Active Fuel Management kills another lifter
Like another poster said, this isn't an LS engine, so your Google search is meaningless.
How do you know AFM caused your problem? What cylinder was the lifter failure on?
And what filter screen and sending unit are you referring to? The fuel pump?
Meaningless? Seriously. Have you ever used Google? I used the year model of the truck not the series of engine.
If you would use Google yourself rather than trying to be a smarty pants on the interwebs you too could figure it is a common problem.
The filter I am referring to is the one under the oil sending unit at the rear of the intake.
This is an interesting post I found on the subject with my obviously lacking Google-Foo.
http://www.performanceboats.com/pb-open-water/76350-attention-owners-variable-displacement-gm-v8s.html
  • Replies 30
The link you posted is from 2010. The engines today have been redesigned.
He had a lifter fail, it was either an AFM lifter or it wasn't. Obviously the dealer knows and likely told him which it was. Failure of non-AFM lifters on LS and LT engines is pretty close to unheard of with stock valvetrains. And yes, they are the exact same lifters (12576400 non-AFM, 12619820 AFM).
Doh!
You can say that again.
What year truck do you have?
And FYI, if it was a common problem with these trucks, there would be a 200+ page thread here like the other common problems. There's not. You're like the third person to claim having a failed lifter. That's not very common in my book.
Virtually every serious engine problem on the 2014+ trucks reported on this site has been traced back to a failed AFM lifter and/or a failed valvespring (which need to be weak because the AFM lifters can't handle strong springs).
It may not be common, but it is the most common cause of serous problems with these engines. They are a weak point, denying that is simply denying reality and is pointless.
The bad news people need to understand is that simply deactivating the system doesn't make the lifters any stronger--they're still more likely to fail than the non-AFM lifters. The only way to make the valvetrain bulletproof is to replace them, which is pretty labor-intensive on these engines.
But that also allows you to sell a cam-swap to the wife as a "durability and safety improvement."
  • 4 weeks later...
when I worked at GM, they made 1350 trucks every day at our plant. Even 1 or 2 shifts on Saturdays to boot.
There were 2 other truck plants cranking out 2 or 3 shifts worth each.
So letting that sink in - any comments on any forum represent a miniscule percentage of the number of produced vehicles in a year. Trying to get any dealer to take a forum's results seriously based on that alone, is pretty optimistic.
It is great none the less for folks to share their experiences. Given the different levels of interest one experiences across dealerships, its good to have a resource like this to compare each other's results and see what worked, considering a lot of dealers drop the ball.
Personally I'd like to see the manufacturers forced to list the top 20 issues and their success rate of repair. Not likely to happen in my lifetime.
People don't understand just how many vehicles the plants crank out per shift. At the GM plant here in OKC when I worked there a car rolled off of the assembly line every 60 seconds or less depending on production needs. We pushed out almost 1000 cars a day, then times that by 50 weeks since GM does a mandatory 2 week maintenance shutdown each year and you get 250k cars a year just at the plant I was at in OKC.
More popular vehicles as said have multiple plants, so it is easy to say as in the trucks that a million trucks per year could be produced easily.
Nice. Like how our sales manager convinced his wife the difference between a GSXR750 and GSXR1100 was the frame size. :)
I haven't been following the forums in a while but was wondering if the AFM system is also present in the 2500 series 6.0L? If so are they having similar problems or did GM finally come up with a solution for the lifter failure other than a few instances? Also did they go to the 60k mile warranty instead of 100k because of this issue and they don't want to back their vehicles knowing there is an issue. I am currently undecided between the 6.4L 2500 Ram and 6.0L 2500HD but based on what I have been reading the reliability issue of GM I am leaning towards the Ram. Don't get me wrong I have been a long time GM guy but after issues I have had with my 03 Silverado and the track record they have had with the lifter issues makes me weary.
The 6.0 in the 2500 is not a gen 5 engine like the Direct injection style ones in the 1500. That being said the chevy 6.0 is Litterally BULLETPROOF. i have had 2 in the past with 200k miles. they were worked every day and they asked for more every startup. Hell my friend pulled one out of the junkyard out of a hummer and put it in his C10 and has been running 10 lbs of boost with a supercharger on the stock internals for several years now. its been around since 2000 so think of that before you go buy some italian fiat ram
Great, appreciate the info. I have always liked GM products over Dodge and Ford for reliability unlike most I realize every manufacturer has issues it is just how it is handled that makes a person come back.
  • 3 years later...
2016 Sierra Denali 6.2.  AFM.. 46000. 2 lifters collapsed. Plus a bent push rod.  Lifters back ordered. Not sure when they will be in... 1500 miles from home.  Going to look at buying unit to disable AFM. SUGGESTION?  Thanks for Dealer assistance.
Most use Black Bear Performance to disable the AFM.
    • Its just that it worked on 2024 trucks on this forum and my 2025 model truck, unless GM did something since that point to screw up access or Autel has a bad update. I haven't had need to use my tool since last year when I did the changes to the placard pressure settings and since then I updated the software on my Autel but have not plugged into the OBD so hard to say if I would get a surprise as well.    All I know last year when I bought the Autel I was warned to be sure to update it before I tried using the unit as they said who knows how long ago unit itself was actually manufactured as the software could be way out of date.
    • And so you had gone through the process of registering and updating the tool and so on ?. All I can say is that on the front page as the tool fires up you go to advanced mode, then vehicle model comes up and you choose Silverado ( not the DRW or EV  since your a single rear wheel ) , then I think its choice 2 which is 07/2021 - 12/2026 ( 433mhz 13542523 ) as that is the series of tpms sensors and then go down to choice 5 which is tire type/pressure selection. Hit yes and it says to connect to OBD port and turn ignition on.    Having said this, I updated the software in my tool lately and these year range choices look different from the past due to them doing some updates it would appear and I have not connected up to the OBD port since last year so hopefully I am not in for a surprise with them screwing up the software and that it won't work on my truck anymore either.    So my question is, when you plugged into the OBD and started your truck it had that message on the Autel screen "vehicle not supported" ?. That does seem odd as tire shops would be pissed right off if hey can't use their tool on the model year after mine that in theory is supposed to be much the same truck ... unless GM did some change in the computer system to block certain things from access.
    • Understanding and using modern scan tools is its own body of knowledge. I had little hope that would work...programming access to the BCM is probably required and that is not easy for us consumers. Expensive scan tool, GM programming subscription, online authentication, etc.   It also may be a matter of finding the right dealer to program it for you. Flashing a modern BCM might be a little too advanced for most tire shops.
    • Update for anyone following:    Installed everything as shown in diagram. Opted for 8 AWG from Battery Positive to a 50A resettable inline breaker. 8 AWG is tied into to 2x 12 AWG wires feeding a 6 way fuse bus in parallel (manufacturer’s design of what I purchased).    4 of the 6 fuses available for circuits are tied to terminal 30 of each relay. I tied a jumper from one of my spare circuits off the bus to terminal 86 of each relay. The trigger, terminal 85, was pulled from my interior by way of T-Taps from the X61A-X5 pins 10, 11, 17 and 23. This was the hardest part of the job. Even with the X61A unbolted and the X5 removed - there was VERY little wiggle room.  I added back up lights that I want to come on with my cargo lamp - but when I would check continuity between S48A-X1 pin 18 to its respective landing point on the X61A-X5 it triggers the factory relay… Instead I opted for a add-a-fuse on the passenger interior fuse panel (fuse location 10 - cargo lamp) and ran it through the boot on the driver side to my load. Did this to avoid introducing any electrical gremlins.   Note: Please check for continuity between the S48A-X1 and the X61A-X5. In my case wire colours were not the same as other’s who have posted. To do a continuity check you need a Multimeter. Completely disassemble the S48A-X1 and remove the brown face plate off the X61A-X5 by way of a flat head screwdriver - this was the only way I could get any results.   The outputs, terminal 87 of the relays, were fed into a junction box and landed at Individual studs and were labelled Aux 1-4.    At this point, all you need to do is run wire to your loads and bring them to ground. I created a negative bus in the engine bay, all my negatives land here.    For anyone having issues with all of your new aux switch lights coming on with the press of one - I noticed this only to be an issue when the battery wasn’t hooked up to my relays? No idea why, but it was quickly corrected by having my system buttoned up and functional.
    • Well I ordered the Autel ts508, and it won't work on my truck I tried all the 2023 and everything it just says vehicle not supported lol   I'm able to send this unit back, so I'm going to do that, then I'll just stop into a some tire shops and if none of them are able to do it, I guess ill have to spend a bunch of money to get a good scanner..... Thanks GM lol
