Anybody put a LED tailgate Spoiler on new trucks yet.
This version replaces the existing tailgate "cap". They aren't added on. The lights below the tailgate sometimes aren't straight and have lights that are brighter than others or just completely burnt out. Has factory look and safety. I'd like to find a "cylon" version so I could be in the cool guy group.
  • Replies 33
I've installed 3 of those now in my nightmares since reading this. Does that qualify me for acceptance to post in your thread / group?
Rough crowd. It ain't all that bad. If you like it, just do it Jimbo. A real easy way to gain another brake light is the hitch plug type. You slide it into the receiver hitch and plug it into the trailer electrical plug.
If you're into custom work, a LED Bowtie might be a good way to burn the retinas of a tailgater. OOPs you have a GMC....
Rough crowd indeed...
clean out the Lund catalog while you are at it...visor, cab extension, rear wheel covers
haha...JK...it doesn't look too bad but I would prefer not to have an eye level row of LEDs at a stop light behind you
Is this what you're looking at?
Hey did anybody else notice the led's on the bumper steps. I guess I'm not cool but I like those.
I think its unique and that u would be probably one of the only who has one. Its a good thing that the guys who dont like it dont have to look it everyday, its ur ride do it like u want!
I noticed, but have you seen how I've been getting beat up over the tailgate lights? Didn't want to risk further humiliation!
I saw one like that, BUT he also had a amber strip under the doors wire to running lites. it look good at nite. It's your truck, iff you like it DO it .
Go for it if it's your style! I am all about having more than enough brake lights. Looks dumb to anyone who's paying attention behind you but the more lights you have illuminate when you hit the brakes, the more likely you are to catch the eye of the one person driving behind you that's not paying attention and is about to rear end your brand new truck.
This being said, I think that this bar would be a good addition of its hooked to the 3rd brake light and still looks good when turned off
Like Spurshot said, if it's you personal style or if you just like it, go for it Jimbo! It may end up looking better in person
The thing about any of these do-dads, is that a little goes a long way. Put some flares on, the ring-around-the-headlights, funky silver tail lights, some cheap mag wheels, and these lights, and you begin to look like you're driving a pimp's truck. Moderation.
My buddies and I had some fun with my last car. Got more lights for it than we should've haha. It was called a pimp mobile from time to time.
. LOL. To each his own. There is one guy on this forum that is an LED lighting guru. He has an led in every nook and cranny of his interior. Looks f'ing amazing. But hey I like chrome too so what do I know. Lol!
Heck yea got to love that chrome!!
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
