No way.......looks just gorgeous the way it is.....as a matter of fact, a nice set of 4" CHROME tubular step bars would really set it off. I don't know why you would want to de-chrome the truck. In my opinion tons more people will turn and say "wow", was that ever a nice looking truck. I know there are quite a few guys out there that for some strange reason prefer the "so-called clean look". IMHO the "clean look" should be called the "drab" look.
Your truck looks great, do you want to remove all the chrome and turn it into something where nobody gives it a second look.
Just my opinion
REV
Thanks Rev! - yea i think it looks pretty good and i do like a little bit of chrome - hence the chrome wheels, i may just change the handles to the painted black and call it a day. I agree though some nice chrome step bars would look pretty nice!
Here's mine, purchased Feb/21/15
'15 gmc sierra sle, cc, sb, cloth buckets, Kodiak pkg, 5.3, 3:42.
Added tonneau cover and winter wheels and tires.
Rick
Okay I will play!
You will notice some pics have mods and others don't as I had just got the truck and was going mod crazy! :)
9DE53E16-8AB4-4D2D-A71F-3927A51D4E4D_zps
93164A26-DA33-44E7-9E68-EDC0A8537E92_zps
DF6CE92A-6A25-46BF-B6F6-4BA345591129_zps
2014 LTZ 3.73axle 5.3. Rancho quicklift in front rancho rs9000 xl in rear with Firestone airlift in rear with built in compressor. Also added husky weather beater mats and driver assist handle.
Sent from my iPhone
using Tapatalk
Sure would........here's a pic of my DBL Cab, pretty much the same other than the wheels. (I like yours' better) But I have the factory 4" side steps. Nothing like a black truck, with a lot of chrome..........at least when the damn thing is clean.
Stay with the chrome........dynamite look in my eyes, and I'm sure a whole lot of other folks.
REV
Edited by revitupfaster
2014 Sierra SLT
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
