That would explain it. Bench seat here.
My bench seat has an sd next to usb under the center console/armrest/backrest.
No SD in 2016 LT Crew Cab with bench seat.
The SD slots are in 2015 HD's w/bench & fold down console, along with 2-USB's, & aux cable plug in socket. Can't see why GM would change that in the '16's...
I still have a complete Kicker VSS set for sale for a '14+ Double cab. Sub and amps. All wiring included. Message me if interested.
Part #19303115
For those of you who have replaced the front and/or rear speakers in your truck, did you find a gm speaker harness for the connections, or did you have to cut the wires and either splice or solder the new speaker wires? I'm contemplating adding aftermarket speakers, but I don't see any metra or other companies making harnesses for newer gm trucks, and I'd rather not have to solder speaker wires in case I put the old speakers back in if I decide to get a new truck within a few years.
Any info. on speaker harnesses (model/part number, etc,) would be appreciated. Thanks.
This is what I used based on Alexantics' recommendations.
Chevy Silverado Truck 2014-2015 Factory Speaker Replacement Connector Harness
https://www.amazon.com/dp/B00W5SG8XI/ref=cm_sw_r_cp_api_j8o0xbTMKH5GC
I had an issue with fitment at first, but with a little wiggling, was able to force the connector in. I have a 2016, so not sure if the mate end was designed slightly different. Installed the Kicker 6x9 with a speaker adapter as well.
You can see the guide notch on each rounded corner. That's what I fought trying to get it to fit. It ultimately mated.
These are the front speaker adapters I also went with.
New Kicker 41KSC6934 6x9" 3-Way 300 Watt Car Audio Coaxial Speakers KSC693
https://www.amazon.com/dp/B00JST5I7Y/ref=cm_sw_r_cp_api_vbp0xbXKGK76H
And the front Kicker Speakers
Scosche SAGMHR634B 2006-Up Chevrolet HHR/Impala Speaker Adapter for 6+-Inch or 6+-Inch
https://www.amazon.com/dp/B0015A8Q7S/ref=cm_sw_r_cp_api_tap0xbF65W9TT
I will be installing the rears tomorrow.
Metra 82-3004 2014 6X9" Speaker Adapter for Select GM Trucks
https://www.amazon.com/dp/B00IIC1CSQ/ref=cm_sw_r_cp_api_ucp0xb1KFSRP3
And Rear Speakers
Kicker 41KSC674 6-3/4" 2-Way Coaxial Speaker - Pair (Black)
https://www.amazon.com/dp/B00JST5H52/ref=cm_sw_r_cp_api_0dp0xb9T1PFD0
Edited by pgamboa
Here are some photos of the rear speakers installed with the speaker adapter ring and wire harness. No splicing needed.
This completes the Kicker upgrade (with the exception of dash speakers). Sounds Great!
There are tabs on the ring that need to be removed and were easily done with a pair of pliers. They are etched for easy removal.
So in your opinion changing the speakers is worthwhile? Did you lose any volume(sometimes you do when changing to 4 ohm speaker) and did you disconnect the dash speakers. I have heard the dash speakers don't blend well when changing the door speakers
I am by no means an audiophile. The front and rear speakers do bring out the mids and highs in my opinion. Installation was easy, & plug and play. Sounds is louder all the way around and hits. I LOVE bass and this was a nice plug and play add on. I'm sure a custom system would have been louder and cheaper, but wanted a system that was plug and play, and doesn't void warranty.
Edited by pgamboa
I agree, I love the upgrade of the both front and rear speakers. No volume loss at all, I have no db level proof but to me it actually is louder and clearer. I just picked up the factory Bose dash speakers and will try adding those with the kicker speakers to see how it sounds. Pgamboa and I both had non Bose stereos and added the complete kicker Vss sub and amp upgrade. I do not recommend upgrading the door speakers with out the additional amp. I do not think the factory head unit would provide enough power.
I already have they kicker sounds take full system... just wanted a little more volume and clarity if upgrading the speakers helps I will pull the trigger. Just wanted to know if replacing the stocks was worth it .
I dropped son off to church today. One the way, all windows rolled down, sound turned all the way up, it is loud and really happy with the clarity on the mids/highs with the new front/rear speakers.
Edited by pgamboa
anyone '14-'16 Silverado/Seirra DOUBLE CAB ONLY Looking for the complete Kicker VSS kit with both sub and digital signal processor? part # 19303115
I have one for sale. Complete with everything. Great sounding addition. Bought a crew cab and just added the Kicker VSS for crew cab. LOVE IT! Ready to ship professionally with insurance and tracking.
Asking $475 including shipping...You will not find a better deal here.
    B07
    B07
  • Who's Online   2 Members, 0 Anonymous, 701 Guests (See full list)
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
    • Looking for this part for my truck. They don't sell just that one piece and to get it you have to pay over $100 even used for the whole air tube. The piece the hose clamp snaps into that is held on by the screw and nut. If anyone has access to one please let me know.
