i just bought a 2015 2500 and im wondering how to disable the DRLs. i did it on my 2012 by taking out 2 fuses. i dont see those fuses there. anyone do this on the new ones yet?
I wanted to do the same thing, but alas, they did away with the two fuse gig I had done in the past also. But, I have conditioned myself to reach over and turn the knob to the left and disable the DRL's when I start the pickup. Message comes up on the DIC saying daytime running lights disabled and you dismiss that message. I park the pickup in the garage and can tell that they are turned off. Also, when the wife is driving and coming to pick me up from my semi truck, I can tell they are off if she remembered to do the left turn thing when she started it up or any time enroute. Still seeking a more permanent solution, but this one has me somewhat satisfied.
Some wonder why anyone would even want to disable the DRL's. But those folks never go hunting or dealing with livestock on a farm or ranch.
Edited by Cowpie
yeah,that kinda stinks. I just don't like em on except for bad weather etc. being a mechanic for many years I get tired of changing burned out bulbs and melted plugs and wiring in the headlamp assemblies. that's why I always disabled them on my cars. maybe at some point someone will chime in with a fix for us. thanks
Start the truck, turn the headlight knob a click to the left to turn off DRL's, push and hold traction control to turn off traction control and stabilitrac and good to go.
I opened up the switch, removed the return spring, put switch back together and all set. Switch stays in the off position now.
ok,thanks for all the help. ill try it,i did see the other posts about this as well.
That's an interesting idea. Thanks! I will have to take a look at that.
im going to try this myself as well. thanks
Can't you just pull all fuses found on the fuse box? That usually does the trick.
No fuses on 2015. They figured out we were pulling them and hard wired DRL's.
  • Haha 1
We have a harness that will do it for you if you like tested it yesterday works fine, and we mad it move the DRL to the fog lights like it needs to be.
Edited by 2SSRS
How can we order this harness?
at the web site gen5diy.com sen an e-mail to sales@
  • 8 months later...
Some vehicles the DRLs are the hi-beams. Of all the vehicles that have their DRLs as headlights, about 95% use their hi-beams. Would love to switch my DRLs from lo to hi.
    • Can you sample the pooled liquid, enough to confirm it is oil?   ...That its not fuel or coolant.   Also, make sure combustion gases aren't entering the cooling system.   Simply put, either oil being pushed up past the rings (this really isn't possible), oil leaking past the head gasket, oil leaking past the valve, oil entering through the intake air path. If none of this is likely - it may not be oil.   What could be likely is the fuel injector leaking down. A puddle of gas would still smoke and rough idle. (Same cylinder has the same problem after injector replacement?)   What is the crank time first thing in the morning, when the puddle would be present? Does it seem like the high pressure fuel pump needs an extra second or two to rebuild the pressure that injector 8 may have let bleed off? Check the fuel pressure via a scanner prior to starting the engine.
    • Good information!  I didn't know about the dementia aspect and asked for a general for my second knee. I'd heard that recovery room time is usually shorter with a general.   The anesthesiologist talked me out of it and I had the spinal.  Inconvenience and/or discomfort is a small price to pay for reduced risk!
    • This is for those over 70 years of age contemplating joint replacement surgery involving general anesthesia. Even some 55 yrs. ago when I took my pharmacology class the dangers of developing dementia in the elderly that had general anesthesia were beginning to be recognized. Over the years there has been some refinement in the cautionary warnings, avoid general anesthesia if possible if you've had close to 10 priors, especially over the age of 70 and/or a family history of dementia. I'm not including the twilight anesthesia induced by propofol often used in cytoscopies or colonscopies. Seriously think about seeing a neurologist and undergo cognitive testing before proceeding if any of those criteria apply to you. Spinal anesthesia may be an option in some cases. I'm in the above camp and although I could use a new right knee, I get fidgety according to a prior orthopedic surgeon when the bone saw spools up or maybe it was the smell of saw blade meeting bone, anyhow I may have one general anesthesia left in me which I will pocket for now and I'm choosing mind over mobility, anyway where did I leave my damn cane!
    • We understand your frustrations with your auto start/stop, fuel gauge and cruise control concerns since your latest update, @LarT-26. You mentioned getting repairs completed, however, have your concerns been resolved? If not, we would like to learn more so we may explore the best path of assistance moving forward alongside your local dealership. When you have a moment, please visit: https://s.gmc.com/support-request and complete the request form with all pertinent details. This will help us to better understand your concern and ensure that it is routed correctly. We will keep an eye out for your outreach.
    • We understand your frustrations with being unable to open your Sierra’s top inner tailgate, @smitty81503. Your concerns are frustrating, and we would like the opportunity to explore the best path of assistance to pursue their resolutions. There are many different factors that could be the root cause of vehicle concerns, and we handle each one on a case-by-case basis. When you have a moment, please visit: https://s.gmc.com/support-request and complete the request form with all pertinent details. This will help us to better understand your concern and ensure that it is routed correctly. We will keep an eye out for your outreach.
