Anyone get a buyback?
After being approved for a buyback, how long were you told it would take to fully complete the process? How long did it actually take. I was told 45 days at least. Seems a little long. Maybe Im just in a rush. thanks.
  • Replies 41
Why would I want to? About 17,000 miles and no problems
Then no one really needed your post. Just another flag waving "my truck is perfect troll"
I don't think the question was presented directly to you.
Edit: I will delete the last part of my comment because I don't want to be reprimanded for unruly responses.
lol yup
I wouldn't laugh and joke about it because karma can be a mofo!
Many of the people here that have gone through the process did so because their trucks were unfixable by gm and their dealers after many failed attempts. Not sure why you want to make snark comments about it and how great of luck you have had, because obviously these problems are very real and the people here going through them do not need to hear your little comments about it to make a bad situation worse! If you have nothing but nonsense to add, don't and move along to somewhere else please!
Edit~my post was directed at Pathor not Nards.
Hey guys. I was just wondering if the 45 day process I was told is normal or not. I have already been approved, went down and pick out a truck , but was told this is a very long process and to just wait. The truck I picked out was a LT2 Z71 so their will be a very small difference in MSRP but I will cover that. I would like to hear from anyone who has already gone thru the process and has any advise what to expect. You can PM me if you'd rather keep it private. Thanks
Friend of the Family went thru a BuyBack on a Cruze, and it took just over 60 days. Good luck !
scott nice to see you got the buy back. Was there a stipulation that you had to repurchase a Chevy or GM product or could you just get out of the vehicle and contract completly if you wanted?
I just told them all I wanted was to get another truck. The really didn't have anything like for like . I refused to OK a truck from a different dealer that I could not drive and check for vibration. The closest truck on the lot was a LT2 Z71. The sales manager kept saying this is going to be a long process over and over. He stated he would send all info to GM and wait on them. But I still left with an uneasy feeling. Kinda like don't call us we'll call you. Just wondering if Im getting the runaround or if everything is normal.
I got trade assistance which is a little different then what you are getting. I ordered a 2015 and now the dealer is trying to get GM to expedite the trade assistance money so it arrive before the truck does. Otherwise I will be waiting for the funds to arrive before I can take possession of the new truck.
What qualifies for a buyback? I have had my drivers side seat in there 5 times now and they cant fix it!
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
