EPA for 6.2/8 speed is official
Except that GM is stupid and limits it to LTZ/ SLT trims. Even if I could afford that I'd never want all that fluff.
I can understand GM trying to cut costs in some areas and trying to make more money by Not making certain things available but not making the 6.2 available in midlevel trucks is a terrible idea.
Marketing 101.
Limit supply and collect a premium for the initial purchasers of an new 'in demand' feature. When initial demand tapers, and/or production capacity is increased, make it more widely available.
2014 vs 2015 6.2 4wd comparison
Not sure where that came from, but if you use the configure tool on GMC's website for my truck's configuration, they are the same.
Please help me out of my misery.
Isn't the combined economy the average of city/highway?
14/20 is 17...but 15/21 would be 18...
:dunno:
so long
j-ten-ner
Hell, they could put the 8 speed in the Colorado/canyon too. The transmissions are the same size. Imagine the new colorado/canyon with the Diesel and the 8 speed trans.....that would be impressive MPG me thinks.
Why do you think the diesel won't be offered until next year? :cold:
:dunno:
so long
j-ten-ner
Combined fuel economy is a weighted average of City and Highway MPG values that is calculated by weighting the City value by 55% and the Highway value by 45%.
http://www.fueleconomy.gov/feg/label/learn-more-gasoline-label.shtml
they weight city and highway values differently. personally i've seen almost exactly what the EPA estimates in both my 2011 Ram 1500 and also my previous 2008 Sierra 1500.
Did anyone notice that the gas mileage is listed as using regular gas? I having a hard time with the new numbers as my truck is getting 20 mpg city with 3.42 gears
True but you'd thing the parasitic loss in 4wd would be more. either way, impressive figures. I wonder if the 5.3 will gain anything when it eventually gets the 8 speed.
Would be nice to see 17 city/24 highway for the 5.3 2wd/4wd.
I already get better than that now. 5.3, 4wd, 3.42.
My all around average MPG is the EPA Highway rating, 22 MPG.
errr....proof? Sorry pics or it didnt happen.
This is what is commonly referred to as "rounding error" LOL.
    HWN808
    HWN808
  • Who's Online   4 Members, 0 Anonymous, 930 Guests (See full list)
    • Diesel $5.42 at the truck stop on the hi-way
    • I'm not sure if this should be a new topic, let me know if it's out of place. This my first post. Thanks 85077522 - AC Delco GM Genuine Parts Brake Master Cylinders. Anyone else had to replace this brake master cylinder yet. I didn't do any brake work, it looks like new parts and I've had the truck for about 4k miles, 119k total miles.  When it started to throw codes I did the calibrations with a bidirectional scanner and got the codes to clear but they came back so I did the routine; base bleed, automated bleed and final base bleed. All that with Bosch ES16-32N fluid (please look it up). That seemed to fix it but 100ish miles later it failed again so I ran the same process but with a pressure bleeder this time and got the same results, fixed for 100ish miles. The original fluid looked bad and I thought I got most of it out, it could've been the wrong fluid. The codes; P25A2, C05B0-00, C2A1B. I can get them to clear but not for long. The C05B0 indicates a leak in the front circuit (which is bone dry) so I'm thinking of doing the bleed process on that front again today and I don't know if that's taboo to just do the front but at this point it seems like it's worth the try anyway. The new master cylinder/module unit is supposed to get here today. But now I'm pretty much convinced this install is over my head. I've called several shops and some mobile guys that I know but this thing is like radio active material, scary wise. I did get 2 local shops say they should be able to do it, one says he has the SPS2 programing capability. And with the battery disconnected is there supposed to be pedal resistance, mine is to the floor, then if I pump it I can get some resistance. I had a panic stop prior to this issue which may have contributed from what I read. And on the first attempt to bleed and hydraulic test the scanner listed things to look for and one was any gaps between the pad and rotors which I did notice on the RF corner and I removed the outer pad (where the gap was) cleaned it and the hardware and didn't see a gap after that but will re-check it. I read that if pushing the caliper pistons back then you're supposed to open the bleeder so as to not push fluid backwards into the abs module or it will damage it. If that's true then that's also a possibility from the previous owner having the brakes changed before I got it. I'm using an XTool ip500 scanner. Any suggestions, questions and comments welcome.
    • Next Friday will be my 6 week point from my right knee replacement.  The surgeon says it will be fine if I choose to drive after this checkup.  I know I could drive now but best to do as my surgeon (and my wife) tell me.  Richard compared being 62 to 72.  I remember when I was in my early 60's I was experiencing slow but regular decline in my mobility.  Thanks to good medical support,  i continued to fight the speed and spread of this decline. During my 60's I worked on non-surgical methods and just when I turned 70, my orthopedic surgeon recommended joint replacements.  In a little over a year, I had one shoulder and both knees replaced.  This hasn't been a terribly fun experience, but worth the discomfort as my future mobility health trajectory has reversed.  It is a treat to now be watching my mobility. balance and confidence steadily improve!
