Any body have trouble getting Camber in specs? What options are out there if so? Upper control arms? Camber kit bolts?
Has anyone looked at these struts? they advertise up to 2.5 of lift versus the bisteins wich lift 1.8 ??
http://www.summitracing.com/parts/eib-e60230060310/overview/year/2015/make/chevrolet/model/silverado-1500
It would be nice to get the look of the RC 2.5 kit without any spacers as the 2.5 kit is exactly the look i like on these trucks
Bilstein's also offer up to 2.75" but this depends on application (brand of truck). On our trucks they are good to 1.85". I think you will find the Summit's claim also depends on application.
I put on 5100s at the max height setting along with BFG KO2s in 275/60r20 and my MPG plummeted 3-4 mpg. Leveling kit and 1 size taller than stock and can't even get more than 18 on highway if I'm nursing it. Averaging 16.5. That's with hand calculating and pretty close to computer after recalibration with Hypertech. Anyone else similar issue? Thinking about lowering 5100s a setting or 2 and getting a lighter tire in stock size back on bc I didn't expect that big a mpg hit.
2015 GMC Sierra 1500 All Terrain SLT 5.3L CC short bed
My truck reads an avg of 14 over 400 miles. Bilstein set at 3rd setting. KO2s 275/70/18. Average 13 mpg in town. Probably less since I haven't adjusted for tire size.
I believe the biggest hit is going from a street tire to a true A/T tire.
I've just read folks doing 2.5" lifts and putting bigger tires than mine on and claiming to get 21+ on highway. Maybe they are full of crap, who knows. My highway is barely more than city mpg. Running all stock I had a 300 mile trip that averaged 23, since these minor mods I can't do better than 18 highway so that's a really big hit.
Edited by Tcolburntexas
What's in your diff? If you have the 3:08 I bet that might be why. Most people with the 3:42 haven't had as much trouble. The 3:08 is built for economy and larger tires and changing angles won't do well with lower ratios
Let us know
3:42 ratio, only 3.42 available in the All Terrain
Ive got 3.42 as well with 2 inch level and I can only get near 20 on highway like 19.5, but I drive 80 and the front end is shaped like a brick now. If I ran 60 I bet id see those 22mpg numbers.
When I go to an AT tire I expect to take a hit though.
Edited by jrob56
Poor fuel economy?
With the larger tires, the speedo/odo counts revs, not distance traveled. Vehicle goes faster/further per rev.
IE the speedo is under-reporting your speed. Also under-reporting distance travelled.
You will need to apply a correction factor using your odometer's readings to get true mileage.
Use a tire size calculator to get the difference between stock and your size.
Apply the correction to your MPG calculations.
Eibach's site info for the shocks - 2"
Summits photo looks like a pic of the rear shock - this is the front shock specs from Eibach's site:
mfg_pro-truck-sport-shock_front.jpg# E60-23-006-03-10
Front: +0-2" rha
Footnotes: Ride Height Adjustable Ring Slots To Allow For A Lift Of 0-2"
Edited by 15silver
Any updates on the 6112's? Last update said end of June.
What was the weight of the previous tire vs new tire.
Its a pretty big jump, think stock is 43ish and that size K02 lists at 54.5.
Stock size K02 is 53.1
    btm
    btm
  • Who's Online   7 Members, 0 Anonymous, 1,422 Guests (See full list)
    • Why does Mobil Premium cost 90 cents a gallon more than Shell Premium when their regular offerings are but pennies apart?
    • Was all the way down to $3.69 a gallon but then jumped back to $3.99 just because for some reason.   Diesel floats between $4.80's to $5.10ish a gallon. I even saw Diesel #1 for $6.09 today but nobody in there right mind even buys that in the summer.
    • Mine just keeps lagging or getting stuck on the reverse camera. When I turn off the truck, get out, and close the door it will still stay on. It’s very intermittent and I would not be able to duplicate the issue.
    • I was checking out fuel prices at my farm fuel retailer at their pumps and yes the farm price is a bit lower than the non dyed fuel and was glad to see that the regular farm gas price has dropped a lot from what it had been but what blew me away was the price of diesel as the spread now compared to before the prices went up earlier in the year, diesel was actually slightly lower than gas which was a switch from the theme the last number of years. However that sure isn't the theme lately and definitely not right now. The prices I will post are not from that retailer but just looking at gasbuddy for the main city in this area and instead of posting the lowest price someone found I will list the higher price ( and that may not be the highest price, just whatever someone posted on gasbuddy ).   So regular gas and there are a lot of stations listing the same price for regular is 1.68 a liter, premium 2.00 a liter. Diesel 2.03 a liter for a top price I saw on diesel.   Figures out to 6.36 a us gallon Canadian funds for regular and 7.68 for diesel. With the US exchange rate it would be 4.58 us for regular and 5.53 for diesel.    Thought I would figure that out to get a picture of what it settles out like compared to various US prices and its about the same as the current price in Fairbanks AK as Anchorage tends to be lower. So yes, these would be the prices and higher along the way on the Alaska highway where they know they have a captured market !, for fuel prices for those beginning the long drive back to the lower 48   The problem is our Canadian dollar and going to the states that have the high prices, boy do we pay then !
    • Just wanted to get a idea of how many of you still have problems with your radio cutting out during the first few minutes of driving, my 2024 GMC Sierra still does this after a little over 2 years of complaining to my dealer about it, and OTA updates no longer complete, the check for updates in settings is greyed out for the second time while trying to install a update, my dealer took about a week to play around with it the first time this happened, and somehow got the check for updates to work, even though it would always show system is up to date when I knew it wasn't, now again 1 month later its greyed out again when the OTA update N25-F163BU tried to install, which ironically is the update to help with reliability of future updates.
