That would explain it. Bench seat here.
My bench seat has an sd next to usb under the center console/armrest/backrest.
No SD in 2016 LT Crew Cab with bench seat.
The SD slots are in 2015 HD's w/bench & fold down console, along with 2-USB's, & aux cable plug in socket. Can't see why GM would change that in the '16's...
I still have a complete Kicker VSS set for sale for a '14+ Double cab. Sub and amps. All wiring included. Message me if interested.
Part #19303115
  • 1 month later...
For those of you who have replaced the front and/or rear speakers in your truck, did you find a gm speaker harness for the connections, or did you have to cut the wires and either splice or solder the new speaker wires? I'm contemplating adding aftermarket speakers, but I don't see any metra or other companies making harnesses for newer gm trucks, and I'd rather not have to solder speaker wires in case I put the old speakers back in if I decide to get a new truck within a few years.
Any info. on speaker harnesses (model/part number, etc,) would be appreciated. Thanks.
This is what I used based on Alexantics' recommendations.
Chevy Silverado Truck 2014-2015 Factory Speaker Replacement Connector Harness
https://www.amazon.com/dp/B00W5SG8XI/ref=cm_sw_r_cp_api_j8o0xbTMKH5GC
I had an issue with fitment at first, but with a little wiggling, was able to force the connector in. I have a 2016, so not sure if the mate end was designed slightly different. Installed the Kicker 6x9 with a speaker adapter as well.
You can see the guide notch on each rounded corner. That's what I fought trying to get it to fit. It ultimately mated.
These are the front speaker adapters I also went with.
New Kicker 41KSC6934 6x9" 3-Way 300 Watt Car Audio Coaxial Speakers KSC693
https://www.amazon.com/dp/B00JST5I7Y/ref=cm_sw_r_cp_api_vbp0xbXKGK76H
And the front Kicker Speakers
Scosche SAGMHR634B 2006-Up Chevrolet HHR/Impala Speaker Adapter for 6+-Inch or 6+-Inch
https://www.amazon.com/dp/B0015A8Q7S/ref=cm_sw_r_cp_api_tap0xbF65W9TT
I will be installing the rears tomorrow.
Metra 82-3004 2014 6X9" Speaker Adapter for Select GM Trucks
https://www.amazon.com/dp/B00IIC1CSQ/ref=cm_sw_r_cp_api_ucp0xb1KFSRP3
And Rear Speakers
Kicker 41KSC674 6-3/4" 2-Way Coaxial Speaker - Pair (Black)
https://www.amazon.com/dp/B00JST5H52/ref=cm_sw_r_cp_api_0dp0xb9T1PFD0
Edited by pgamboa
Here are some photos of the rear speakers installed with the speaker adapter ring and wire harness. No splicing needed.
This completes the Kicker upgrade (with the exception of dash speakers). Sounds Great!
There are tabs on the ring that need to be removed and were easily done with a pair of pliers. They are etched for easy removal.
So in your opinion changing the speakers is worthwhile? Did you lose any volume(sometimes you do when changing to 4 ohm speaker) and did you disconnect the dash speakers. I have heard the dash speakers don't blend well when changing the door speakers
I am by no means an audiophile. The front and rear speakers do bring out the mids and highs in my opinion. Installation was easy, & plug and play. Sounds is louder all the way around and hits. I LOVE bass and this was a nice plug and play add on. I'm sure a custom system would have been louder and cheaper, but wanted a system that was plug and play, and doesn't void warranty.
Edited by pgamboa
I agree, I love the upgrade of the both front and rear speakers. No volume loss at all, I have no db level proof but to me it actually is louder and clearer. I just picked up the factory Bose dash speakers and will try adding those with the kicker speakers to see how it sounds. Pgamboa and I both had non Bose stereos and added the complete kicker Vss sub and amp upgrade. I do not recommend upgrading the door speakers with out the additional amp. I do not think the factory head unit would provide enough power.
I already have they kicker sounds take full system... just wanted a little more volume and clarity if upgrading the speakers helps I will pull the trigger. Just wanted to know if replacing the stocks was worth it .
I dropped son off to church today. One the way, all windows rolled down, sound turned all the way up, it is loud and really happy with the clarity on the mids/highs with the new front/rear speakers.
Edited by pgamboa
  • 3 weeks later...
anyone '14-'16 Silverado/Seirra DOUBLE CAB ONLY Looking for the complete Kicker VSS kit with both sub and digital signal processor? part # 19303115
I have one for sale. Complete with everything. Great sounding addition. Bought a crew cab and just added the Kicker VSS for crew cab. LOVE IT! Ready to ship professionally with insurance and tracking.
Asking $475 including shipping...You will not find a better deal here.
    • I included the first gen-cylinder de-activation (active fuel management) in my statement.
    • Hello All!   My 2019 Colorado 3.6 LT, 4WD Crew Cab has approximately 77,500 miles and I recently began experiencing the well-known transmission shudder between about 30 and 65 mph. The problem had worsened to the point that I could no longer attribute it to road conditions - and I had decided to bring the truck to the dealer - when recently, I experienced a sudden loss of power while driving at maybe 40 MPH. Several warning lights flashed, the “Check Stabilitrack” message appeared, and the Check Engine, Stabilitrack, and Traction Control icons remained illuminated. The truck regained driving power, but it stayed in a low gear with unusually high RPMs for the speed. (limp mode?) Because I was only about two miles from home, driving slowly, I was able to make it back and run an OBD-II scan, which showed fault codes U0101, P0700, and U0100. My next trip in the truck was to drive it to the dealer the following day. That trip began normally, but after about a mile I experienced another loss of power, along with the same warning lights and the same “Check Stabilitrack” message. As before the truck remained driveable, but again operated at an abnormally high RPM-to-speed ratio and seemed stuck in a single gear. About a mile later, the dashboard lit up once more, this time displaying “Check 4WD.” Soon after that, I arrived at the dealer. I have verified that the truck still has its original factory transmission fluid, which means it has never received the corrective fluid exchange outlined in GM Technical Service Bulletin #18-NA-355.  That was Thursday of last week and I've heard nothing yet from the dealer.    According to Technical Service Bulletin #18-NA-355 and the build date of my truck, my truck should have the newer LV fluid. I've done a little research and read something about a problem with the wiring harness as well.   Anyone have an insights into this situation?  Thank you!!
    • Having bumper and other body damages can be very frustrating, especially as a result of a parking lot collision/bump. Our team wants to learn more about the damages to your truck so we can look into ways we might be able to help. When you get the chance, please fill out our support form with more details: https://s.gmc.com/support-request . A member of our team will follow up with you as soon as next available. We want to get you enjoying your truck to the fullest again.
    • Did you even read this article?   Even the title of the article says "U.S.-Iran Deal Doesn’t Mean a Swift Return of Oil and Gas Flows"   Remember, crude oil prices are based on FUTURE purchases by the oil companies.  Gas prices are based on FUTURE purchases by the station.  This article stated that many of the oil producing nations have to restart their processes to get the oil produced.  Then the oil has to be shipped to wherever.  And it doesn't get there overnight.  And most of that oil is not coming here. Check out this site:  https://afdc.energy.gov/data/10621   A graph will pop up to show where the US imports their oil from.  Notice that there isn't a lot of import from OPEC and Iraq.  Most of the US import comes from Canada. The US oil produces are selling their oil on the open market, which is why the US fuel costs went up.  So you're correct, the US oil companies are going to slow walk the price downward.
    • Having codes and an engine light with no hints on what might be causing it is nothing short of frustrating. How long have these concerns been present? We want to know more so we can look into ways we might be able to help you. When you get the chance, please fill out our support form with additional details on your experience so far. A member of our team will follow up with you as soon as next available: https://s.gmc.com/support-request
