From the OM:
Automatic Transmission Fluid (8 Speed Transmission)
When to Check and Change Automatic Transmission Fluid
It is usually not necessary to check the transmission fluid level. The only reason for fluid loss is a
transmission leak or overheated transmission. This vehicle is not equipped with a transmission fluid
level dipstick.
There is a special procedure for checking and changing the transmission fluid in these vehicles. Because this procedure is difficult, this should be done at the dealer. Contact the dealer for additional information or the procedure can be found in the service manual. See Service Publications Ordering Information on page 13-11.
Most new transmissions have a dealer only tool. Even if you get the dipstick, you will need the temp map to tell your where the fluid level should be at what temp.
Not that this is a good thing but it is the way they are going...
If you like having new vehicles, dealers need to make money to keep their doors open
The automatic transmission dipstick has been disappearing on a lot of vehicles for many years. I am not surprised it is just starting on the new Chevy Silverado. I know of some vehicles as of 2006 but it could have happen even later than that date. Just like the spare tire on some vehicles.
Edited by PMattras
My 2009 Cadillac CTS w/6-sp is same, no dipstick.
GM is trying to keep the aftermarket business for themselves and they make it difficult for owners to find aftermarket products and to service the vehicles.
Well one does service their tranny now. Drop pan and add a few quarts. Or you can do full exchange of fluid but really expensive. I did the pan and a few quarts at 30,000 and will again at 70-80,000.
If it is leaking you will know. If over heated you should know and be watching temps while towing. Otherwise tranny fluid is not going anywhere and will be in good condition. I do not buy the lifetime or 100,000 miles stuff and service the tranny.
Independent shops will have the ability to service the tranny.
Simple. You drive your truck till the warranty runs out, soon after it breaks , you buy a new one. Kinda like the tires that are made to last forever. You'll never see 'em. They gotta' keep us coming back. This "non serviceable" crap is just the beginning. Ever tried to find the engine in a Porshe Boxter?
I read that one of the Ferrari models sold in mid 80's (maybe it was Testarossa) required timing belt change every 15k miles. And to change the timing belt, the entire engine had to be pulled out of the vehicle becuase there was no other way to do it. How is that for DIY maintenance?
Well, I'd call a Ferrari kind of an exotic car. Not a bread and butter car all of us drive.
Ok it doesn't mean that the Ferrari has to be a bitch to work on just because of that.
But if I was a farmer and had to rely on my equipment (like the truck who takes me to the field e.g.) and couldn't perform routine maintenance...I wouldn't like it.
Do I have to crawl under the truck to check for leaks every morning? It's easier to check with a stick IMO.
so long
j-ten-ner
Edited by j-ten-ner
The Jeep and Challenger are this way, no transmission dipstick. So I bought the service dipstick, checked both when they were new and recorded the readings which corresponded to the chart I had. Some people have gotten around the problem by purchasing a long zip tie and using it as a service dipstick.
I don't like it but what are you going to do?
    • I would have to read back to get a better picture in my mind of some of the other comments and what they were using for a driving scenario they based the fuel mileage off of. That is why the fuel mileage conversation is extremely difficult to make fair comparisons from. If I was to be living in town and only driving around town, light to light and some longer stretches that doesn't have a light every block, and the usual stop at a grocery store and the bank and so on and so forth, my fuel mileage even during the summer time would be so bad with my truck I don't even want to know how bad it would be !. Then add in winter time and idling to warm it up to clear the windows and driving through snowy streets etc, large heavy trucks with gas engines have NEVER been worth crap for fuel mileage and why some little pot licker of a car with wheelbarrow tires and a 1300 cc four cylinder non turbo engine was the ticket to using a mere fraction of the fuel over a full size pickup.    By the way my truck has the 34" tires as its a HC but not the BFG KO3 tires ( that was an option for my truck but the sales guy couldn't figure out what the tires actually were so that never got on the order until it was too late to change the truck order ). So what fuel mileage your getting actually sounds good for "town driving" and with my truck when I go to town the fuel mileage keeps increasing as I get closer to town because it takes quite a while to get the driveline oils warmed up ( and why it always shows better fuel mileage on the return trip from town because its already warmed up ) but once I am in town that fuel mileage average just keeps dropping the more I mess around town and then has to recover back to something reasonable again by the time I get home for an over all average.    I'd be curious what your sticker says for the factory weight of your truck, mine is close around that 7700 lb due to the options it has. But anyway the long and short is, vehicle weight, higher rolling resistance heavy tires and a hefty driveline and a relatively large gas engine make for crap fuel mileage in stop and go scenarios, all one can do is drive it easy off the line at each stop and as my dad had said over the years, drive like a raw egg is under your foot and that's the best one can do. Years back with a carbed engine and if the carb was getting a bit out of tune etc as would the ignition system, the fuel mileage on pickups with larger engines was just awful compared to what your getting. We pay the fuel price penalty for driving HD trucks over some little vehicle, that is the reality.
    • We had two Toyota’s with that engine in the mid 80s. We had 50 gallon fuel tanks, a toolbox full of tools, an air compressor and assorted parts for our equipment. We beat those up and down pipeline ROWs until we started buying diesel trucks. Then they became parts runners and first vehicles for our teenagers first cars. Our shop Forman wrecked them both two years apart when we hired him out of high school as an apprentice. Good thing he’s an excellent mechanic. It took awhile before he could be called a good driver.
    • I have a 2025 GMC Canyon Denali.   On a trip recently the engine failed.  The dealership diagnosed a bent valve and says there is a service bulletin that indicates to 'relace the engine'.  The truck only has about 14K miles and is under warranty.   The failure occurred 5/11/2026.   So far I have worked with GM Customer Assistance and Roadside Assistance.  Evidently no engines are available and nobody will offer a date when a new one will be.   Coming up on two months with no repair or timeline and no loaner from the dealership.   GMC Customer Assistance is 'ghosting' me and keeps closing the cases I've opened with no resolution.   Hoping someone can help me on how to escalate this issue.
