They're working great, for a direct replacement using stock springs they are light years better than Ranchos. The 6112 should be awesome. The Toyota guys love them and say they're comparable to KINGS/ICONS
Sent from my SM-G950U1 using Tapatalk
Do we have any idea when they will release those?
They expected to date has come and gone. Who knows ?
Quick question..
2014 sierra crew cab
I got 275/60/20 Discoverer AT/3 and doing the Billstein level on top notch.
Can i get the tires mounted first before the shock install? Just wondering if it will rub hard untill i can get the shocks installed the next day or so.
According to the "Technical CSR" I've been emailing about these for the last few months, the current status is "They are due in anytime now, waiting on spring coating."
They always have one reason or another, but hopefully that is the truth. They have been due since last year. I will believe them when they arrive to our loading dock!!!
On 10/23/2017 at 5:24 AM, Ozer said:
Quick question..
U-Turns will be hard. But if its just for a day I think you will survive.
I just read a thread on the Bilsein bump that occurs after installation of the shocks. It seems the top plate does not get tightened down all the way unless you use a washer or spacer under the shock top nut. I have been having some noise in the front end since the swap over washboard sections in the road. I checked this afternoon when I got home from work and found my top plate loose enough to move. So I did some searching and found the thread mentioned above. The bad part about trying to correct tbis is you gotta almost stand on your head to correct it. Maybe not tomorrow night but by the weekend I will have done something about it anyway. I'll link the thread here tomorrow.
My Bilsteins set on the max lift were installed earlier this year so (living in the Midwest) this is first they've seen cooler temps.
On the expressway today the truck was really riding funny. Kinda like very small whoops so it felt like it was bouncing up and down really fast. ( I was going between 70 and 80 mph)Not like with out shocks.. It was very stiff feeling. I wrote it off as just being that section of highway combined with the trucks wheelbase.
Later I was on a totally different expressway and felt the same.
Anyone experience this? Would a spacer lift work better for ride quality with the shocks set at stock height?
Also Eddie 70, mine makes a light knocking/ rattle noise when going slow over terrain that makes the truck flex side to side. Nothing big.. Just driving across the yard will do it and I can't find anything lose.
I went out to the garage tonight when I got home and checked everything really closely. The top plate was VERY loose. The best way I found to tighten the bolt was through the fender well. Hold the wheel well liner back, rotate the shock shaft so you can hold it with a small crescent wrench. Tighten the 16MM nut on the top of the shock until it is tight against the top plate and no more movement is noticed.
Read this thread for pics.
I have driven approximately 175 miles since I did this the other day. This was the fix for mine. It may loosen up, but I can't imagine it would using the supplied nuts that came with the shocks. They are just a tad undersized and you have to use a wrench to run them down. However, if it does loosen, I will double nut it.
SO much better with them tightened down. The truck is almost quiet again and it has 92k miles. I am excited again!
    Sothpaw27
    Sothpaw27
  • Who's Online   1 Member, 0 Anonymous, 442 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
