My MPG sucks first 1k miles
I have around 800 miles on the truck. Almost all my driving is city driving 4 miles to work, 4 miles home for lunch, 4 miles back and 4 miles home. About once a week I take 50 mile interstate driving trip. I am in Florida, it has been in the mid 70's for the past 10 days.
I am averaging. 12.5 on the current tank. 15 MPG lifetime and I think the only reason it is that high is because it was a dealer swap that had to be driven here.
Could this just be because I don't drive that much? My truck has zero mods...right now
  • Replies 33
No doubt the 4 mile city trips are a big contributor. Not having any miles on likely also has an impact.
funny, I have the same city commute (about 4 miles) and I also drive back home sometimes during my lunch break. I get 14.5 to 15 mpg. Which is better than some F150 crew cabs I had that only got 12 to 13mpg same commute.
I got 21mpg on an all highway trip. This was with under 1k miles on the truck. I've had the truck 3 months now and it just rolled over 2k miles. Lifetime mpg is 16 according to OnStar app.
I'm dealing with the same thing, very short commute to work so I average about 10.5 city. Frustrating as hell because i get about 19-20 or so on the highway. But the city is killing me. No idea where they get 16 city mpg from, but that's definitely not what I see. 5.3 All Terrain SLE 20" rims SRA stock tires. Everything stock.
remote start kills your mpg as well as idling at any lights. my commute is all city and i get about 12mpg average but can get up to 16-17 if i baby it. 6.2L
My MPG have been getting worse since picking the truck up. Anyone else notice that?
^I believe winter blend gas is out now so it can cause a drop in mpgs.
Short trips are bad for MPG. Doesn't let the motor warm up. And its even worse if its stop and go for 4 miles.
Feeling a little better about mine now. I was getting kind of ok numbers, but the last couple weeks have sucked. I'm hoping its a combo of winter gas and remote starting. It's 90% country driving, you'd thing I'd be getting at least better than city numbers. City is 13 l/100, was at 17.2 this morning. I've never seen the advertised 9 l/100 hwy except when going downhill.
My mileage is between 13 & 14 MPG with a 7 mile work commute and sometimes I have the truck idling as a remote start with a 1000 miles on the OD. Taking the truck on a long trip and I'm anxious to see how it does on the long trip.
2014, AT Short Crew
3.42 Gears 5.3L 20" tires
Well I am averaging 16/18 with mud tires and a level kit. So far the lifetime is at 16 mpg. Before my tires and level kits I was running 18/22 mpg. 70ab98acfae05d52086ebd175d79d12d.jpg4509b82df0df52c8bc1b109cfdf0f473.jpg
I'm averaging 15.5mpg, 10 miles back and forth to work each way. 18-19mpg on long highway trips. I've got the 6.2L, level and AT tires tho... I hope your mileage improves.
I'm in the 15-16 mpg for the 10000 miles I've had it. Almost all "city" with some city freeway stuff in there, which can go from the Tijuana Grand Prix to stop n go.
    CaptainDad
    CaptainDad
  • Who's Online   5 Members, 0 Anonymous, 487 Guests (See full list)
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
