Did they forget to reset the OLM when they changed the oil? Oil level and OLM have nothing to do with each other.
Very true. Devices like portable generators actually have a low oil shut down switch which will automatically cut off the engine if the oil level drops too low. this is to protect the engine which may run unattended for a long time. Normally cars and trucks ar e not equipped with such devices.
Am I reading that some people on this forum have to take their truck to the dealer to read the dipstick?
  • 2 years later...
I have a '15 silverado, 5.3L v8.  I've got a couple thousand miles to go before I'm due for another oil change (I go about 5K per change).  I got the low oil level alert.  OLM's at 60% FYI.  I have not seen any oil spots in my driveway so hopefully there's no leak.  The other times it's been changed, I've gone as far as where the OLM is at 30%.  Never seen this alert before so why now?  I checked the oil cap to ensure it's on properly.
Did you check the oil level with the dipstick?  Maybe look around the engine and underneath the truck for any sign of a leak?  You may want to install a catch can, as the oil may be going through the PCV system...
  • 7 months later...
On 2/29/2016 at 11:37 AM, Kerrslight said:
I used to check the level after an oil change but I've been going to the same place for years and never had a problem. I will probably check after work and see what it looks like.
I see how that could be confusing. My reasoning for saying the oil life is at 70% is just me saying I didn't have the oil changed that long ago. I know it has nothing to do with level, but I figured since it hasn't been too long it must've burned a lot of oil, has a leak, or just wasn't filled properly. I drive about 30K a year so I've been doing some driving lol.
All in all I was just curious if anyone else had a low oil level warning not long after an oil change. I will check when I get home and if I find its low, I should be able to have the shop top it off.
My gmc does the same exact thing I was reading the comments up and with the adding 8 quarts instead of 6 imma try that but I even took my truck to the dealership and they couldn’t find anything wrong I’m at a little over 80000 miles and a 2016 so if anyone else knows why please let me know. Thank you for everyone with their thoughts !
If you have a 5.3 or 6.2 2016 1500 pickup its takes 8 quarts not 6 to begin with.  Hopefully you haven't been underfilling your truck this whole time...
Edited by newdude
REALLY ! ?
No they’ve been putting 8 I checked the paper work  i thought they told me 6 but my dip stick isn’t reading anything and my truck computer is saying add oil when I literally just got the oil change like I said I took it to the dealership they did their test ****** and they can’t find anything wrong with it so if anyone knows anything let me know and my truck I barley drive it so it’s not like I’m driving miles and miles a day
Have they checked to see if the dipstick is in the correct position? Correct one for the truck?
What does your OLM say for a percentage after they change the oil?
Edited by JimCost2014
  • 4 years later...
    250.3k
    BDS my HD
    BDS my HD
  • Who's Online   0 Members, 0 Anonymous, 555 Guests (See full list)
    • Hello hello looking forward to expanding my knowledge of the 2026 2500 HD that I just bought.   Truck has 3500 miles on it four-wheel-drive crew cab and I’m about to put a 6 1/2 inch BDS lift on it 18 x 10 -25 offset with 37’s   Already have the wheels and tires just waiting on the lift install in about three weeks   Question what surprises am I not gonna be happy with?  I’m not new to lifted trucks so I know that acceleration towing gas mileage all that is affected..   Question is those of you that have this truck this powertrain with a 10 speed Allison and have done the mods that I’m doing,,, how bad is it? Is that Allison constantly gonna be hunting for the right gear to go into? And what about towing, acceleration, fuel consumption as mentioned?    Lastly how come I can’t find any ring pinion gear set up for these axles and when could I expect to see them?   I apologize if there’s any typos I’m doing speech to text on my iPhone.
    • I've got a 2013 2500 6.0L Flexfuel. Drove the truck earlier today with no issues. Went to run an errand tonight and noticed key fob wouldn't work. Figured battery was dead, so replaced fob batter. Still wasn't working. Grabbed my other set of keys with the other fob and that one wasn't working either. So I manually unlock truck and insert key. Interior lights come on, dashboard lights up, turn key and truck starts. Turn truck off, like a moron, and try starting again. This time no crank, no click, no nothing. Lights still come on and dash lights up, but now I'm getting a service 4wheel drive, service tire monitor, etc. Check voltage on battery and Im showing 12.2v. Throw my battery charger on it and give it 15 mins and try starting again. But still no crank no start. Decide maybe its a bad battery, run to autozone grab a new one and put it in. Same issue. Disconnect battery and let it sit for 15 mins. Try again and still nothing. I had managed to roll the windows down earlier as its a humid night, but now I can't get them to roll up. Power locks are also not working now. Then randomly I try the key again, and it fires right up. Immediately I roll up the windows as we have nothing but rain forecast this week. I shut it back off wait 30 seconds and start up again. Worked a 2nd time. So turn it off, start putting things back together. Try one more time, and back to no crank no start. And now the car alarm starts going off. Had to disconnect battery and leave it that way for the night as I don't think my neighbors would appreciate my alarm going off again tonight. Any thoughts or help would be appreciated.
    • No one will care for you like you care for you. Do what you can for as long as you can. IMHO of course.
    • How about them NICKS!!!
    • Hi there.  Long time lurker, first post.    i have read the previous posts regarding the water ingress problem with this emblem.  I bought my 1500 SLT the  summer of 2025 new and after reading the MANY problems with these emblems failing I decided to install one anyways.  As per a YouTube video, I sealed ( or tried to) this sign with silicone sealant around the outer perimeter joint and the holes that were already somewhat sealed on the rear plate of the emblem.  And installed the connector assembly using dielectric grease on the connectors. The installation looked great and worked well for about 4 months……then FAILURE.  Grrrrrr…… I live in the great white north and wash my truck weekly in an automatic car wash  to keep the salt off.  Let me tell you that removing the old, failed emblem is a whole different animal than removing the OEM individual letters without removing the grill assembly. Mainly because the illuminated logo is built differently than the original letters which  you can remove the red surface lettering with a knife or some kind of blade which gives access to the tabs which hold the logo onto the grill. So I had to essentially destroyed the old emblem to remove it. Doing so killed my chance of doing somekind of autopsy on the failed , old logo.  But there was plenty of water inside when I ripped it apart.  Prior to installing the new assembly I tried it with the old harness and it works fine.   Does anyone have any insight as to where the water is getting into this emblem? I intend to seal the new logo with slow curing epoxy this time around using a syringe.  I think this newer emblem may be an updated unit which I hope GM got the vendor to fix. It has an October 2025 date on it.    If this one  fails,  I am just going to revert back to the non-illuminated letters….AFTER PULLING THE GRILL.    Any thoughts on sealing with epoxy would be appreciated. Thx!   Doug
