Lights behind grill
Has anyone ever smoked a light bar so it doesn't stand out as much. I have a Sierra AT and every light bar ive seen behind the grill stands out like a sore thumb. One or two coats shouldnt knock the light output down that much should it? I also noticed Rigid has released a blacked out model at the SEMA Show. Unfortunately they're way out of my price range. Hopefully the Chinese knock offs will follow suit.
Rigid Industries new Midnight Edition:
130212BLK_Midnight%20Edition_30in-Eserie
That is sexy
  • Replies 406
I was thinking about doing that when I do my bar in my all terrain. Except i was thinking of doing it with a sheet of tint or laminx
Anyone have a picture of an install behind a High Country grill? Bought a 30" Rigid dual combo bar. Should be here tomorrow. Wondering how much light will be blocked by the horizontal bars of the grill or if there is enough space between that light output won't be significantly affected.
Sent from my Nexus 6P using Tapatalk
I installed a 30' Baja Designs ONX6 behind my high country...very little light blocked...the thing is ridiculously bright..I will try to get some pics tomorrow for you..the HC grill is good because the slots go all the way across.. i adjusted mine so it shoots light right between the slots.
Thanks for the info-good to know. Was also worried about the indention running down the middle of the grill causing issues. Hoping to install today. Will post pics if I do.
  • 1 month later...
Better late than never, I had the grill off again, here's some pics:
I made some aluminum brackets to attach to the angled supports behind the grill. Clearly I need to get some stainless screws haha.
I know yhis was posted a year ago but these brackets are sharp man....GOOD JOB i am surprised theres not a dozen ppl ask you how you made them unless i over looked it. Did you Mcguever them or are you a machinist
Thanks man, my light hasn't budged one bit since I installed them and the stainless screws I added after really helped the look. No one asked me how I made them because they were too busy buying them. As for making the brackets, I am a machinist so it only made sense to do something like this. I'm actually just starting another batch of these, if you're interested in a set feel free to shoot me a private message. I was going to put them on eBay but never got around to it when I got flooded with requests right off this forum.
- Colton.
Who here is experienced in how the spot/flood combo works? I was under the impression on is on and off is off and that there is no seperate switches for FLOOD and SPOT. the best deal i found sa far at 18000 lumens is a Mictuning .... here is a link to it on amazon http://www.amazon.com/gp/product/B00LAVVEL2?psc=1&redirect=true&ref_=ox_sc_act_title_2&smid=A15H3UKRB6RHF9 Look at one of the reviews that the guy is sharing his install with illistrated pictures and let me know what you think... Why 2 switches? can i run it off of 1 switch? is there 2 set of wires off thi led bar? It is listed 2 seperate ways on amazon, with wire and without wiring kit. I soon as i hear from a few of you guys i will pull the trigger or change directions.
you only need one switch. he has another light for that switch. the bar is on off only, combo means that the outer lenses are diffused for a flood beam while the center lens isn't so it produces a spot beam.
33725340-1EFC-498E-ADDE-E41CC4AA05EC_zps
you only need one switch. he has another light for that switch. the bar is on off only, combo means that the outer lenses are diffused for a flood beam while the center lens isn't so it produces a spot beam.33725340-1EFC-498E-ADDE-E41CC4AA05EC_zps
Thanks Gab, that's kind of what I was thinking but his description, pictures and the fact that it comes with that wiring kit and switches throws me off. I guess the seller put a wiring kit package for some one that is adding to a set up that already has a light bar.
Not a huge fan of drilling through that thing. I made a clamp that uses U bolts to hold on the light bar. Ill attach a PDF that you can print, trace, cut, modify to your own needs.
Looks just what I'm looking for! I dont want to drill either. How has it held up? Any thing you would change? Any tips? What bar did you put on? Thanks!
VHT Nightshades is used regularly for tinting tail lights I wonder if this would work on a light bar and give the same end result as the new Rigid dark one?
I have put on 6000km with the bar mounted this way. It has held up fine to bumpy roads and various obstacles.
The light bar is a 30" TopNotch Bar: https://www.partsengine.ca/p-59427-topnotch-combo-beam-curved-led-light-bars-20-30-40-50.aspx
I wish that I was in my Dad's shop when I fabricated the mount. I used a hack saw and a hand drill. If I would have had a cut off wheel, drill press, air tools it would have been a much nice product. I would have trimmed some of the excess fat. Possibly drill out some of the bulk of the material.
Overall I was happy with the dimensions and fit.
I WARN YOU - If you are using a different bar make sure the dimensions work for you. This is based off my light bar and I cant guarantee you will have similar results with different bars.
If you have any more questions let me know.
I got my OPT7 32" light bar today and thought I would let you guys know what I think of it. HEC YEAH!!! If I would have known it was this quality I would have went ahead and ordered the C2 but I got the C1. I will install it this week end and let you know how well it performs. The wiring kit is very well made. I plan on mounting the switch in place of one of the cigerette 12v socket. I seen this done by another member and I like this switch because you can still close the cover. Looks really clean and factory.
    TopBo
    TopBo
  • Who's Online   3 Members, 0 Anonymous, 1,835 Guests (See full list)
    • New tires are on, Cooper Discoverer Road+Trail AT's in 235/75/15. $100 per tire, after $10 AAA discount. Plus install ($100), disposal fees, and taxes.   The new tires ride nice. Catch 22, new tires, I love it again! But I feel like I've been through the wringer with this rig, and maybe I don't need this kind of headache right now. Wait until tomorrow, I'll probably love it again and keep it another week.   Never a dull moment: Got a CEL driving to the tire shop, P0172 bank 1 too rich. Oh lordy, really? I've been enjoying an emoji-free dash for too long, apparently. I popped the hood at the shop and I think there was a vacuum leak very close to the intake. Cleared the code and put a bunch of miles on it going home, code never returned. My fix was zip-tying the line on the vacuum reserve ball because the hose won't stay seated. It's either that or the fuel pressure regulator has an issue again or an injector is leaking. See why I'm getting tired of this one?!   In the gas price thread I recorded 19mpg on the last tank in fairly mixed driving and some higher-speed highway (70). I also don't have the lower engine shield installed right now, and that would help with diverting a lot of wind underneath the truck.   Not too long ago, a green '96 4-door 4x4 came up for sale with less than 1,000 actual miles. There was a story there but it was real, and the place wanted like $25k for it. Would be fun to have a NICE example of one of these, but not too nice. The joy is driving them.   That's it for a while...family and social stuff all weekend, no time to play with my Hot Wheels in the garage for the next couple of days.
    • $5.19 after Kroger discount for 87 today. Moses!   Somehow I've already put 560 miles on the Blazer with the last tank clocking 19mpg.
    • I have a 91 GMC SIERRA 1500 4.3 liter. My dipstick broke. Can someone tell me how long is the oil dipstick. Local Part stores do not stock the oil dipstick. If someone can tell me the length. I can match up an aftermarket one. Thank you.
    • Assembling a Word Puzzle   A sentence in a famous sermon says:    “Happy are those conscious of their spiritual need, since the Kingdom of the heavens belongs to them".   Forget it was a sermon and forget its religious nature. Assemble the puzzle. What did he say? I'm only going to unravel the part underlined.... Keep it simple and out of the ditch. It's a word puzzle not a religious class. I'm not writing a book. Okay..   By saying that people conscious of that stated need will receive; the implication is that there are also people that are not conscious and thus deprived.   But this one sentence also says that ALL people have this need, not just the ones aware of it.   NEED will try to lead you to satisfying it. You're thirsty, you seek water. You're hungry, you seek nourishment. You're cold, you find cover. Lack of awareness is a choice. So when he says "conscious' he isn't saying simply aware but aware and active in satisfying that need.    That's allot of information for eight words. This man knew how to craft a sentence...   Give that some thought the next time you read an advertisement or a book.
    • My gas fill door does not stay closed. Not sure what happened, but it works its way to about a inch open every trip. Need a fix to this. 2020 Silverado 1500.
