Anybody put a LED tailgate Spoiler on new trucks yet.
Looking to add a LED taillight strip, but I see a tailgate spoiler cap is available with the row of LEDs. Anybody have an opinion of what is out there?
  • Replies 33
No offence, but that sounds like it would look incredibly tacky. It's a truck not a 94 Honda with a fart can.
Before anybody rips into me, he did ask for opinions. :flag:
Yes galliher, that is the "spoiler" I was asking about. Is that your truck or a file photo?
I would much rather see people add extra lightning than the people who "tint" the tail lights now. Saw a new truck the other day, his tail lights were so dark that when he hit the brakes during the day the lights were more faint than if just the running lights were on. That was from 4 cars behind the truck. Any further than that and you couldn't even tell that the truck was on the brakes.
If I was wanting more light on the back of the truck, I would get one of those light strips that fit between the tailgate and bumper. They are pretty much invisible until used. Just my 2 cents.
Just to clarify, I'm not looking for any opinions from those of you that haven't installed one. I'm also not looking for acceptance in to any group. I just want to know if anybody that installed them actually thinks they are worth the effort. I don't want to put the lights between the tailgate and bumper.
i actually like that, if it were built into the tailgate guard up top. i wouldnt want it to look aftermarket. its also easily viewable above car hoods behind you, so in traffic many cars back could see your brakes.
I guess it looks "ok" to me. As far as those light strips that go below the tailgate, most times I see them on trucks - several of the bulbs are burnt out. No thanks, waste of money IMO....
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
