So no one gets confused, if purchased new, the plug is not attached to the power cable that is fed through the firewall. It is also noted in the instructions to be attached after the cable has been passed through the firewall grommet. Other than that, it would of helped if they would of added at least 6" of extra wiring in the harness.
Can someone email me or post a picture of how the crew cab model bolts down? The instructions I have are for a extended cab (probably added to my install difficulties) .
Does anyone know if you can up the front amp separately? I bought a used kit from a guy on the forum that was supposed to be the kit with the sub and amp for the speakers (19303117), but I received it and it is the kit with just the sub (19303118). I'll probably send it back if I can't get the front amp separately.
Thanks
Scott
Thanks
Scott
I knew that was going to bed the case with that post.
I don't know if you can get it seperate, but if you can your price from kicker is pretty high.
Probably better off buying one as a complete kit.
Sent from Tapatalk App - Samsung S6
Are folks still having poor sound issues when playing music via bluetooth? Like from an iPhone with iTunes music downloads or Pandora streaming from their phone app rather than the radio app?
I recall reading some saying the sound quality was pretty bad when streaming from their phones.
Edited by Black Hole
Thanks
Scott
Hey Scott, I'd be interested in buying sub only from you. How much shipped to MT??
I have not experienced any poor sound issues playing through Bluetooth with a android. I don't know about iPhones though.
This is a head unit and Bluetooth issue with the factory GM stereo and has nothing to do with the Kicker Soundgate sub. I have not personally heard a difference from streaming Pandora using or iTunes via Bluetooth. There is however a huge difference between streaming Bluetooth and play music via USB or a CD.
With your stereo stock do a little test for yourself.
Play a song via CD Or USB at the loudest volume you think it sounds good. Write down what level the head unit is at. If you have a decible tester go ahead and test how many db's it is at as well & write that down.
Then stream the same exact same song via Bluetooth & the loudest volume it sounds good on the head unit. *make sure you turn up your volume from Bluetooth piece Aka phone.* Write down what level the head unit is at. If you have a decible tester go ahead and test how many db's it is at as well & write that down.
You will notice very quickly that streaming Bluetooth requires the head unit master volume to be 20% to 30% high compared to CD or USB and it will not get as loud!
So if your driving down the road playing a song on Bluetooth you may have your volume on the head unit at 17 and still fill it is not loud enough.
Playing the same song via CD or USB with the volume on the head unit at 10 & it's already loud!
The sound quality and volume is much higher playing music via CD or USB. That's just common sense though. Of course there will be a loss of audio quality. The songs from a iPhone if from iTunes will always be less quality because they compress the files so you can fit more music on it. Then you factor in the audio quality loss from streaming.
This loss in volume streaming Bluetooth is much more obvious when doing this test driving down the road with some windows down. Doing the test this way you will quickly see the difference in volume and and audio quality. You almost can not hear the stereo at full volume with the windows down streaming Bluetooth.
Hope that helps!
Edited by Alexantics
Hope that helps!
I understand completely. Thanks very much. Appreciate it! :thumbs:
Set the Fade to +1 to the rear speakers. It helps balance them out.
This is exactly where I have found the sweet spot too.
I am still playing with the Bass (+1), Treble (+3), Mid settings (+2), to find a good setting.
Has anyone with a regular cab tried this? I contacted Kicker about getting everything except the harness but they don't offer anything for the regular cab
  • 3 weeks later...
Anyone done the upgrade with the 2016 I0B radio? Kicker lists the sub and amp kit as not compatible with I0B / IOB.... I guess I0B has an amp with the new 7 inch screen.
Edited by GS340
    whenindoubtuseahammer
  • Who's Online   3 Members, 0 Anonymous, 320 Guests (See full list)
    • Enjoy the new truck, it’s a beauty. I’m glad you’re keeping the OBS, I love those old trucks.
    • With large equipment or deep mud it is more of a use the higher gear to avoid spinning tires, getting stuck because of spinning tires and doing damage to your machine. The idea is if you run out of torque before you spin tires you can still downshift for more torque. If you are just spinning your tires in the lowest available gear you are stuck and things break.   Automatic transmissions, traction control and electronic transfer cases change the calculation a little as you the driver have less control over each piece.
    • are there any codes? with lots of rust, perhaps disconnect/clean both sides of the connection/examine cable ends (the wires) for corrosion going into the sheath & replace if necessary/reconnect ALL the power AND ground cables between the battery, engine, frame, cab, fuse box and starter charm.li (website) has a no-start diagnostic procedure you can work through to get it working.
    • Its no wonder you've gravitated to the oil types and brands you have in later years after trying certain brands and one being a specialty oil or at least very hard to come by up here and the other would have been a commonly found oil of the era and the vastly different outcomes as a result to using the vehicles in question the same distance for an OCI . It shows what marketing hype can do without actually having the product to back up the claims and that is no different now with the insane claims that are written on the side of a bottle of oil from some of the off the shelf oils.    What has surprised me and I was already finding this out before I bought my truck with the GDI engine, that this newer fancy technology that seemingly would suggest better fuel economy/emissions with this high pressure spray of fuel is not in reality kind at all to the engine or at least the oils life. Yet they insist on claiming long OCI with this technology just like they did with the port or similar type fuel injection systems when in reality its a step back in oil life to have a GDI system.    I think the mistake your making Grumpy is that your not sending your samples to Blackstone and getting the feel good glowing report that you can run it another 1000 or more miles and then send another sample where they say run it yet another 1000 miles and on and on it goes until your sending in something that looks a lot like road tar and then they may suggest you change your oil within the next 1000 miles 😆
    • I am guessing that engines of that design back then had a better ability to be abused and survive longer than a new design engine with the long timing chain and the overhead cams and phasers etc. But I would never guess that an engine could go that far and not fail spectacularly or at least die a slow death.
