Been driving it a lot this week. Nice how when the car is rough around the edges, you worry less and tend to drive it more. Wrote up an Ad. Really torn on to sell or just have a long term project. Some of you probably remember how I just couldn't stop messing with the firebird(comments like "how many hours are in YOUR day?"). I don't like stopping in the middle of something.
I learned that many years ago, rather have driver than an expensive collector. I had more fun with my 4 door Chevelle than my expensive 2 door. My Tempest than my GTO, to name a few.
Ryan
We entered our Marquis in one last weekend. Won a $50 Jegs gift cert - not because our car is so nice .... it was just the luck of the draw. :thumbs:
I can't compete against a '71 Monte Carlo, '68 Camaros and Mustangs, a Grand National, 50's trucks, etc etc...
We weren't the newest car there, as you can see. That Impala next to me was friggin beautiful! Guy left in a hurry. Wanted to check it out more.
Check out this gem that showed up! Vega wagon! All original too! Didn't know there were any left that didn't rust away right back into the ground. :D
Edited by Jsdirt
Few from the show I am at
Ryan
NICE! Some beauties there!
Were a couple real nice trucks at the one last weekend. The step-side '71 was for sale. Way outta my league.
Please tell me it came with the plastic sleeve?
Accord is doing great, 300HP V6(yeah, rated 278 but dynos have proven these are underrated) and 34 MPG for half the drive down, 32 for the other half, driving around 70 most the time(except for passing through small towns) with the car full of people and luggage. Got stuck in literal stop and go in Dallas and the tank average is still over 30.
Edited by SnakeEyes
Finally got my dashcam permanently wired in. It has a controller box that takes battery and ign connections and then runs the camera for a preset time or battery voltage limit is reached. Kind of a pain since the fuses are a "low profile mini fuse" which I did not have nor taps for the same. Had to make some ebay orders to get that squared away but it works great now.
I'm not a limber as I once was and cars are smaller than they used to be so a few hours of working in the trunk and interior takes a toll!
I installed the same setup in my 2011 Sierra earlier and it was a good bit easier.
Edited by waumo1
Yes it came laminated as the date I am attending is written on the back (so I can't tamper with it). Should be a good time had to miss last year (1st time they did this) due to work
Ryan
Exhaust mod resonator delete
Ryan
I may or may not be participating in this thread soon [emoji16] [emoji16] [emoji16] stay tuned!
Sent from my SM-G925V using Tapatalk
Uh oh trying to become one of the cool kids :)
Ryan
Edited by RyanbabZ71
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
