2017 Sierra Denali Ultimate
2015i Yukon Denali XL
Edited by NOVA99
That yellow badging looks amazing. I would have never thought yellow but definitely looks good
Sent from my Nexus 6P using Tapatalk
Looks like he is a Steelers fan :P Go Lions!!! :D
2017 All TerrainX
Nice 2017 ATX
Edited by AllTerrainX
That will be the end of the Lions cheering...
Edited by 6.2Midnight
Haha yeah I'm a steelers fan. I started with the yellow inlays with the chrome emblems then finally removed them and painted them black and added the inlays back. Still figuring out what to do with the all terrain emblems
I debadged my ATX and I am deciding what I want to do with some of the emblems. I might put a couple back on but I want them flat black on the chrome and maybe keep the red on the GMC and AT emblems. Idk...
I thought it might be fun to post a few pictures of my 2017 Z71 Midnight in less then a shinny state. We have had 41" of snow in 3 storms this week.
The first picture was taken during a 24" Blizzard.
can you post some pictures ? would like to see how she looks without them back and side
What's a little snow ? add that to low temps , plus wind chill's that have reach ( - 60 below ) . hot chocolate , bon fire .
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
