2016 Siverado Rear Heat/Cool?
It is a crew cab..... If you want rear climate control get a tahoe.
Sent from my Note 4 on Tapashit
I never understood this line of thinking. Many of us with crew cabs often have...a crew! Whether it's grown adults or young kids, shouldn't they expect comfort? A legitimate argument can be made that the front vents are sufficient, but why is having rear passengers considered taboo by so many people? Yeah, I haul my family around all the time, but quite often, it's with a half ton of drywall or lumber in the bed. Or a yard and a half of mulch, or compost. I can't do that very easily in a Tahoe.
  • Replies 53
I apologize if you understood it that way..... I was talking about the climate control specifically. When it comes to hauling people.... Thats what it is for and why most buy double and crew cabs. I just so happened to put stuff back there that i want out of the cold/elements since i travle alone. I do have friends that pile in and they seem comfortable in th back of the double cab..... But like i said.. I dnt sit back there so i dnt care lol
Hauling people, gear, trailers and generally all our crap is why we buy trucks.
I just dont see the rear climate thing as a big deal. But that's me, obviously others feel differently.
Is there rear heat/cool ducts to the rear (back seat) on the 2016 Silverado 1500 Crew Cabs?
Yes, there is an under seat duct.
(at least in my SLT )
Don't know it it is a supply or return air duct.
Yes, just like in the 2015's. They're beneath the seats and work fine.
I haven't had any complaints from rear passengers -- the floor vents seem to work fine. And for A/C cold air drops so using the front dash vents usually gets plenty back to them.
As for the flat floor, the one on my 2015 isn't that bad. No it's not completely flat but it's pretty close. What I would rather have is stowage boxes below the floor similar to the Dodge minivans so that I can keep some tarps/bungees/ratchet straps stored there and still have a flat load floor.
"I bet 20 forum bucks GM's next bodystyle has rear console vents.
And heated rear seats
And flat floor."
And, 36 gal gas tank option like Ford offers.
And, towing mirrors option on models below High Country such as LT, LTZ.
And, Gear Display next to the V-8/V-4 Display. Would be beneficial when towing to know what gear you're in.
"No. There are some useless toe vents for the heater but they do nothing of real value."
I have a 2015 LTZ and was not aware of the toe vents till I read the above post. Curiosity got the best of me and so I checked it out. Sure enough, there's one under each front seat. Then, my curiosity still at work, I wanted to see how strong the air flow was and turned the fan wide open. And, there was zero flow from the toe vents. I had the air-flow controls set for the dash vents only. So, tried the floor vent only and got pretty good flow from the toe vents and the same from the dash/floor combo and the defrost/floor combo. But, got zero flow when setting was on Auto. So, to sum up; toe vent flow is decent when using any duct setting other than Auto or Dash Vents only. Live and learn I suppose :)
They'll work on Auto when needed, just not constantly.
"They'll work on Auto when needed, just not constantly."
Thanks. I went to the trouble of looking for this in the manual and its there. Guess the toe vents must source its air flow from the floor vent. Therefore when the floor vent duct is closed no air blows from the toe vents either. Pretty soon GM is going to have to offer a new vehicle training class. I'm still trying to figure out all the bells and whistles in the Infotainment Center. Oh, did I mention that I'm old? Could that be the problem? I'm thinking so
And flat floor."
On 1500's tow mirrors are available on WT,LS, Custom, LT and LTZ, but not on High Country.
On some trims they are only available as part of a package.
On Sierra they can be had on all trims except Denali.
And vibrating seats at the touch of the switch for those who have become a custom to the feeling. :rollin:
yes why should anyone want some luxury features in a 50k+ luxury truck or even some standard features, it is a just a truck.... I must be the only one who's wife who is always cold and wants to turn her temps up or close her side of the vents. Nothing worse then having your side on low while the passenger is on 70 haha. She "hates get blown on" so they get closed, I have to yell at her to at least wait for the cab to cool down
    Bulldogger
    Bulldogger
  • Who's Online   4 Members, 0 Anonymous, 847 Guests (See full list)
    • Around 2008 if memory serves they took sulfur out. That was when diesel went up.
    • Question for you Grumpy, why is diesel so much more than gasoline? Seems to me that it may be slightly a little less refined than gas and it doesn't have 10% alcohol which presumably lowers the price of gas
    • Thanks, so being a different beast altogether, anyone know what the "optimal" temp is for the 10L80/90 for proper shifting?
    • How many years have I pointed out every point in that link to the folks here and been avalanched with criticisms and outright hostilities at times? I ran counter to even the great CUSTOMBOSS and Lake Speed Jr and the half dozen experts on YouTube and in the final.....GM, Physics (Stribeck) backs that Grumpy old Bear.    Honestly, I never said a thing engineering hadn't studied silly and laid in concrete during WWII. But I'm old, the information is old and yet, the Laws of Physics are eternal.    Okay there is one exception. I vehemently disagree with their use of the word 'tolerances' when what it meant is "clearance".   The clearance is the distance between two objects. The tolerance is the degree of acceptable variation permitted in that clearance. I.E., piston to bore clearance is 0.004" with a tolerance of +/- .0002" so the clearance is in specification if it lies between 0.0038" and 0.0042". Cutting that 'tolerance in half has ZERO impact on lubrication requirements. Makes for more difficulty in manufacturing.  But a tighter clearance 'MAY'. Depends on finish. Anyway....   It's one of those statements made by people to make themselves look smarter than they are to convince people who are as un-enlighten as they seem to manipulate their behaviors. But hey, the blind leading the blind puts them both in the pit.
    • Out and about yesterday on a long Saturday drive I passed a lot of Shell stations. My preferred, so I pay attention. Lot's of small town Illinois so not six stations in three blocks like the city.    Everyone of them over a radius of say 100 miles had regular at $4.19 but one which was the one closest to home at $4.15. However Premium pricing varied greatly between 85 cents over regular to $1.50 over. I'm not counting the price of the station with the lowest regular so the reference is the same for the remainder and all within the same brand. However the spread discrepancy holds across all brands.     @txab, any thoughts on that?
