For MRT..... have you had any experience with pulling the stock Magneride suspension out of a recent Sierra Denali and replacing with an after market shock better suited to a 6" lift with 35x12.5x20 tires? No one local has done this yet and there are unanswered questions as to what will happen once the magnetic shock sensors are unhooked . . . i.e error lights on dash, etc.
Thanks,
M
I've had no luck getting MRT to respond to any of my messages, plenty of for sale signs hung out but nothing in the way of the useful information I need before making a purchase.
I can't do business with people I can't communicate with. I hope your situation is different...
I installed a 2.5" leveling kit and now interested in upgrading the shocks, I spoke with a Bilstein rep and he told me that he doesn't recommend installing Bilstein 5100 with a leveling kit. He said they do not have any shock for my application. anyone heard of this?
Email them and they will respond quickly at least they did for me.
Unfortunately NOT for me, more than one message I've sent has never been answered in more than 2 weeks time. I'm sure a BS excuse will be forthcoming once the need to hang out another for sale sign is needed. Honestly, it's fine, there are other vendors who would like to have my business, just wish my time wasn't wasted so I could have moved on. Like I mentioned, I hope others have a better experience.
hey ma
Hey man I've had the same question after surfing through this tread ive seen multiple people suggest the 4600s (yellow) bilstiens work.... can anyone confirm 100% and if the ride quality is better, I hit certain dips and it throws my passengers dam near out of the truck! Also any one have a DIY on how to replace em? I assume the rears are simple two nuts take it out and replace are the fronts pretty similar ive had cars where I head to drop the whole suspension out compress the springs ect... thanks guys!
I recently installed 5100's and have them on the highest setting. Now when I go over a bump hard, I am hearing a clunk noise. Its only when I go over a speed bump or a depression in the road with any kind of speed. If I go over it slow I hear nothing. Has this happened to anyone else? Any thoughts on what it might be?
Check the torque specs on the upper and lower bolts on the coil/shock assembly as well as the end links bolt. If those are within spec, you may be hearing the bumpstops (I hear this in my stock height truck if I hit certain speedbumps).
I am looking at running 305/55/20 BFG All Terrains and from my research I need a 2.5" level. Looking at either the RC 2.5" lift/level or getting the 5100 Adjustable Bilstein's coupled with the BDS level kit. In theory using the Bilstein's to raising it the extra .5" since BDS is 2"
Can anyone recommend one way or the other, or if my theory is correct?
I would not suggest this, you will be over extending the range that the upper control arm was designed to operate within. Use the 4600s instead.
Thanks,
M
We have pulled the air systems out of the older models with great success, but have yet to remove or replace a Magneride. To make it work you will most likely need a resistor or EBM (Electronic Bypass Module) to trick the computer into thinking its still there. At this time I dont think the aftermarket has caught up, but trust that they will have an option for that soon.
We looked thru our inbox and have zero PMs to or from you. Please email us at [email protected]
hey ma
Fronts require a spring compressor, rears are easy like you said. The ride quality is 100% better in our opinion. Bilsteins will make a noticeable upgrade.
Check the hardware, sounds like a loose bolt or a missing bushing.
I am thinking of experimenting with the settings on my 5100's. I have it on the highest setting now.
I am thinking of lowering one or two notches or trying both to compare look and and ride.
Anybody have any recommendations on Macpherson Spring compressors?
I have used the Auto store rentals on lessor springs than this and don't want to even try with these springs.
At $200 for strut changes before alignment I am thinking they could pay for themselves fairly quickly.
Edited by DavidND
Go with a 2.5k wall mounted unit, the coil mounted units are super sketchy.
I have used those on small cars before and they barely work and are dangerous. I have done some research and the following should work pretty well for my occasional use and be somewhat cost effective;
OTC 6592 StrutTamer Extreme with Stand
I just did my 5100s this weekend. I've had an older version of the OTC StrutTamer -- #6580, a "non-extreme" model -- mounted in my garage for a few years.
It'll work, but you REALLY need to use it in conjunction with #6583, a "bridge" accessory that spans the top of the strut mount. Tried it without and didn't have enough leverage on the stock spring. I then did it with the bridge -- as GM's OEM service instructions even show -- and it worked perfectly. Suspect it's probably the same with the Extreme.
In any case, the bridge is only $50...might as well have it on hand when tackling it.
    • When I was there, most to all did not have an hour meter. They just did 5000 miles on regular vehicles and 3000 on police stuff. The modern oil change monitors should take into account engine hours, weather, etc. I don`t use the monitor on my stuff. I pull the stick, look at it, smell it, rub it between my fingers, etc. That`s my oci.   I have had many engines. Some bracket race. No problems doing things my way. I was in the mechanic business for 30 yrs or so. I still do things the old school way. Don`t care who laughs at me.   Understand, I was in the main shop. We didn`t do oil changes or tires. We had a service station for that. I don`t remember the hours they used for tractors, lawn mowers, etc. Something in my head says 250 hours.
    • I don't know how far back vehicles had hour meters, be it driver accessible or diag accessible but was wondering if there was any rule of thumb your shop came up with in regards to an hour limit on engine oil regardless of the miles on the oil.    I know with construction or farm equipment its almost always based on engine hours for maintenance scheduling as no other metric really applies other than a seasonal time limit that one self imposes on items like engine oil.
    • I'm not sure what to say on that mess but I will say that is an odd thing for that mechanic to speculate on as per assuming its been run out of oil a few times as the odds of that engine having instead piled up with a complete seizure would be very high if such events had actually taken place. However there is nothing saying that the oil has ever been changed although once again, what filter was on that engine as that would tell part of the story if its possible to figure out if its a factory installed filter or not. Too many items unknown and a lot of speculation, but regardless of that its one fubared mess that is mind boggling to see for a vehicle that new and its hard to imagine how it ever made it that far in life looking at the top of the engine.    His scanners, I've watched him before here and there and I'd have to say if I recall correctly that some of his scanning equipment is one or two steps up from a child's Exo Sketch 😋
    • I agree. That`s a LOT of sludge for 12,000 miles. I tossed that out here since this is an OCI thread. There`s tons of people here that do not post.   I used to work on a city fleet. That includes police cars and fire trucks. Lesson is, not to only use the odo for oci. A police car has a ton of hours on the engine for the miles it shows. And, not just idling, directing traffic. They beat on these things.   Course, since it is a Kia, they were gonna use the "100,000 mile warranty" for their OCI.😉
    • CLASS ACTION SUITS?  Does anyone know if there is already a class action suit for the paint - which was to have been fixed, changed in after the 2020 GM vehicles?  Does it look like this?    Just started 3 weeks ago - No help from GM as of yet - Dealer will not assist in speaking with GM on my behalf. Confirmed it is the paint they use along with the way the put it on that causes it to fail.  Clearly a Manufacturer's Defect.
