Do you carry your spare?
LaserBlueZ71
  • Replies 35
If you are getting bigger tires I would consider buying 5. I run into guys all the time with their 35's and 37's and no spare. Sometimes no matter what you have for plugs or tire slime can patch a hole. Especially sidewall damage.
But if you feel a spare is useless to you it's your truck.
I thought people were having problems with 99-06 spares not releasing from under the vehicle due to a stuck cable or rust
Likely because they hadn't ever lowered it in several years. It's a cable assembly, it should get some general maintenance from the to time.
A few weeks back crossed paths with a guy who couldn't get his wheel off his truck. He had been there a few hours. I offered to give him a hand as there was no cell service. Frig, beating on that thing with a mallet wasn't going to loosen it. Never had the wheels off his truck in the 2 years he owned it. No idea how he made out after we drove 40 mins down the ride to call for assistance.
I dunno. I have a 2014 and had the misfortune of having to use it and it came down very easy.
How do i do maintenance on mine? 2002 in illinois never removed/lowered
Lower it, remove it, lube winch cable and work it up and down a couple times, then make sure the spare tire is all good and button it up
Exercise it. Lower it and spray it down with PB blaster or similar product, then work the mechanism
I've always had a full size spare. Nothing else the extra 50#s or whatever it weighs adds weight to the back. Spare came down easy after I figured out how to work it the one time I've had to use it.
I always had the safe feeling from having the spare until I needed it for the first time and it didn't fit over the rear calipers.. lol.
I put it on and the truck didn't move. So many years of false security!
With all the different roadways and terrains I drive through I keep my spare (and latch/cable) ready and waiting. I've only had to use it a couple of times but both times would have left me screwed out of luck if I didn't have it. I was in a no reception, middle of no where area. If you ever drive in Alaska or the Alaska highway (in my case I have done both and in both directions) you will want that spare too.
Has anyone ever replaced the lock for the spare access? It was lost when I left it on the rear bumper and took off.
No but they can't cost that much and like the tailgate should be self-keying so all you do is insert your key, turn it and the lock is then matched.
I think you guys are right. Better to have it and not need it versus needing it and not having it!
Any products out there besides a bicycle cable lock that would keep a spare tire secure in the bed of the truck?
    • Does your dealer charge you for the tire rotation on top of the oil change price ?. I haven't had any service work done at my dealer yet other than when I brought it back soon after owning it to have the front end aligned to correct the steering wheel being off center a bit. Oh they called me at least twice hounding me to bring it in for an oil change and pushing a 300.00 package of oil change and tire rotation and whatever other quick simplistic checks they would do. Only going off of what a friend gets charged for his half ton for the basic oil change and its the same amount of oil as the L8T holds, it was about 150.00. Once one buys a set of tires from most shops these days or so I believe, they will do free tire rotations and some do free tire balancing as well as free tire repairs.    Certainly doing a tire rotation is no five minute job, and definitely not at home but because I run a set of winter tires on their own wheels, I swap them at home and its a one tire at a time deal because of the tire season swap although I jack up the rear and do it and drop it back down and then raise the front and do them and coordinate the tire rotation into that process for both sets of tires. I am using a floor jack though and if I need to raise both ends at once I use a couple sets of jack stands to have all four tires off the ground. I use either an air impact or battery impact and have electric impact as well so no shortage there of easy methods to spin the lug nuts, and then retorquing the lug nuts. None of it goes quick though but my wages are cheap though ... zero. I live an hour out of town, its easier just to do things like that myself than waste a bunch of time in town and having to make an appointment and probably a special trip and sit there at the tire shop waiting for them to get my vehicle in and get it done and not screw something up in the process.
    • I do have the 8 speed.  Interestingly enough, after driving my truck for the past 2 days now, I have not had the clunking issue at all!  I am beginning to think it may have been suspension/leaf spring related, and somehow when the shop put my truck on the lift to do their initial inspection, it relieved some built up tension/pressure that was causing my problem.  I swear it felt I was a bull rider on a bucking bull the way the truck would almost rock back and forth slightly before the big thud/clunk when coming to a stop.  I am hoping I got lucky here and it's gone for good.
    • Bring it to discount tire. They do free rotations even if you didn’t buy your tires there. I didn’t believe it until I tried and they did. You can tip the employee if you would like
    • Best part of this video is how it resets expectations. Wonderfully done piece. It also made clear a few points I've made from day one. Detergent oils DO NOT KEEP A MOTOR CLEAN at the recommended or longer change intervals. They just get dirty slower than a non-detergent oil and there isn't spits difference between them on this point if they carry the DEXOS license. Great thing about the license that gets missed is it assures CONFORMITY even it that means a low bar.    One thing he did not talk about that I paused on an magnified was the condition of the oil ring separator. Besides a stuck ring a plugged separator and land drain back is huge when it comes control. We see in short order improvement in control IF that is the problem.    Another item I took exception to and he did not make plain was the condition of the timing chest and under valve cover having something to do with indicating piston cleanliness. Schaeffer's Oil makes that same omission in their million mile Ford video. I'm guessing he has never torn down a Red Line HP, AMSOIL SS motor that has been on that diet from the get. What he showed in the video was a good deal of varnish. Something totally absent in Peppers 165K cover off look. I smiled because he did his at the same milage.    He also makes the mistake of assuming oil temperatures in the pan are the temperature all over the motor even though he makes note of the piston being the hottest part of the engine. that baffled me a bit.    I can tell you from personal experience and witnessing teardowns of family motors that even oils of the 1960's would keep them squeaky clean when OCI's were 1500 to 2000 miles without exception. At 3K and above you get what he experienced and the longer you leave it the quicker to gets to the junkyard.    I think his is missing a opportunity not tearing it down again when he's done killing it. Time would be his only cost.
    • Very often the part number on the trim part is just for the vendor order/assembly plant and will not show up in the parts system.  They won't make a bunch of extra parts that were not ordered. Keep in mind, lots of these parts were made to be "just in time" parts meaning they were dedicated to a vehicles ordered and sequenced for assembly.       Also, trim parts will often say, paint to match.
