Rear End Bang
Glava2876
My new Denali 6.2 A8 started the 2-1 bang shift that can feel like you were rear ended.
I also have a 2015 Corvette with a M7, but the Corvette uses the same basic 8speed and I noticed some similar complaints about the A8 on the Corvette Forum -so I asked about it on one tread, letting them know it was in my GMC and got this response;
The 2-1 bang is a 0 pedal driver demand issue. The factory table has large negative torque demand at 0 pedal coming down in speed and when you get to 0 mph it demands 77 ft lbs (axle torque) from like -400.
I have been working with the driver demand table in the low speed / low (or zero) pedal areas as well as the downshift speeds/torque converter unlock speeds and have nearly eliminated the issue.
A large percentage (almost all) of the A8 issues are due to poor programming and don't need a transmission replacement. GM needs to crack some heads in their computer nerd dept and write some tunes that work better.
I am not the sharpest tool in the shed and it may not be right, but I thought I could try giving a little gas with my right foot while braking with the left to see if more than 0 demand made any difference. It did and depending on the amount that I pushed the accelerator while I braked, the bang was just barely perceptible or gone.
So is there a way to get a tune to do that?
Big bang for a big buck - sounds like something GM is getting good at.
I am quite sure a good tune can greatly mitigate this problem. I am disappointed that they even have issues like this with the new Corvette.
My truck does exactly the same thing. Our subdivision is on a road with curves and slight ups and downs. At times when cresting a slight incline at about 30 mph when you let off of the gas it feels like the trans tries to upshift and you get the "bang". First time it did this (with the 2nd transmission) my wife took a deep breath and looked at me and said "did someone just hit us?" All I could say was no, it is just the transmission clunk, again. I have gotten used to it now and just ignore it until the truck is gone. Damn shame with such a nice truck. My wife's ATS is smooth as silk. Why does the truck have to be so different?
Mine has done that from day one but after 6 months it doesn't do it hardly at all....could've been the tranny learning & programming driving pattern but not sure
Add clamps on the leaf springs... it will help. Search for more info...
How would absence of such clamps cause a "bang"?
I have no idea... I just know there is a long post about it helping a lot of the bang, rear end clunk, etc, etc... and even trans shifting. I installed on my truck after reading.. and does help. truck feels more planted in the rear as well.
dang, bud, can't you even give me credit when you copy/paste my material? :lol:
Sorry, I wanted to get the information on both sides, but wasn't sure if I should put your actual name on it.
So are you happy overall with the Corvette -mine is my all time favorite car!
Anyway, I'm bringing my Denali in Friday to see what the dealer comes up with and will share what they do -and other than the bang problem, I think that this truck is great.
I am just kidding with you, I thought it is funny we are both on the same two forums with the same two cars.
yes, i like my C7, its a perpetual project..... :-)
i also am very happy with my truck!
Hi. My second car is a Ford Focus and has a front end bang. You think I could join your guy's club. lol Ehh.... never mind I'm just jealous. New truck AND a Corvette! I should have stayed in school.
But on a serious note I did just call and make an appointment to have the "bang" issue checked out on my '14 Z71 and I was just wandering if you guys know where exactly the banging is occurring at? Is it the trans? The slop in the rearend? U joints? All of the above? I'm trying to get mine fixed before I get my tune.
It's hard to tell where it is occurring mechanically.
I had the rear end bang and the dealer ended up finding two bolts in the trans were not at all tightened at the factory.
When I saw the title of the thread I thought this was going to be about something more exciting!
Sorry, my mind lives in the gutter sometimes...
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
