All other wires are there. Just missing the one from the fuse block X2 connector terminal 37 to the X201 connector terminal 41.
Nice detail you provided here. So the (2) Pin connector that is down below in the wire loom that the clock spring connects to.... where does that go then? Does that connect to the mate end of the X201 connector?
Edited by pgamboa
That's routed inside the rest of the harness underneath. It's on the opposite side of the X201 connector. It's there just waiting for a power source.
This picture is the Yazaki terminal for X201 terminal 41.
Edited by Justin101714
Makes sense. Find it silly though that the (2) pin connector is there but doesn't make it all the way to the Fuse Panel. I did not have to run that wire for mine and my truck is a 2016 Silverado LT. Strange.... but very good detail. Nice!
Edited by pgamboa
Mine is a 2016 LT as well. Not sure as to why they make them differently. But that wire is definitely not there. Using a multimeter, you'll find power on both sides of that fuse, if you go to the 2 pin connector for the clock spring, you won't have any power. If you disconnect the X201 connector and look in that slot I circled in the picture above, you're more than likely gonna find theres no terminal in that cavity.
This definitely help those that want to perform this upgrade and not assume power is present just because the 2-Pin connector is present. Good find! That X201 connector pretty high up in the dash above the BCM?
Just lay on your back on the floor, it's within arms reach above the BCM. Not hard to get to at all.
I think we found out if you have the adjustable pedals the wire is there. I didn't have one on mine so I just used a fuse tap. But I like this find and I think I will rewire to the back of the fuse box. Good work Justin
Okay, got my little harness made with my two terminal ends ready to plug up. Used woven tape to protect the wire from chafing. Soldered both ends to ensure a good connection. All my parts are here, I'll update when I get it installed tomorrow more than likely.
Okay, I decided to install the harness at least and check for power and ground. Got it all set up, running factory with the factory fuse. I have power and ground at the small 2 pin connector just like it's supposed to. All I have to do now is install my airbag coil and steering wheel and I'll be good to go! [emoji1417]
Two clips hold the fuse panel in, you have to hold them down and pull the panel outward.
There are 4 clips surrounding the connector. You'll have to undo the clips and move the CPA downward about 1/8 inch. It stops by itself to another set of stops, DO NOT go past those stops.
I chose to install thicker gauge wire because it's a battery positive circuit.
The X203 connector above the BCM.
That's awesome. I'm going to do that. Could you list the 2 terminals and where you bought them. That would be a lot of help. Great presentation by the way Thanks
Terminal for the X201 connector - Yazaki 7114-4110-02
Terminated lead for X2 fuse block (comes in pack of 5) - 19301761
Bought both at my dealership.
The cost for both was around $20
The dealer sold you Yazaki terminals by themselves? Hot damn! I find the pre-terminated lead to be overpriced and try to find the terminals by themselves from Mouser and crimp them myself. Then again, being able to get them immediately from the dealer... and not having to wait...
I work for that dealer. So as long as you provide the part number to them. The Yazaki terminal is in TRAY 9 by the way. Not all dealers keep the terminal trays these days
    • That's interesting, I assume that would add to the cost of the oil but also I was forgetting to bring up the issue of the low tension rings allowing more oil past which in turn forces the cats to have more oil additives pass through them that wouldn't otherwise so they are creating that problem and of course its all in the name of fuel economy. Mind you the other issue would be the lack of additives that fight the formation of carbon within the piston ring grooves which turn the engine into an oil burner and with in this GM forums case is your average off the shelf Dexos licensed oil, meanwhile the other off the shelf oil being Valvoline's R&P isn't licensed and the only one that is which is that certain Mobil oil that came out recently ( its not even being marketed in Canada ) and only a fraction of vehicle owners are going to be using it out of all the other oils on the shelf or the quickie lube bay that meet the Dexos spec by way of actual licensing.    Also I suspect that its an easy excuse to pool the non turbo DI engines in with the turbo DI engines and design the oil to not have LSPI issues in the most demanding engines and short change the naturally aspirated DI by not offering a higher concentration of additive package they could handle and still not be at risk of LSPI.    I wonder if Amsoil flipped the switch just lately and did whatever packaging designation at the same time as I wonder what oil formulation I would have bought in May, of course I don't know when it was packaged at the factory vs how long it was in storage at the Edmonton warehouse. I know its been said at least in the past that the big players switch over to a reformulated oil but the packaging has not changed until they make that move as well so there is that cross over time where its a new formulation in a predated formula marked package.
    • Hmm. A real reason to not just use the odometer to determine OCI?
    • Sad thing is that this doesn't have to be the case. LSPI can be solved without a reduction in TBN. Swap Ca for Mg.  Cats are not a issue if the OEM can get a ring and valve guide seal even at SN levels of SAPS. Dizzy is purring like a kitten with a bowl of warm milk. 200K of Full SAPS oil and zero detonation issues and nice a clean inside and out. This shouldn't be an issue. It isn't 1920.    Tell ya what AMSOIL SS is excellent at, internal cleanliness. The new formula is even a step up from their already outstanding cleanliness levels. Can't say the OEM offering is quite that clean. There marketing suggest the SS is cleaner.     That is the only defense with at shelf oil. Nothing wrong with them if you ignore the marketing and OEM 'recommended' OCI and use a thimble full of common sense. 😉 You go sir.
    • I started with a folding cover by BAK PAC on my 2500. It went bad after close to 5 years. Bent and vinyl coming loose. Contacted BAK and they gave me a very good discount on a Revolver. Had it a number of years. Mostly outdoor storage. Some garage storage. Vinyl started to come loose. Still under warranty so they replaced to cover. Sold the 2500, bought the 1500 and got another revolver for it. Had it a couple years now and no issues. I store it indoors. Got a bit of discount when buying it as well. If you are seeing problems, contact BAK or real truck and let them know. Customer service was pretty good. But I think they changed their warranty.
