SteeringWhheel Leather Cracking/Wrinkling
Hi. Does anyone else have an issue with their leather steering wheel cracking and wrinkling? I just bought a '14 Sierra with 18k on the odometer and noticed one spot, about 6 inches long at the bottom of the wheel, where I could feel small cracks. Then, yesterday, another 6 inch area appeared on the left side of the wheel along with a smaller 1 inch area on top. I plan on visiting my dealer for review bUT wanted to see what others had to say. Also, I had the TSB performed for the headlights the day after I bought it...what a difference! Thanks!
First I have heard of this. Should be covered under warranty.
This does seem like an isolated case, unless GM has stooped to a new low on quality. I have two GM vehicles with leather steering wheels, one 9 years old, the other 6 years old, no problems with either steering wheel yet.
And it is a warranty item.
I have almost 17k on mine and no issues with the leather on the wheel. Likely a bad batch. Should be covered under warranty.
Still waiting on my dealer to call me back on the headlight bulbs and reflash.
Normally I'd agree that it might be previous owner damage BUT the cracks go front to back not around the wheel. I'll snap a picture. They're also not in a place where a driver would hold the wheel. By the looks of the issue it's definitely a defect. Pics tonight.
Maybe the guy had chemicals on his hand that damaged the leather or could just be a defect, either case I would think the dealer would fix that issue for you with a new wheel.
X2 I have seen this before from chemicals on hands causing this.
  • 3 months later...
The wheel was replaced....the new one is also having the same issues. Someone else posted they see the same thing recently. Awesome.
Could be all wrong but to me it looks like that the leather is really thin and depending on the weather it could be that the 'glue' won't hold on too long. Heat and / or cold makes a difference too.
If I was you I would go to an upholstery shop and have them take a look at it - having this issue for the second time shouldn't be the case.
Mine is doing this also. 18,000 miles owned since new. It's happening in a spot I never put my hands.
The is a reason I always have a cheap wheel cover. I'd rather buy a new cover every few years than replace the steering wheel. So I can't tell you about mine since I had a cover on mine since I had it for maybe 1 week. The cover has held up fine, just has a spot where the material came off that's about 1/4" in diameter so no big deal for now. Even then I could just turn it around if it gets bad enough or starts to get on my nerves lol.
  • 1 month later...
Mine is doing the same exact thing! I had my driver bottom leather seat cover replaced, now I'm going I get the wheel replaced! The whole wheel is completely slick too! 17000 miles
    Greg3160
    Greg3160
  • Who's Online   4 Members, 0 Anonymous, 870 Guests (See full list)
    • After I wrote that reply I went for a ride. 85 F out. So trans started at 85 F and it shifted the same as it did an hour latter at 168 F. I've never actually recorded the to cold to shift point but it is under 32 F before they start hanging on to a lower gear or leaving the converter unlocked. Both intended to heat fluid.    Yes, brake or bake. Absolutely.      Your welcome. True research ended decades ago. Field trials are still in play.    There is a thing called oxidation onset temperature. This is the heat related oxidation not the O2 exposure kind. For mineral oil that starts at 140 F. So what happens after 140 F? Each 20 F cuts fluid life in half! Does using a Full Synthetic improve that? Yes! By how much? Depends on the base oil type and a few other factors. But enough to notice. Some esters are even higher. There are even synergies between types the will raise it higher than any one component is alone.    Then there is "Hindered" oils. Antioxidant additives. Hindered Polyol Esters can sit at 500 F for years in a turbine.   When a blender brags his oil will 'take 500 F" in service he doesn't specify for how long. Water will dance on a 500 F hot plate for several seconds. @newdude put up a chart showing the relationship between fluid temperature and it's life in an automatic transmission. Here's a version of that chart for Group III based oils. These temperatures are those in the pan as observed as 'normal'. that is you drive as you do for as long as you do under what load you ask of it and whatever that temperature is this graph applies to. Flash temperatures of a few minutes isn't what his means.    Note that fluids held at a constant 240 F have a service life of only 20K miles. 220 F explains the factory exchange limit, eh? My equipment I keep under 180 F and I'm good if the cooler will hold it as low as 140 F. But that's me.
    • Im in the same boat. Carlink adapter comes tomorrow and dev account is in process. Would you he able to send the new instructions my way also? Question, do you have to change code and republish app everytime developer updates? Thanks for your assistance, truly the only thing i cant stand about my truck is the carplay limitation
    • Parts department or service department at the dealer.
    • I’ll take the blue one!
    • And Google AI says......... Yes, your truck can technically handle it, but you will be right at or near its maximum limit. A 2016 Chevrolet Silverado 1500 High Country with a 6.5-foot bed has a maximum payload capacity of approximately 1,770 pounds.Weight RealitiesLoad weight: Half a cord of dry hardwood weighs roughly 1,100 to 1,500 pounds depending on the wood type (like oak or hickory).Payload limit: Payload includes the weight of the wood, you, any passengers, and a full tank of gas.The math: If you weigh 200 pounds and have a full tank of gas, a 1,500-pound load of wood puts you right at that 1,770-pound ceiling.Safety TipsCheck the yellow and white sticker on your driver-side door jamb for your truck's exact payload number, as high-end luxury trims with extra features have slightly lower capacities than basic trucks.Expect the rear end to sag noticeably.Drive carefully, avoid sudden turns or stops, and keep speeds low if you have to travel a distance.
