force and are very snug. I was pleasantly surprised that they fit.
20160921 065451
20160921 065437
you can run 275/60/20 without a level
on stock wheels
Edited by tyrich88
RC 2.5inch with rear blocks is going on today, tires tomorrow. Gonna test fit the 275/65r20s and the 305/55r20 Ko2s. I've read that 275/65r20 will rub slightly but a little trim or pulling back fender liner will solve this, but worry that and change in driving conditions will shove the tire straight into the well. The 305/55r20 I've heard fits no problem. Just worried that it won't be a noticeable difference from stock tire.
Edited by 16_sierra
So I have looked through 30+ pages of this thread and I am still as undecided as ever as to which direction I'm going to go. I have a 2014 Denali 1500 with a RC 2.5" level kit and I'm wanting to go from stock wheels and rims to a 20x9 or 10 with a 33"-34" BF Goodrich AT tire. I am wanting to keep the setup as flush as possible with the aggressive look still. Would a 305 55 20 with a 20x9 stick out of the fender a huge amount and if not which offset would I need? I know a 276 60/65 20 is the popular size but I think it looks very tall and narrow from what I've seen.
you need an offset as close to factory as possible to sit nice and flush. Here's a pick of my old truck with 305/55r20's on factory wheelsf906ab8fc81240a3a68ec704452e7c9d.jpg
  • Like 4
I assume that the 275/65 could run depending on your offset or if the tires run large (I have bfg ko2). I still have zero signs of rubbing after 2500 miles.
    DM22
    DM22
  • Who's Online   3 Members, 0 Anonymous, 1,554 Guests (See full list)
    • Did have to make 1 modification because of the WeatherTech rear mud flaps and that was needing 3 longer screws than what came with the install package. 😄
    • Picked up the liners yesterday. Installed passenger side WITHOUT any modifications. All mounting holes lined up perfectly. Rain is interfering today with drivers side. Very Happy! Will add pics when finished
    • That is a fair point, and I agree that trying to log “everything in the truck” would be the wrong direction.   There are a lot of modules and a lot of traffic. If the product became a full-truck datalogger, the amount of data would get huge very quickly, and most owners would never use it.   I think the first useful version would need to be narrow: - powertrain-side event evidence - selected high-value parameters - communication / voltage / reset events - pre/post event window - short report first, raw log only as backup   One distinction I should make is between active OBD/PID polling and passive bus capture. If you are polling PIDs through OBD, then yes: the more parameters you request, the lower the effective sample rate becomes, and you are adding diagnostic traffic to a vehicle that is already busy running itself. With passive CAN capture, the recorder is not asking all the modules for data. It is listening to traffic that is already on the bus. So it does not consume vehicle bus bandwidth in the same way that a scan tool polling hundreds of PIDs would. But your point still applies in a different way.   Even if passive capture does not add bus traffic, the recorder still has limits: - processing rate - storage rate - timestamp accuracy - decoder workload - event filtering - report size - user attention span   So the answer cannot be “log everything and let the user figure it out.” The product would need to store enough raw evidence to be useful, but only decode, graph, and present the important parts around the event.   A practical report should probably show: - what triggered the capture - how much pre/post data was preserved - which selected parameters changed - how those values compared to baseline - whether the same pattern happened before - whether any voltage, reset, bus-off, lost-message, or communication fault occurred - selected graphs around the event - raw data only as supporting evidence   So I agree with you. More data is not automatically better. The real product is the reduction from raw data into a useful event report.
    • That makes sense, and I agree with most of that.   I think the product would need both: 1. a default powertrain template, so it is useful out of the box; 2. user-selected priority parameters, so the owner or shop can choose what they want to see first.   Different users are going to care about different things. One owner may care about oil pressure and voltage. Another may care about misfire trend, AFM/DFM behavior, or U-codes. A shop may want communication events and repeatability first. Your baseline point is probably the most important one. Raw data is not very useful unless the report can show what normal looked like for that vehicle under similar conditions.   The way I would think about it is: - start with a basic known-good baseline - learn normal behavior for that specific vehicle over time - allow the event to be overlaid against baseline - show whether the event was a one-time spike or a repeatable pattern - provide a simple severity level, but with clear limits on what that severity means   For example, early severity could be something like: - Info: event captured, no obvious abnormal pattern - Watch: value moved outside baseline, but not repeated - Warning: repeatable abnormal pattern under similar conditions - Critical: communication loss, voltage drop, bus-off, reset, or severe repeated event   I would not want the first version to say “replace this part.” That would be overclaiming unless there is repair-confirmed data behind it. It would be more honest to say “this pattern deserves inspection.”   On the OBD port question, I think OBD absolutely has a role. OBD is probably the right place for: - DTCs - freeze frame - VIN - calibration information - normal scan-tool parameters - Mode 6 / enhanced diagnostic data if available The reason I am still looking at an ECM-side recorder is that the failure may happen before anyone connects a scan tool. If the owner plugs in a scanner after the event, the pre-event evidence may already be gone unless the ECU happened to save it. So I do not see this as “OBD versus ECM-side.” I see it more like: - ECM-side recorder: always armed, rolling buffer, event evidence - OBD/DLC companion: DTCs, freeze frame, VIN, calibration, normal scan data - phone/cloud: status, notes, upload, report generation, notifications   I agree that phone connection and push notifications would be useful. I just would not want the phone or cloud connection to be required for capture. The recorder should save the event locally even if the phone is not connected. The phone should help with event marking, download, notes, upload, alerts, and report viewing.   For a default GM V8 event report, would this list make sense? - RPM - calculated load / MAP - throttle position - vehicle speed - gear / torque converter state if available - coolant temperature - oil pressure - oil temperature if available - battery voltage - commanded AFM/DFM state if available - actual AFM/DFM state if available - misfire counters / roughness by cylinder if available - fuel trims - relevant U-codes / communication events - bus-off / lost periodic message / module reset / voltage drop events Which of those would you remove, and what would you add?
