Vibration in steering wheel 2015 1500 Silverado 4x2
You guys seem to post useful info, perhaps you can help. In short, I started noticing significant vibration that progressively got worse, beginning around 10k miles (now have about 25k). I assumed tires and went through the usual troubleshooting... balanced them a couple of times, rotated, etc. Stock 20 inch wheels.
I don't have much faith in factory tires, so I replaced them with stock size Michelin LTX MS/2. It rode a lot better for a couple hundred miles, then I noticed vibration getting worse again. Had tires rebalanced. Called Chevy dealer (3 months ago), they were dealing with this issue and had no answers yet and several trucks waiting diagnosis. Started doing my own diagnosis... visited dealer again and he told me Michelins could be the problem. He can put picometer on the truck but they won't fix the center console vibration because it's just something we have to live with according to him. No joke... you can put a bottle of water in the console (60/40 split) and it will occasionally slop out the open top.
To be fair, it rides OK... a lot better than my wife's Jeep Wrangler. But in my mind you shouldn't be able to even have this dissussion... the Siverado shouldn't have this kind of vibration at all.
All said... I'm still feeling a bunch of pulsation in the steering wheel at idle and more vibration up to 1200-1800 rpm. This is a pulsation up and down with overall vibration, it does not wobble like a bad front tire. It has little to no change with road conditions (cracks, bumps, etc). Not much change if at all if you drop it in Neutral. It seems to me to be more related to RPM than speed or road conditions. You do feel a different ride condition if you're on concrete... a little stiffer ride, but that's not the vibration I'm feeling in the steering wheel. Every now and then you get a sensation like a broken shock (remember the 80's silverado's?), but it's not consistent.
Any thoughts or help? I'll get back to the dealer and hook up their pico-meter... I suspect a bad motor mount or some rotating engine attachment with a balance problem. Perhaps other vibration in the frame coming up the steering column. I would think a bad power steering pump except the electric steering kind of kills that idea...
I've driven GM trucks my whole life and I've never seen one that runs this well have this much vibration. When I got in it, it rode like a Cadillac. Now it feels a whole lot more like an old Dodge or really old Ford. Frustrating thing is that it's not consistent... same roads, sometimes different levels of vibration. I am convinced it is not speed related, which takes tire balance out of the equation.
This is Houston, TX... I just realized that the vibration seems to be a little less severe lately. Daytime highs are 90-95 right now, evenings are quite a bit cooler. Perhaps a coincidence... I'm grasping at straws now.
Thanks for any help... or other ideas about how to diagnose it.
Got the same thing, can someone tell me what may cause a tire to change balance points and weights? Is the tire out of round? Had tires rebalanced 3 times in last 2 months and they keep moving the weights around the rim? Chasing the balance!
14 Silverado 4.3...
Dealer told me that one of the vibration causes has to do with quality of the factory tires. They require a road force balance of either factory tires or Continental tires. He won't touch my Michelins. He said it takes something like 20 tires to find 4 that perfectly balance on the road force machine. I don't know if this is my issue, but i doubt it. I still feel the steering wheel vibration even at idle now. For awhile it was most noticeable at 1200-1800 rpm. I may be combining issues... regardless, it's kind of disappointing to deal with this on such a new truck.
Thanks for the posts so far...
Mike- I'm no expert but perhaps you need to try a different dealership. In my situation, 2 of the original tires had flat spots when I bought it. Dealership replaced the tires and everything was fine. Fast forward to my first service-oil change/rotation, went to a different dealership near my work and got it done. As soon as I got up to 65-70 on the freeway, the vibration was terrible. Had a water bottle bouncing around in the cup holder. My first thought was...crap...all those threads on this forum talking about vibrating trucks...now I'm screwed.
Brought it back the next morning and explained the situation. They did a road force balance on it and resolved the vibration issue. Five months and 6K miles later, still good. When I picked the truck up, the service writer asked me where I bought the truck cause the tech that did the balancing wanted to know what ass clown worked on my truck...not too impressed by the other dealerships work..lol.
So, all that to say, you might need to take it somewhere else to get another mechanic to look at it. Not sure where in Houston you live, but I can pm you the dealership that got me fixed up.
Mark
  • 1 month later...
I am also on the hunt on this. What I find is the roadforce balance does well for a couple days, then the vibration comes back. I would be fine with the slight vibe in the rear, the steering wheel vibration sucks period. I also thought bad front shocks or inadequate front shocks. They may not be dampening and what we feel is not a vibration but a resonance. Does anyone know how to disconnect the electronic steering assist?
  • 4 months later...
14 Silverado 4.3...
Did you have any luck with this?
  • 2 years later...
I am having similar problem.  Steering wheel vibrating on rough road or smooth road after going over a bump. I had tires road force balanced but didn’t change anything. I replaced swaybar bushings and endlink bushings few months ago. My control ate bushings are ok. The truck feels solid when going over bumps. It is just steering wheel vibrating feeling loose. I checked the steering shaft under the hood and it has a decent amount of play in it.  Shouldn’t the steering intermediate shaft be solid and no movement?
    • Welcome back! No, it definitely doesn't pass the sniff test. Even "ceasefire" needs an alternative definition these days.    $5.29 at Kroger today
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
    • 2024 Silverado 2500 HD LTZ grille no camera Parts list   84603331 84913656 84913657 84913654 84913655 84911567 84911568 85646092 85646093 85797921 85797922   11570637  x10-15   grille/bumper bolts 11546500  x10      grille clips 11571006  x10      push/retainer clips 11546454  x6       nut retainers 11611609  x6       M5 bolts 11610700  x6       molding/trim retainers
    • And use RA's 5% discount code if you buy from them.  google for the code, one is always available.
    • Just don't turn the steering wheel as much?
