You can try to compress the springs with ratchet straps - generally unsafe but if you are not removing the top hat not much risk involved.
Thanks for the suggestion. Tried my hardest to be "safe", picked up some compressors at pep boys. There just isn't enough room to get them in the right spot without dropping the shock. A couple clicks with a makeshift endless ratchet did the trick.
Maybe the most unconventional thing I've ever done to a vehicle.
Glad to see it worked out! Figured that would be your best bet, even with pro spring compressors it's scary business though. Ratchet straps are very versatile, can even reset the bead on tires with them
Update on the GM 6112s! They will have two GM 6112 models, 09-13 & 14+. The 09-13 GM 6112 ETA is end of March or early April. The 14-15 is even farther. It's probably a little too early to give out part#'s, but you'll be the first to know once they're released!
So from what ive read and correct me if im wrong, 6112 for 2015 Sierra aren't out yet and wont be until after April. And these 6112 will increase the front end of my truck to a max of 1.8" on top of my 2.5" level kit. I am looking to get a little more height so i can increase the offset of my rims and thought this would be a great option.
Although that is the listed height, the 6112 will be able to provide more than 2" of lift depending on the truck. You cant really stack lifts just like that without damaging the upper ball joint on the control arm. You could run the Bilstein on the lowest setting with the spacers, any higher and you will need aftermarket uniball control arms.
Blank post?
sorry yes, very new to this. So if im leaving the 5100's at lowest setting, that wont affect my ride height which is really what im looking for, theres no point in getting the 5100 or 6112 when they come out. if i want to affect ride height ill have to do a body lift or suspension to push my tires out to the desired offset i want, or trim.
Are you offering a pre-order for the 6112's?
I would start by asking what is the desired height you would like, and go from there to is it two wheel drive or four wheel drive. Because depending on what configuration your truck is will dictate the direction you go.
We are! There is a pre-order list about 70 deep. We arent taking any payments at this time, just collecting information so when we finally get them the process is easy. If youd like to get on the list please shoot us your full name, delivery address and email to [email protected] or via PM.
Just had my 5100's installed ... LOOKS GREAT AND RIDES AWESOME !
Its a tad stiffer , I expected that .... no body roll , not much of a nose dive when you hit the brakes , off and on ramps like its on rails .....
I really like these shocks , transforms the ride totally . Service manager at the Local Chevy Dealership loved them after being a bit of a skeptic . " Not many would change a shock on a NEW car "
My ride , 2016 Z-71
Edited by sbk12rs
    B07
    B07
  • Who's Online   2 Members, 0 Anonymous, 979 Guests (See full list)
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
    • Looking for this part for my truck. They don't sell just that one piece and to get it you have to pay over $100 even used for the whole air tube. The piece the hose clamp snaps into that is held on by the screw and nut. If anyone has access to one please let me know.
