Anyone with a 1inch level or 1.5" leveling kit
I having a hard time deciding between a 1in or 1.5in spacer. I want at least 1.5in or rake. I don't carry anything in the back, except for a regular tool box, loaded with junk.
In the same boat. I want to raise the front a bit to take some rake out but still have a small slant.
From the pictures, even the 1.5 looks very level. Figure a spacer is cheap enough until it's time to get new tires and I can switch to bilsteins.
  • Replies 92
I debating on putting a level on my new 2016. I know if I do, I don't want more than a 1.5in level this time. I would like to have at least 1.5 in rake. But it seems those that have this kit are only seeing about 1in of rake.
The only 1.5 level I see is this motofab - http://www.motofablifts.com/product-p/ch-15lm.htm
thoughts?
This seems like a very high quality kit. The price is great.
I wonder if anyone else has tried it.
I love it...no regrets. My trucks sits perfect IMO. Glad I picked the 1.5
Sent from my XT1254 using Tapatalk
Oh, you already did it? Thought you were considering it.
Any pictures from the side?
How way the install?
I'll try to get a pic soon. Install easy...just bolts under the shock
I have a 1.5in motoFab level kit and love the look. After a Line-X bed liner I have .5 in of rake. I tow a 5x8 utility trailer with a 4wheeler and it isn't nose high but put approx. 300 pounds of gear in the bed of the truck and its nose high. 90% of the time I'm not towing or hauling anything though and I love the way it looks. Saving up for a summer wheel/tire combo because 265/70/18 tires on stock rims are just a tad skinny.
Vinny, you got pics?
I recently added 275/60/20 tires with 1" level. Can defiantly tell the front is higher with still some rake. I am also going to add spray in liner that will drop the back end some. If I had to do it over again I might go with 1.5, but overall I like it with the 1". Its much better than without.
I have bilstein 5100s set at the middle setting. It's about 1.25" of lift. Perfect height for my taste.
Do you have them on all four corners?
I installed Bilstein 5100's on the max setting. I gained 2" up front and at no point have I thought that the front looks higher than the back.
That being said... You could also go with 5100's on the second highest setting which I believe gives you about 1.3" of lift. Might be exactly what you're looking for.
Yes. No rear lift tho
2016 Double Cab, 1.5in motofab. 275/60/20 BFG
Perfectly leveled. Very nice. Great looking truck.
What do these tires measure out to? 33"?
Yes, I think the 1.5 level is about perfect for these trucks. Truck also rides much better when compared to 2in + level.
