Side pics of the whole truck if ya got em
Sent from my SM-G928V using Tapatalk
I think there's a pic in my gallery directly from the side before the 1-1/2" body lift was installed.
Nice!! I like it!! Thank you!
What kind of mileage are you getting now?
I get around 18mpg on Premium and about 13mpg on e85.
I agree, that looks great. That is just a level and then a 1.5" body lift?
I could live with that.
I'm getting 19 on my stock setup. I'm really happy about it and don't want to kill it.
Sent from my XT1254 using Tapatalk
I got closer to 20 before the level and tires. So I would expect a 1-2mpg drop as a ballpark number.
Good information, thanks!
Have you seen any specks on the Grappler's yet? I couldn't find any weight information.
I haven't seen anything and I don't think Nitto publishes weights on their site making it a little difficult to track down, I'm thinking they are going to be real similar to the exo grapplers as far as weight goes.
Not that anyone cares. I went with bfg because of the lack of reviews with Nitto and Toyo tires.
From the looks of it, it'll probably be heavier than I hoped for but that's the one that's caught my eye for now.
I like BFG KOs also but don't see them in the size I want 33*12.5*20.
305/55-20?
I went with 275/65-20 which is 34x10.5 seems to be a great tire
305/55-20?
305x55x20 is the closest they have to 33*12.50 but I recently did a test fitting and the 305s rubbed a little. I agree they seem to be a great tire from feedback and reviews I've read.
Did all of your mods help at all with mpg?
Also if you test fit any 305s on those 17s I would be interested to see how they fit as i've been eye balling some 17" methods and 305s would be awesome.
I took my truck in for a fitting. I tried a 305/55/20 Nitto mud tire on Fuel nutz 20x9 +1 offset.
The rim and wheel isn't my 1st choice but I wanted to see what fits and that's what my tire dealer had to play with.
I'm running a RC 2" level up front, stock rear. I rubbed the liner at full lock. I could zip tie it back and it might work or I'm thinking about running a 33x12.50 tire. I think it's slightly smaller than the 305s.
No matter what I decide it will totally transform the look of the truck.
My 1st choice setup is Nitto Ridge Grappler and Fuel Maverick 20x9 +1.
I just need to be patient until the Grappler's are released.
I am running those same wheels in a 20x10 -24 with a 33x12.50. There is a slight rub at full lock in reverse. Other than that, no issues at all. Even when I hit the trails a couple of weeks ago during camping, no issues at all. I will probably zip tie the liners back so there is zero rub.
61769-4-2015-silverado-1500-chevrolet-le
61769-6-2015-silverado-1500-chevrolet-le
61769-7-2015-silverado-1500-chevrolet-le
61769-11-2015-silverado-1500-chevrolet-l
  • Like 3
