Diablo Tuning 2014&15 5.3
jonboy77
I just bought a T1000 and have been trying to read through the 50 plus pages but there is so much info on the 6.2, 5.3 and scattered post in the discussion it was over whelming. So, who has a 5.3 tune with a Diablo tune and would discuss what tunes they like, dislike and beginner info? What is AMF and TM?
AFM = Active Fuel Management. I believe Diablo calls it DOD instead. Just when you think you have it figured out, another acronym to keep track of...
I have found that using to much throttle boost will hurt transmission performance.
I have a intune i2 and my settings are 87 octane tune with modified stock trans
Dod turned off and all shift pressure up 10%
I noticed much better performance feel from the transmission with the throttle boost at 0%
I have tm turned off and trans line pressure turned up all the way. It still doesn't seem to shift very hard. What is nice with the Diablo is that you can change the trans settings for normal mode and diff settings for tow haul mode. So you have mild to no trans tune in normal mode, but turn tm off and boost line pressure in tow/haul mode for spirited driving. I have tm and line pressure maxed in both normal and tow haul mode. And of course adjusted for new tire size and got rid of the 98mph speed governer.
I have just a firm shirt tune and limiter removed drives great shifts are definitely better in 2wd. The only funky thing about the firm shift it bangs at wot and on down shift from 2-1 or any gear to 1 or 2 in auto 4wd drives great in 2wd so not sure what the issue is on that one haven't tried tow haul mode yet to see if it plays nicely there..
(Only mod on truck is a ported throttle body).
With an i1000 are there threads specifically for them. I want to read up on them before I plug it I and screw something up.
Go to the Diablo forum and read all the issues with the tunes. Make sure you try to install the tunes in a location you can leave the truck sit in case it bricks the ECM. Yes, I have one from my 2011 GMC and no, I won't hook it up to my 2015 Chev.
  • 3 weeks later...
I just set up the 87 octane tune and didn't mess with line pressure just did tm off firm shifts tune just waiting for it to finish to try it out hopefully didn't mess it up first time messing with a tuner
Sent from my SM-G900W8 using Tapatalk
Horrible issues with my Diablo Trinity. Try to install it on my 2016, and no such tune exists. Contact customer support weekly with zero updates. Finally update tuner again, and still doesn't pull up a 87 octane tune.
Now it won't let me return to stock tune, it says it already is. But it obviously isn't, I turned the AFM off it. Now there telling me to reflash the computer at the dealer. I'm unsure how that will work...I suggested just sending me a sprig device, and all I get are 1 sentence monotone answers whether it's via email or phone.
Does your 16 have a 6 speed or an 8 speed? The 8 speed isn't supported yet.
    • Okay boys and girls I put a bottle of this in Dizzy the oil burning guineapig after a tank between the coil and plug service of the #3 hole and near the end of the first R&P 5W30 attempt. As a note I did a two R&P oil changes back in October of 2025 with little effect. Granted they were 1K mile a shot oil changes so.... Then followed by fourteen  1K mile changes of Mobil 1 Euro 5W30 FS. Also ineffective.    Anyone who has followed the adventures of Dizzy may remember that to put the oil on the full mark of the published nominal 5 quart change I withhold about a cup of oil. That over the last 50K miles the P0420 light has been a frequent flyer, sometimes three of four a day. And that even on 93 octane fuel she registers some KR even in moderate conditions on favorable days on slight inclines. Lastly when giving her a kick in the pants, something done about once a week, she looks like a diesel with the pump turned up. 😬   After one bottle and over the last 500 miles of a 3K mile OCI, of the first oil change I dropped the nastiest looking oil ever in her history. That's saying something as  you will recall I have used AutoRx, HP EC30/40 and a few other harsh solvents in her before including the GM top soak twice. This was syrup. Black stinky, inky syrup but the filter wasn't all that bad.    On the second fill I had to use the entire 5 quarts to reach the full mark. That was unexpected! The ignition KR is completely gone! Even at 99% engine load. MAP is much lower. Level road is now 9.8 instead of 12.5. Fuel economy is remarkably higher and for the first time since her earliest days she will spin to 6500, more than a thousand higher with out laying down dead. Yes, the coil and plug had something to do with that but remember the first 2500 miles after that repair on the first change it was same ole same ole Dizzy. Seems we have top rings that are somewhat functional again. P0420 code only comes on now if run in town for more than an hour of stop and go. On the open road it goes weeks without a incident. Perhaps it is cleaning the cat on the pass through?  Fuel Trims have improved as well. Nothing not to like.    To early to say about oil economy but the changes to date in the operational aspect is remarkable. I can't think of a worse case than Dizzy.... It's already paid for itself in a few tanks of fuel with the mpg improvement.    @OnTheReel, I'd say if the Jeep didn't respond perhaps there wasn't an issue to respond to.    I've run the Red Line SI-1, AMSOIL fuel cleaner, GUMOUT and Techron all in this SUV without any such results. Color me impressed. I'll be running out my supplies of the list mentioned and moving on to the Valvoline R&P Fuel System Cleaner.
    • Hey Chuck !!Thanks for the all the info I'm an old fart and I have everything I need for the oil change at home,minus flexibility .... and I’ve been doing my own oil changes for 40 years. I just didn’t want to end up without a crush washer or with the wrong one in my stash and have to walk to the auto parts store, lol. I climbed under the truck to check the location, and man, it’s going to be the easiest oil change and filter swap in the last 40 years—right up there with my 2014 Mitsubishi Outlander 2.4. No mess, nothing to drip on—just perfect. I’ve got one more free oil change to use, and then that’s it with the dealership!
    • I think this subforum was created for the new generation pickup trucks (2027-) with the 3.0 but I don't think it's a big deal either way. There are probably 2027 model-year specific changes for the SUV's too.   I was just curious if you had issues with your 2025 3.0. I'm still under 10k miles on mine and fingers crossed I don't have thrust bearing issues. I'm guessing not, since you're willing to buy another one! It's a good engine minus one or two manufacturing whoopsies.
    • Wife has enough metal in her she hides from the scrapper.
    • Djannoyed was a one hit wonder. Posted and disappeared.
