Appropriate oil life
Drove 1,225 miles in 19hrs yesterday (two fill-ups) Engine oil life decreased from 34% at the beginning to 16%. Does that seem right?
About right, if you do 1225/7500= 0.163 then 0.163X100= 16.3%. 34-16= 18%.
That would be for perfect driving conditions. Gotta factor in rev ups(hill climbs), temperature, humidity, road conditions, etc.
Thanks... Didn't realize the basis for the oil life calculation was 7500 miles. Diesels must be really rough on oil. My 5.3 would only decrease like that if it never warmed up.
Sent from my LGLS990 using Tapatalk
Oh wow, didn't realize that it was under the HD k2 section. I was going off of the gas engine recommended mileage. I belive the Dmax is every 10k miles, so yeah it did decrease faster than it should. All I saw on tapatalk was 2014+ k2 section lol
That is okay. My 2014 would normally hit about 11k on oil life
GM oil life algorithm is not based on mileage but it does have a mileage cap at 7500 miles.
Condition/Concern
Since 2010 all GM vehicles have been equipped with the oil life monitor (OLM) system
The monitor calculates the percent of oil life remaining, based on 3 pathways
The OLM starts its calculation for all pathways after the first 50 miles to account for marshalling and time before sale. Subsequently, calculations begin immediately after each reset.
Recommendation/Instructions
Oil Life Monitor Calculation Pathways:
  1. Engine revolutions- Oil life starts with a fixed number of revolutions and will decrease with each revolution. Cold / hot coolant temp readings have multipliers that reduce engine revolutions pathway quicker depending on how far from the normal oil temperature the vehicle is operating.
    Note: If engine coolant temp gets above 260F, engine overheat condition, the oil life will go to 0%.
  2. Mileage from last reset – Starting with MY 2013, the OLM is capped at 7500 miles for all GM powertrains except the Volt. In perfect conditions a vehicle would reach 7500 miles from the last reset and the oil life left would be 0%.
  3. Time- This pathway is a liner function, a fixed decrease in oil life for a given time after the oil life is reset. The oil life will drop to 0% after 1 year regardless of the amount of engine revolutions or how many miles since the reset.
    Note: The Volt uses a 2 year timer instead of 1 year. It also uses the engine revolution counter. It does not use the mileage pathway to count down.
  1.
I have to pull the service tickets for my wife's lacrosse... Swear it's going longer.
GM has their OLM calculation thing going on, but I have mine. My 6.0 gets changed at 6000 miles. The manual makes it very clear that any severe service may require more frequent oil changes than OLM suggestion. I can't even leave my driveway without encountering one of the severe service classifications according to the OEM. And the OLM cannot calculate for everything. It doesn't have a clue if I am in dusty conditions or not, for one. If the GM OLM is using some form of "algorithm" to determine things, that is fine. It still cannot measure everything.
On diesels, I have generally gone 10-11K on smaller stuff like the 2.8L diesel in a 2006 Jeep Liberty, up to 25,000 miles on my commercial trucks. Since all the OEM's have dialed back the amount of EGR that is getting ingested by motors now since the advent of SCR, there is really no reason a diesel could not go 10-11K on an oil change for the average user. I wouldn't pay any attention to an OLM for a diesel either.
I ignore the oil life meter.
Why?? I think these are great. I get mine changed at about 12% life left.....
    • Folks, Have a great new 2026 WT  (std cab, 2.7/4WD) w/base 40/20/40 mech adj bench "fake buckets"  (with lower and upper center console) heavy vinyl seats.  Overall the seats are very comfortable and the vinyl is heavy and appears less likely to 'split out'. Am very tall (6'5")  + a bad back/osteporosis/former hyperparathyroidism so ease/range of movement is a bit restricted.  The truck rides a bit high and I use a nerf step bar w/my left foot to step in, then I put right foot/leg in, drag my butt in  & get seated.  Worked fine in my 2018 RAM quadCab. But I end up dragging my butt over the left raised sidecushsion area of vinyl seat, and due to texture there's fair amount of traction on slide inward.  (ArmorAll didn't improve.) If the seat were even ~1/2" - 3/4" lower it'd be helpful, but base seats just have the forward/backward underseat bail and the side lever for tilt which really doesn't affect seat height.   I really don't want to 'de-puff' the left side sidecushion forming the  fake 'bucket'. I know one company sells 'seat elevator blocks':  but is there a simple way of lowering the height of the driver seat instead?   Thanks Bill W San Jose
    • I have a basic 2026 1500 WT  (2.7L/4WD reg cab shorttbed). Comfy, generally happy with electronics/radio - but is there a way I can add switches to steering wheel right-side position (curr. empty) so I can adjust volume, push phone button to voice dial, etc? Bill W San Jose
    • The curb weight on a 1 ton crew cab long bed is around 7k lbs.  Now, I don't know where you went to school but 9k is not more than 2x 7k lbs. More than 2x 7k lbs would be 14k+.   With that said, obviously yes you're going to feel a 9k lb trailer when slowing down.  I already said, when accelerating.  When changing lanes?  No.  But if you look at the context of what was quoted, the original person said, "after a mile or two..." which means that would be after the accelerating portion and you're driving a generally steady pace.  Please do learn to read and comprehend.
