Headlight Illumination Issues
deputy
Comments by a new '16 owner is that the '16 headlights are way better than his '14 that he traded. I noticed the projector is much bigger for the '16. Shame there is not a easy way to swap for the '16s. Or maybe there is?
  • Replies 1.9k
Knowing GM, probably a total different assembly, not compatible with our vehicles made earlier. I did ask my dealer and he is checking, But I will lay odds that if by a slim chance they do fit GM will want a small fortune to upgrade them for us.
Working on it. Believe me, dealer will be no help. Dealers said SLT lights couldn't be fitted to SLE's. Ofer and Jared figured it out and designed a harness to make them to work. The '16 lights will bolt up to the '14/'15's but they use the newer round plug instead of the rectangular plug. GM is starting to use the round plug on all their vehicles. As soon as GM releases the SI wiring info on '16, Ofer will start working on the harness. The '16 lights aren't cheap and by the time you add the harness it will be a small fortune. But for those who want to spend the money, we're almost sure it can be done.
And the '16s are HIDs and LEDs on upper trim. Not sure how that will work with the BCM etc on the '14-15s?
Escalated issue to GM nothing done. The GM rep tried to offer me a $200.00 voucher, My truck is still under warranty 14654 miles I don't want the voucher I want my headlights fixed.
She then told me that she was going to close the case, I asked her why? The issue was not resolved, she still closed my case (Unresolved ).
GM moderator answer this.
M
After reading this I went and pulled a bulb on my 2015 Denali built mid May 2015. The bulbs are made by Phillips in Germany 55 watt 9012. I don't have any problem with lights.
the new 16 lights are much brighter but i don't believe they shine farther than the 15's? idk. i have friend's with 15 silverados and sierras and they're fine. my High Performance LED Headlights are way brighter though
can you take some output shots of the lights and maybe comparison shots?
Man I've dealt with so many shitty headlights on my vehicles that I can't even tell if mine are bad or not. They seem great unless the roads are wet.. But I thought all headlights suck on wet roads?
I have a 2015 Silverado with projector beams, I tried the hid kit from carzenonkits, the lights were junk, I was very disappointed, the lob beam actually overheated after an hour and stopped working, I also couldn't see at night when the road was wet, I asked for the 4300k... I think they might have been the 6000k? This has been a very expensive mistake, I just went with the new 4000k piias, they were way better than the hids
Same problem the GM dealer has encountered with installing HID kits here, now they refuse to waste their time. They had manufacturers reps from the various kits try to resolve the problem, but so far no success. I tried led lights, without success now I have a led light bar behind my grill and that works great, but I have to get the dealer to connect it to the dimmer switch.
I would consider a hid kit if it wasn't made in China or a third world country, and it was guaranteed, this isn't going to happen.
    • More is cylinder deactivation. Kia-Hyundai Ive had 4. The warranty is the same 10 years 100K miles. My grandson drives the first one 05 Elantra GT. My wife drives the second one 2011 Genesis. The Genesis still performs as new and looks great. The Elantra looks rough. He’s not kind to it. The third was a Genesis coup. The fourth was a Santa Fe. Those were my daily drivers. I don’t keep them long. Kia is the same as Hyundai with the same warranty. I looked at the K-4 today. Too small, otherwise pretty good buy. Most of Hyundai and Kia’s have a performance upgrade.
    • Thanks for the point of reference
    • Great question. Answer....depends. One the volume of the crankcase, the driver that will actually be using the vehicle and the amount it uses plus the distance expected for that next trip. Couple of for instances:   Wife is going to drive Dizzy to Moline and back plus a bit around town so say 500 miles on the day. I know from years with that SUV that around town and local rural it uses about a quart in 1250 miles. But on the Interstate and her at the wheel without her anchor nagging her she'll push it and it will drop a quart in about 800 miles. Hence, around town I wait to somewhere between a quarter down to a quart down. On her trip I'd top it if it was down a few ounces and hope for the best.    Have I overfilled one? You mean by adding before it needs a full quart I assume. No, not once after finding the true fill mark.  I know the dipsticks of everything I drive and add what it needs. I learn this by doing the first oil change a quart low. Run the motor for a few minutes. Let it sit over night. Check and mark. Then add half a cup at a time making note of the place on the stick. I add through the dipstick tube with a barbeque basting bottle. Give it a few minutes to drain down and check again.    A vehicle like Dizzy that uses this much oil will take a few quarts between 3K changes. I keep one in the vehicle with the bottle and a bag. (Mindful of it's fullness) Not a big deal and never makes a mess of it. There is no such thing as "multiple quarts' in my shop for any specific oil. There will be a maximum however of the number of different oils used over the fleet.     Dizzy holds a nominal 5 quarts. So the first fill was indeed over as it actually took 4.75. My vehicles are fit with Valvomax valves so I can meter an ounce on the drain if need be. Found her mark first crack at it. Never to be repeated.    Pepper uses none between changes so I don't keep a quart in that one. Straight up 6 quarts put her dead on the full line. Check it ever fuel stop. They will surprise you when they start using.    Raven holds 3 liters or 5.44 ounces over three quarts. I add 3 quarts and 6 ounces. That gives me 5 oil changes on my orphan quart.    Lawnmower holds about 3/5 of a quart. I don't over fill it to prevent an orphan. So yea, depends.
    • 185k on original 6.2L engine and 10 speed. 6" lift with 35" tires. Changed oil (Mobil 1 synthetic) when truck told me to. Original tranny with original fluid and no service or flush done. All highway miles. A/C compressor replaced at 155k. Oil cooler line replaced at 180k. Still daily driver. Love this truck.   This is my 3rd 6.2L vehicle (2008 Yukon Denali / 2018 Cadillac Escalade) with over 150k miles and no issues. Denali had broken motor mount at 100k.
