My 2014 can no longer pull my trailer now what, recall changed capacit
dkeven
Geez...I would never put 9600lbs on my truck even when he is rated for it.
"towing capacity" is a sales argument. Nothing more. Everybody knows that.
Get the tools you need to get the job done safe and efficient.
And in some cases that means get a 3/4 or 1 ton truck.
:rolleyes:
so long
j-ten-ner
  • Replies 46
If the truck handled it before and you are comfortable pulling it, don't let a piece of paper tell you otherwise...... just be safe.
Sent from my LGL86C using Tapatalk
What sort of instrumented testing proceedures do you feel j2807 lacks? Have you read through that document to see what the new ratings mean?
It'll still holds as a sales argument...
And I didn't question the "j2807".
:dunno:
so long
j-ten-ner
You make no sense. J2807 is what GM now uses to rate the towing capacity of the 1500's (which chaged very little from '14). You said the ratings are meaningless. But you don't question j2807. Which is it?
I allways pulled more than the GVW if my truck could do the speed limit. The key is and allways will be is the trailer brakes. These gas trucks now days have the torque rating and twice the HP my first haul truck. My first haul truck was a 91 Dodge Cummings and I haul on a fifth wheel 33000 combination truck was rated for 12k trailer was rated for the rest. I would load my equipment over the trailer axels my 3/4 ton truck would only squat about 2 inches. Most of my stopping power was handled by the trailer brakes, that's where the load was. If there was an time the trailer brakes got weak the load would transfer to the truck and the truck would and could pick up the slack. Being older and wiser the only thing I would change is the first truck would have been a dually four tires are better than two for heavy loads.
Based upon what? Have you had issue with them while towing? I don't think I've heard of anybody having any braking issues while towing with one of these. We now know for a fact these brakes will pass the SAE J2807 braking tests with a 12,000 lb trailer without any trailerbrakes! Compared with that, a 9K trailer with trailerbrakes is cake.
That's a bit of a stretch. J2807 braking tests are only from 20 mph. I think every state in the country requires e-brakes over ~3000 lbs anyways. That said, rules or not, we want the trailer stopping the truck at these weights... not the other way around.
http://www.automobilemag.com/features/news/0912_sae_tow_ratings_finally_pass_sniff_test/braking_and_stopping_distance.html
Well, I think they kept the speed fairly low just for that reason--it's a test without trailerbrakes making it excessively hard on the truck's brakes on purpose--which as you said, isn't something that should ever happen in the real world. Given that, 20 MPH is plenty speed to document the truck's ability to bring the trailer to a stop quickly. Higher speeds could mean brake fade, but they test for that by doing multiple stops back to back. With a full weight trailer not using trailerbrakes at all, that makes for a pretty grueling test.
The biggest problem in years past was brake fade while going down a long, steep grade. Luckily, these latest trucks' grade braking/exhaust brakes, etc, (along with much bigger brakes than older trucks) has made that largely a thing of the past.
A agree, but the energy that has to be dissipated from 40 mph in an emergency maneuver will be 4 times higher than a 20 mph stop. I can't imagine strapping 9k lbs to one of these trucks and going down steep grades, or driving along busy highways. A back road at 30 mph wouldn't be too bad, so long as there weren't many hills. Even if the truck will stop, the trailer is going to just push it around sideways. There's just not enough braking surface on the 4 truck tires to do the job. The weight on the trailer tires means that e-brakes can put that friction to the road.
I'm pretty sure we're in agreement here, but hoping nobody would be foolish enough to go towing those kinds of loads w/o trailer brakes.
Yeah, we're in agreement if you're saying towing 9K without trailer brakes is a no-no. I wouldn't do that.
But if you're saying you wouldn't tow 9K at all, even with trailer brakes (as some others have been saying), I don't agree. There's no justification for it. These trucks handle that weight just fine, even down steep grades. Years ago when tow ratings were less meaningful and 1/2 tons were much less capable it may have been true, but it's just not anymore.
Yes... that's what I'm saying. Trailer brakes needed (required) at heavier weights.
:rolleyes:
so long
j-ten-ner
Amen
I laugh at guys driving a sacked out truck, loaded right the absolute MAX. And they're like "well it's rated for it" lol
Wife and kids in the truck, Rollin thru the mountains...unreal.
Yesterday, I passed a guy that was doin 30mph up a hill in a tundra towing a 25' camper, the camper was hooked to an 18' boat and he had a quad in the back. Just plain stupid.
I saw a guy doing the same thing the other day on I-80. Pickup towing a camping trailer with a ski boat hitched to the back of the camping trailer. The overall length was more than a semi trailer (might be mild exaggeration but you get the point). Didn't even know that was legal!
From experience.
Cc 5.3 with 3.08 changed tow ratings in manual by alot. I bought thinking I could tow camper but when it changed now I am too heavy.... but still tows good. For 2015 it got even lower....900 pounds less than v6. Read the "Towing with 5.3" thread. I wish GM would change my gears for free. Legal issues.
Btw...my camper alone is around 8600
