I want the kit for my 2016 Sierra Bose unit. I haven't been able to get a clear answer as to if it will work or not on this model. Any part number info would be deeply appreciated.
If you have Bose you'll only be able to get the Kicker with just the sub upgrade...without Bose you can get the amp/sub Kicker.
I believe it's because the Bose system comes with its own Amp? Don't quote me but this is what I've read.
It should work the same. I have it in my 14 with Bose and the site where i purchased mine it says it is compatible. It also has the lowest price i've seen
http://www.shopchevyparts.com/electronics/2016-sierra-1500-crew-cab-audio-upgrade-kicker-subwoofer-kit/19303118-p-92286109.html
So your saying this system with just the kicker is for trucks that have the Bose system? You don't need the more expensive system with the amp because the Bose system already supplies enough power? Just need to clarify this before I purchase
It has its own 200w amp attached to it that powers it. It does not need anything else. It's Plug and play
  • 1 month later...
I just installed this today. Ordered the 19303117 version for my 2016 LT Crew Cab. This is the Powered Sub and Amp. Took me about 2.5 Hours to install. Would have been quicker IF I had a hanger to route the wires through the Firewall. This and running the cables under the carpet were the hardest part. I watched many videos on how to remove trim radio, etc. Overall, I am happy with it. It does amplify all the other speakers too. Nice job Kicker!
Edited by pgamboa
I had the full kicker system installed two weeks ago in my 2016 Silverado and have to say that it really is a vast improvement over the stock system. Overall the sound is more crisp, clear, and "up front" with more powerful bass to complement it like advertised although the rear door speakers don't seem to do much. Like others have mentioned, the door chimes and turn signals are louder but not too bad--I've become accustomed to it now. The sound settings that others have discussed previously matches my experience as well, along with fading to the rear by +1.
One thing that kind of bothers me relates to the void in the mid range that is evident at times. For example, today I was listening to Ozzy's Boneyard and Motley Crue's "Piece of Your Action" happened to be on. The bass, drums, and vocals were great, but the guitar part was noticeably absent at key parts of the song--not even faint, just gone. I'm not sure if this is due to the compression of the music from Sirius XM, the limitations of my stock speakers, or the mix of Kicker's digital processor, but that song was definitely not being delivered to my ears the way it was intended or originally rendered by the artist (It was like Mick Mars took the day off or something).
Those of you who have added aftermarket speakers, do you ever experience this? For almost $1300.00 installed by the dealership, one would think this wouldn't be an issue, but without voiding the warranty on my new truck by doing other audio modifications or installing that $3500.00 Alpine system or something, this seems to be the only option to improving that muffled sound I hated with the original system.
I don't want to sound too critical because I realize the inherent limitations of the head unit and factory speakers, but after making a considerable investment in a new vehicle and the GM authorized "factory fix", I was a little disappointed today. I still think the Kicker Upgrade provides an impressive auditory experience, but it isn't perfect and it is rather pricey.
I see exactly what you mean. I had the opportunity to listen to some music today. I certainly like the improvement. Luckily for me, the cost was $880, self installed, and with an Amazon gift card to cover most the cost.
If it is of any interest after selling my 2015 LTZ with the non-Bose and getting a 2016 Yukon with the Bose setup, the Bose system is MUCH better. After 6 months of the non-Bose going to the Bose is a huge improvement. I could see sitting in the dealer lot for 5 minutes not noticing it but after living with this the Bose is so much better. Not trying to ruffle feather, just my opinion.
Edited by Gabe63
Try listening to music on an SD card vs using sir I used and see if you still have a problem with lost mid range. All I listen to is my SD card and I have no issues but I have heard complaints from people using Bluetooth. Maybe this is your issue also
I'll try various sources including CD - Oh wait, I don't own a single CD anymore. LOL. Didn't know there is an SD slot??
I just listened to the same Crue song off usb from a youtube download and the parts that were missing when I was listening to it off Sirius were present off the usb; in fact, it sounded great for an mp3 compression, so the music source obviously makes a big difference. I'll have to dig up some cds and try that out as well. I didn't know there was a slot for sd cards either...where is it?
Maybe a SD-USB adapter? I couldn't find it.
If you have a ceneter console non bench seat then you have USB and sd card slots! Edited by Alexantics
    whenindoubtuseahammer
  • Who's Online   2 Members, 0 Anonymous, 271 Guests (See full list)
    • With large equipment or deep mud it is more of a use the higher gear to avoid spinning tires, getting stuck because of spinning tires and doing damage to your machine. The idea is if you run out of torque before you spin tires you can still downshift for more torque. If you are just spinning your tires in the lowest available gear you are stuck and things break.   Automatic transmissions, traction control and electronic transfer cases change the calculation a little as you the driver have less control over each piece.
    • are there any codes? with lots of rust, perhaps disconnect/clean both sides of the connection/examine cable ends (the wires) for corrosion going into the sheath & replace if necessary/reconnect ALL the power AND ground cables between the battery, engine, frame, cab, fuse box and starter charm.li (website) has a no-start diagnostic procedure you can work through to get it working.
    • Its no wonder you've gravitated to the oil types and brands you have in later years after trying certain brands and one being a specialty oil or at least very hard to come by up here and the other would have been a commonly found oil of the era and the vastly different outcomes as a result to using the vehicles in question the same distance for an OCI . It shows what marketing hype can do without actually having the product to back up the claims and that is no different now with the insane claims that are written on the side of a bottle of oil from some of the off the shelf oils.    What has surprised me and I was already finding this out before I bought my truck with the GDI engine, that this newer fancy technology that seemingly would suggest better fuel economy/emissions with this high pressure spray of fuel is not in reality kind at all to the engine or at least the oils life. Yet they insist on claiming long OCI with this technology just like they did with the port or similar type fuel injection systems when in reality its a step back in oil life to have a GDI system.    I think the mistake your making Grumpy is that your not sending your samples to Blackstone and getting the feel good glowing report that you can run it another 1000 or more miles and then send another sample where they say run it yet another 1000 miles and on and on it goes until your sending in something that looks a lot like road tar and then they may suggest you change your oil within the next 1000 miles 😆
    • I am guessing that engines of that design back then had a better ability to be abused and survive longer than a new design engine with the long timing chain and the overhead cams and phasers etc. But I would never guess that an engine could go that far and not fail spectacularly or at least die a slow death.
    • In the 80's 90's I'd run Honda's 7,500 miles between changes using Red Line HP 5W20 and do it for hundreds of thousands of miles with issues. Back in the day it was an SAE 20 with the HTHS of a SAE 30 and SN add load. It was also very polar. Oxidation VOA was over 120. Besides those motors were SPFI and lean burn tech. I could have likely run it longer but never did.    We had a Toyota bought new I ran on Pennzoil's latest and greatest synthetic of the day with "Penthane". A made up word for a very low dose of PAO. Tried 7,500 mile OCI's in that Group III/VI chemistry and the rings tapped out at 90K. Rocker box wasn't as bad as the one Punch put up but it wasn't good either. Also a SPFI motor.    I'm around 3,750 across the board on these GDI monsters and the oil it tapped out by then usually on TBN/TAN crossover and color. Red Line HP Euro.    The AMSOIL SS brochures tell you to follow the OEM values for the service class but that it can be run up to 25K if monitored. I can't imagine what motor could go that distance and not tap out. I've never owned one.    Yes, I know. Lot's of people do. I'm just not going to be one of them.
