just had my new 275/65R20 Mastercraft tires mounted on my factory rims, they rub a little at full turn.  hopefully when I get the adjustable bilsteins put on, that will eliminate the rubbing
Edited by schmolf4
Looks great! Love the white letters. MasterCraft tires seem to be decent quality. ( Think it's a Cooper company) plus they have a nice square contact patch instead of bulging sidewalls and a narrow tread.
yes, they roll off the same line as the cooper discoverer tires as well as the Hercules brand tires...plus the mastercrafts were only $200 each compared to the coopers at $260-280.  I got the E load tires as I tow a 6500lb travel travel and these should eliminate some of the side to side flex.
2 hours ago, kevin77rogers said:
Here’s mine 2018, 2” RC level, 1 1/2 spacers with 285/65/18 cooper stt pro.81d55df552b00426dfb97c7a7ff17f71.jpg
Looks great! Did you have to trim your wheels studs with the 1.5" spacers?
12 minutes ago, kevin77rogers said:
No the wheels have cut outs on the back for the studs to go in.
Nice. I've had two sets of Stock 20's and 1 set of 18" that didn't have enough room in the pockets ( recessed areas in the wheel) to clear the studs. Go figure I found the ones that wouldn't work lol.
2" RC level, 295/70/17 nitto Terra grappler G2. Little bit of rubbing on the plastic and felt liner in the back, but don't have trim any metal!
305/55/20 Toyo OC AT2s on stock 20s with 2in RC level. A little rubbing on the fender lining but I just got spacers so that should help!
Edited by PotvinSucks
I've got a 2017 Silverado 1500 Double Cab and i'm looking to put on Fuel D576 Assault Wheels, 20x10 with a -18 offset. The tires will be Toyo Open Country R/T (good blend between A/T and M/T) 35X12.50R20LT.
I'm wondering a few things here that i'm hoping you guys can help me out with.
  1. Am I shooting for tires too big? Should i go with the 33's instead?
  2. For the 35's, or 33's if im shooting too high, whats the ideal lift i should get?
  3. Once #1 and #2 are taken care of, what do i need to worry about? Will it rub anywhere? do i need a steering stabilizer?
I'm sparkling brand new to wheels and tires so i know very little. I was originally going to get a $125 lift and level kit from MotoFab (3" front 2" back) but now i'm looking more towards the $1000 range.
Any help will be greatly appreciated!
Edited by PMad
Well bro if your dead set on 35's then you looking at nothing short of a 6 inch lift. If you decide on the 33's you'll rub with a -18 offset. Nothing a 2 1/2 lvl and some minor trimming wouldn't fix.
Sent from my SAMSUNG-SM-G935A using Tapatalk
Thanks Frank!
I've been doing more research and it seems like a 6" lift might be more trouble than its worth, mostly because i have a boat i tow often every summer. I'm finding i'd need to do something with the gears and axles or something, thats all brand new territory for me.
I originally started down this road when i wanted to level the truck because it wasnt super expensive, but then i found a motofab 3" lift in the front with a 2" lift in the back for the same price as the level i was going to get, but found that was maxing out the upper control arms and started looking at a 3-4 inch lift, but found 6" lifts were a little more, but need steering stabilizers and leafs and all sorts of other stuff.
So now i'm thinking a 3-4 inch lift. Will i have the same issues with this as i would a 6" lift?
And back to wheels and tires, anyone using 20x9 or 20x10 Fuel Assaults on a 2017 Silverado 1500? Which one, which offset, and how far do they stick out passed the fender? Are spacers needed? Which tires are you running?
    250.6k
    President Roberto
    President Roberto
  • Who's Online   4 Members, 1 Anonymous, 613 Guests (See full list)
