Which Cab / Bed Style Looks Best ?
943 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
one of my friends told me my truck looked funny the other day because the nose was too long. I think anything with more than two doors looks funny.
  • Replies 233
Lol really? Whatcha smokin' ??? I think any truck with less than 4 doors looks too cramped and entry level [emoji3]
Sent from my LG-V495 tablet using Tapatalk
that's why they sell them both ways.
My truck is far from entry level
For me it is between the regular cad short bed and the crew cab standard bed. Oddly enough, I bought neither. I have a crew cab short bed. That decision was based on function rather than form. My wife will have a hard enough time driving this one, much less a standard bed that's a foot longer. Availability had something to do with it as well. I found a deal on a used 2016 CCSB I couldn't pass up.
How do you tell the difference in a short bed and a standard bed without measuring?
Can you tell by the gas cap door?
Besides having an eye for the bed, yes, the gas cap door on the standard bed is flat and contoured on the short bed
Sent from my SAMSUNG-SGH-I727 using Tapatalk
Thank you mafd2.
I must have the Crew Cab 6'6" bed because my gas door is in a flat area.
My Work truck is a 2016 Double Cab Long bed 2500 and it takes a 40 acre field to turn it around.
Thank you mafd2.
And the Crew Cab Long Bed needs even more !
Imagine it with a 30' boat trailer and having to back it up ...
I prefer the crew cab with standard bed, but I guess that is what I am use to. My last three trucks have been crew cab with the 6' 6" bed on them, oh and they all came with 20" rims and tires.
You mean something like this? Even harder when one of your trailer brakes decides to lock up during backing lol
That's a standard bed though... at least from the pic it does, based on the wheelbase length
Sent from my SM-N920V using Tapatalk
    DaleB
    DaleB
  • Who's Online   7 Members, 0 Anonymous, 1,139 Guests (See full list)
    • You must have that upgraded gvw package which is only available or at least was in 2025 with the diesel engine for the 3/4 ton and that gave the truck physically the larger 12.0 ring gear rear diff and the 3500 rear spring pack. There is a difference in what the diff housing looks like externally as one tell tale and also your truck should have the upper overload spring pack and the frame pads that the pack goes up against.    The pressure the tpms system kicks the alarm in on a stock setting truck, that is a good question and was just from what I recall but I doubt I made any notes on it as I knew for the rear that it was not at all what I was after regardless either. Being that you have a diesel and if running on stock tires the minimum pressure on an empty truck seems to be around 50 psi from hearing of those that have weighted the front axle but the rear axle is very similar in weight to a gas truck and again a near empty truck on the rear could go down to 35 pounds at minimum. However the weigh scale is the proper way to know for sure as a guide.    As to changing the readings on the dash from metric to the US measuring system, oh yes that is done easily but what I was attempting to explain was that I can't pick and choose items I want to have in US and those I still want in the metric system at the same time as its either all or none. For example lets say you drove into Canada and switched your dash over to metric so your speedometer read in km an hour, well then your reading kilopascals on your tpms readout and your wife looks over and says what the hell is that saying in the tpms screen and you say "darned if I know, I think its Chinese" !
    • This is partly why I decided to have switched over to Amsoil SS as a way of hopefully preventing the buildup of the sludge/carbon on the pistons and clogging of the oil control rings and the carbon that would cause the compression rings to stick in their grooves as well as stay cleaner up top of the heads in the valve train in the first place, an oil that has tested better by third party testing over typical shelf oil and also doing my best to run relatively short OCI. However in saying that I don't think there is any way to easily prove the oil I was using prior allowed for a buildup at the OCI I was doing, nor in the other direction to make claims the Amsoil is keeping everything clean either. There really isn't a window into the engine is there to know anything for certain even if oil samples were taken for example that showed still healthy oil being dropped out of the oil pan other than engine tear downs that extensive and expensive testing of oils does to actually visually see what is really going on inside the engine. I wish there was some easy method of seeing what is going on but I don't happen to be aware of that if there is.
    • My truck is a ¾ ton but my placard also says 80 for the rear tires, I think I might have the upgraded suspension to the 3500 series maybe.   I put my air down to 60 and the light was still on, and there was no way I was putting over 60 psi in the rear empty and not towing because I knew the actual number Toyo gave me and I didn't wanna ruin the center of my tires!   And you actually can change it in the settings from metric or is and it will show kph or mph then when you go into your tire settings it will be either psi or kpa, but it would be nice to just change it directly on the tire psi page
    • Common Sense Assembly   Your driveline is forgiving of the occasional mistake. It will even often forgive the random serious blunder. But it will not forgive a continuous bad habit.      What? Not everything needs to be a five thousand word essay.
    • We drove about 15 minute east today to visit a friend and saw a steep increase in price in the same county. About 50 cents a gallon steepper.
